LG 42LT75 no backlight
  • tn245
    • Oct 2013
    • 530
    I have this LG TV open right now. Interesting TV - it has a built-in SATA hard drive for recording and pausing TV.
    It turns on and boots up, but there's no backlights. Not even a flash. The caps all looked and tested fine but I replaced the usual troublesome ones with Panasonics anyway. Voltages all look pretty close to what they should be.
    PSU is LGLP42SLPV2EV3 / EAY38640201
    The inverter is integrated on the PSU with just one inverter transformer. The inverter uses a OZ9925GN controller ic.
    ACD: 5.1V
    PWR: 1V
    ST 5V: 5V
    INV-CTRL: 4.6V
    ERROR: 0V
    BURST-DIM: 0.6V
    A-DIM: 0V
    6.5V: 6.4V
    3.4V ON: 1.4V
    19V: 20.3V
    3.4V: 3.4V
    12V: 12.1V
    I've read a lot of threads on it but I'm still not sure of the best way to test inverter outputs. Can I test this inverter with a CCFL as in this thread: https://www.badcaps.net/forum/showthread.php?t=19987 and if so, do I connect one end to each of the connectors where the pink wires plug in?
    Any other tests I can do? I am planning to break the TV down more to look at the bulbs and connections but would like to rule out the PSU/Inverter before going further.
    Thanks!
  • tn245
    • Oct 2013
    • 530
    Re: LG 42LT75 no backlight
    Hi! I'm back after a few months away. Moved house and lots of other stuff to do so haven't had much time to work on TVs. Got a backlog to clear out though so got to get working on them when I can.
    I've just come back to this one. I picked up another TV with the same PSU and tested it in this one and everything works, so it's definitely the PSU at fault. Comparing resistance readings on the inverter transformers between the two PSUs everything looks good there.
    Voltages on the working PSU measure the same as above except ERROR which I'm getting 5V where before I measured 0V on the faulty one.
    Can anyone help me track down the fault? I haven't found a schematic for this PSU yet. Anybody know of one?
    Any help greatly appreciated.
    • tn245
      • Oct 2013
      • 530
      Hi guys! I'd really appreciate some help on this one if anyone can. I'm a bit stuck and not sure how to go forward. Please?
      To summarise: I have two PSUs now - one borrowed from another TV. One turns on the backlights, the other doesn't. Voltages are the same on both (as in 1st post) except for ERROR, which is 0V on the faulty one and 5V on the working one. ERROR=5V only when backlights are connected up - not with PSU is isolated and jumpered on with a resistor.
      Any ideas at all?
      • Shinju
        • Mar 2014
        • 1239
        (edit)
        • tn245
          • Oct 2013
          • 530
          No? Not even a hint?
          • selldoor
            Slow Learner
            • 7870
            Heres a couple of hints.
            1Get a domestic cfl (NOT ccfl) 13 watt or less and solder an insulated wire to the centre contact.
            You need a bare bit at the end. With the board on you just touch the bare end of the wire to output pins on the inverter transformer ( which does actually look burnt) and the bulb should glow. You need to take care as it could be 2000vac.
            2 if you look closely at the back of the board there are some solder joints that dont look great down that side. I would re-flow them ( but see 3)
            3 As the inverter transformer doesnt have many pins you could try swapping them or at least the known good one.
            4 You could test the secondary winding resistances or even all of them on the two transformers. Is there a part number on it?
              • 31298
              change the small electrolytics around the invertor section.
              you "pana'd" the rest - so why leave the invertor area?
              • tn245
                • Oct 2013
                • 530
                Thanks selldoor and stj. That does give me something to go on.
                I checked the transformer resistances and I get the same readings on both boards so assumed the transformer was good. I'll look into the other suggestions tomorrow when I get back to it.
                Thanks again!
                  Check the FUSE F700 and the capacitance of that blue rectangular cap C708 by the inverter transformer.
                  • tn245
                    • Oct 2013
                    • 530
                    budm: F700 is good. C708 is 1012nF on the good board and 980nF on the bad one. Is that enough of a difference to cause a problem?
                    selldoor: The only CFL I have to hand is 20W which did nothing on either board, but.. I swapped the transformers over as you suggested and it made no difference to which board worked and which didn't, so I think the transformer is ok.
                    stj: I didn't have all the capacitor values to hand for those smaller ones but just tested them out of circuit for capacitance and ESR and all test within tolerance.
                    • selldoor
                      Slow Learner
                      • 7870
                      The bulb trick might only work for an instant when the board is switched on but before it goes into protection mode.
                      Did you reflow the other joints - moving the transformer would fix those ones. You could
                      also swap the C708 to see. If they are meant to be 1000nF it depends on the tolerance
                      if it is +-20% then they are well within. Is there anywhere where it suggests there is a
                      blon pin on the connector from the main board?
                      Edit
                      Can you also check the solder on C226 (I appreciate it may be one you may have resoldered
                      but it looks a bit black in photo may just be shadow or flux.
                        OK, the fuse F700 which is for feeding the B+ from the two large main filter caps to the backlights inverter circuits, now we need to find out if you do have 360~400VDC between the F700 and the negative leg of the main filter cap.
                        • tn245
                          • Oct 2013
                          • 530
                          selldoor
                          You're right. I got the CFL to light with the working board. Nothing with the non-working one. I reflowed the other joints you suggested and also tried swapping C708 between the boards. No change so far. There is a INV CTRL pin which I have been using to force on the inverter circuits.
                          budm
                          I'm reading 397V between F700 and the negative lead of the main filter cap.
                            That is good, I will need straight shot closed up pictures of the bottom side of the board in 4 sections so I can trace out the connections.
                            I also need the P/N of the IC701 I believe it is the PWM IC for the inverter circuit.
                            You can also try heating up those small 4 caps (C702, 113, 117, and one next to that small transformer) by that IC with hair dryer.
                            • tn245
                              • Oct 2013
                              • 530
                              Are these ok budm?
                                OK, that is pretty good. I will need that IC 701 number so I can see how those two MOSFETS for the Inverter transformer are driven.
                                • tn245
                                  • Oct 2013
                                  • 530
                                  U701 is FAN7382
                                    OK, here is the spec sheet for the FAN7382.
                                    Since you have two boards, you can do the resistance testing (board removed from the chassis) on the IC using pin 4 as the ref point (black probe on pin 4) and read the resistance against the other 7 pins. Then put the board back in and take the DC voltage reading on the VCC pin 1 (using pin 4 as the ground ref pin).
                                    • tn245
                                      • Oct 2013
                                      • 530
                                      Budm here are the measurements. I measured Vcc with the boards out of the chassis, but forced on with resistors.
                                      Code:
                                           Faulty board         Working board
                                      Pin
                                      1     Rises up to 155K      Rises to 164K
                                      2     532K               530K
                                      3     528K               529K
                                      5     10K                10K
                                      6     ~13M              ~12M
                                      7     ~13M              ~12M
                                      8     ~13M              ~16M
                                      Vcc   14.27V             13.15V
                                      The last three pin resistances fluctuated and seemed to change each time I went back to measure, but there was a significant difference between the readings on pin 8 between the boards.
                                      • tn245
                                        • Oct 2013
                                        • 530
                                        There does seem to be a difference here but I'm not sure what to make of it. ?
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • jimbofz
                                          lg 32LC46 backlight inverter board fault
                                          by jimbofz
                                          Hi this oldie had no backlight .after replacing caps on 24v rail ,
                                          still no b/l this uses inverter type:1315 B1-16A,
                                          im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                                          all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                                          this allows protect to be temporary overridden.
                                          b/l now comes on
                                          but the left hand side of pic is gradually darker than the right side
                                          i have the cct for the tv
                                          but it does not have inverter cct.
                                          i opened it up to inspect the ccfl tubes
                                          and they dont have any...
                                          12-19-2021, 06:58 AM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
