LG 42LT75 no backlight
+ More Options
Posts
  • Bilbo44uk
    • Jun 2014
    • 11
    Re: LG 42LT75 no backlight
    Did you get this working as i have one with same fault nothing seems to get it going tried replacing loads caps too. Tim
    • tn245
      • Oct 2013
      • 530
      Hi Tim. No I didn't get any further with this and after spending a lot of time on it decided to just replace the PSU. Sorry to not be able to help. If you get any further I would love to hear about it as I still have the board kicking around.
      • Bilbo44uk
        • Jun 2014
        • 11
        Hi, i re capped my set it all came on fine for a few mins, then the screen went off, sound stayed on, i have checked all caps, esr, swapped parts in and out, you name it i have done it, the drive voltage to the pwm IC Fan7382 is about 14.5v which is normal between pin 1 and 4, the two other pins seem to be for a logik pulse, i am in middle doing this as im bit annoyed with it as the TV has only come in for what i thought was a cheapo re cap, half a dozen puffed up caps and i thought easy peasy, then this happened, there is no logik whatsoever on this panel, i tested the backlights so know they are good, the inverter isnt turning on at all, i am going to check all small smd resistors for an open one, hold onto that board i may need cross reference. Tim.
        Update: Do you have a TTL Logic Probe, if so check the hi Lo logic state to the chip, pin 2 and 3, use 4 as ground, should get a hi state lo state off of those, if not go back one stage, i am in middle doing this now.
        • Bilbo44uk
          • Jun 2014
          • 11
          Further to my last message, the set is now working, i have spent hours on this as your see by my post times, here is what I did.
          As the O/P stated this is a weird fault, but in the end was logical, it boils down to a combination of bad solder joints capacitors and luck, replace all obvious bulging caps, ESr the rest, replace the 22nf ballast caps on the inverter output, this may resolve the backlight issue, it says 6kv, but 3kv are fine as it only hits 1800v on run, still no good? resolder the 1uf 600v box cap at the back of the inverter transformer, or replace if not 1uf on the dot, this got mine going tonight, obviously check the diodes, especially the one next to the FAN7382 as this was a crappy joint on mine too, check the chip voltage pins 1 and 4 look for around 14.5 volts, if you have a logic prob or modern digital scope check pin 2 and 3 for Hi and Lo logic states, right if you have all that done it should run, worth checking the tracks with a low ohms meter or even your esr meter, this is how i found at least 4 suspect solder joints, ultimately i believe it was the blue box capacitor on the back of the inverter, I also checked ever SMD resistor and diode on the board around the main switching transistors and the drive to the IC FAN7382. I think you just have to be very persistent on this board, when the Tv is working, SELL IT asap!! Tim.
            "replace the 22nf ballast caps on the inverter output, this may resolve the backlight issue, it says 6kv, but 3kv are fine as it only hits 1800v on run, still no good?"
            I would not use 3KV since startup voltage will be higher than that. Also are you sure the ballast cap is 22nF not 22pF? 22nF is very high capacitance for ballast cap.
            • Bilbo44uk
              • Jun 2014
              • 11
              sorry 22pf, i was tired, the sets now working and been collected, in the end it was the blue box cap that caused my issue, tim
              • tn245
                • Oct 2013
                • 530
                As I'd said in a post earlier in the thread, with mine I tried swapping the blue box cap with the one from the working board I had and it didn't solve it. Maybe I'll try the other suggestions though if I get any time to go back to that board.
                Glad to hear you got your one going.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4948
                  • New Zealand
                  #48
                  Originally posted by budm
                  I would not use 3KV since startup voltage will be higher than that..
                  x2
                  Manufacturers are cheap. They aren't going to use a 6kV capacitor where a 3kV one would do.
                  -David VanHorn
                  • lostone
                    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                    by lostone
                    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                    05-19-2024, 11:40 AM
                  • DanPoka
                    by DanPoka
                    02-15-2025, 05:05 AM
                  • Comp_Pro
                    No Backlight Macbook A1990 820-01041
                    by Comp_Pro
                    Hello all,
                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                    Tests performed:
                    There is no backlight even with a good screen.
                    Backlight IC is receiving the correct support voltages.
                    Fuse F8400 ok
                    Current sense resistor R8400 ok
                    Backlight IC is receiving 3.3V on enable pin.
                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                    Backlight IC receiving 5V from PP5V_G3S
                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                    05-06-2024, 10:23 PM
                  • jimbofz
                    lg 32LC46 backlight inverter board fault
                    by jimbofz
                    Hi this oldie had no backlight .after replacing caps on 24v rail ,
                    still no b/l this uses inverter type:1315 B1-16A,
                    im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                    all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                    this allows protect to be temporary overridden.
                    b/l now comes on
                    but the left hand side of pic is gradually darker than the right side
                    i have the cct for the tv
                    but it does not have inverter cct.
                    i opened it up to inspect the ccfl tubes
                    and they dont have any...
                    12-19-2021, 06:58 AM
                  • cheebster
                    iPad Pro 12.9 5th Gen Backlight Issue
                    by cheebster
                    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                    Anyone...
                    05-20-2025, 09:17 AM
