Sharp Aquos LC52SE94U hit by surge
  • Fwrothy
    • Feb 2014
    • 178
    Re: Sharp Aquos LC52SE94U hit by surge
    I was just asking a general question Selldoor. I know very little and trying to learn. My question was asking if TO262 is a case type? If so what is the definition of a TO262 case?
      TO262 is a case format. It's like the TO220 but the metal tab is missing, it's primarily used in surface mount applications (like TO263, known as D2PAK.)
      You want TO220 format.
        Just make sure the tab is isolated.
        • Fwrothy
          • Feb 2014
          • 178
          Thanks Tom66, just came from wiki, looks to me like TO-220F. Can u confirm or does it matter?
          • Fwrothy
            • Feb 2014
            • 178
            Thanks Buddm that's the answer I was looking for!
            • Fwrothy
              • Feb 2014
              • 178
              So is there a parts list or not, all I could find for rdenca231wjqz was 'unit replacement item'.
              Need to spec ic for next step.
              • selldoor
                Slow Learner
                • 7870
                #67
                Whoah!! did you see my late edits re P channel N channel
                Dont think those digikey ones will do
                • Fwrothy
                  • Feb 2014
                  • 178
                  Could you elaborate pls,as I mentioned before, still got my training wheels on. (-:
                  • Fwrothy
                    • Feb 2014
                    • 178
                    Originally posted by budm
                    Here is the simplified diagram and the how that shorted out MOSFET is connected.
                    From this this schem, are these FETs not N channel
                    I'm getting confused.
                      They are almost certainly N-MOSFETs.
                      • Fwrothy
                        • Feb 2014
                        • 178
                        Having difficulty finding anything to match IC7800 that drives the damaged MOSFET Q7808
                        It's an ST brand with designation DAS001/ on the top line and EZ807 below.
                        Incidentally the other MOSFET Q7805 paralleled by source pins is driven by IC7801 which is an ST L6562D ( lower line EZ810) it's easy to find.
                        • selldoor
                          Slow Learner
                          • 7870
                          #72
                          Sorry if I confused you but didnt want you buying the wrong one.
                          Thing is that almost all the ones listed on Ebay say that it is a P channel
                          That does correspond with the "P" as part of the part number. Then I realised
                          that the ones we had seen were all N channel and it does seem odd that the marking for both is the same - still has me wondering anyway follow Tom and Budm on that.
                          Whilst it is not confirmed I think the das001 is a TSM103 - It was suggested by Ben7 and also appears with the dual description on some schematics if you google images for it
                          • Fwrothy
                            • Feb 2014
                            • 178
                            Thanks Selldoor , no worries I find confusion a normal part of the learning process. Any idea where to find a data sheet for the das01 or cross reference to TSM103?
                            • Fwrothy
                              • Feb 2014
                              • 178
                              It looks identical to my PSU board, so it should be close enough. The only difference to me is a missing filter choke probably for the US version, the EMI restrictions are lesser there maybe.
                              Tom66 can u find the Q7808 on your RDENCA231WJQZ board,I was unsuccessful in finding it on the schem?
                              Would be on the sink rail near the Q7805...
                              • selldoor
                                Slow Learner
                                • 7870
                                #75
                                No google in Canada? here is one- you can find others
                                http://elektrotanya.com/files/forum/...001_TSM103.JPG
                                doesnt prove anything.
                                I have gone to Algeria for 2 weeks so probably no internet
                                Well not for free!!
                                • Fwrothy
                                  • Feb 2014
                                  • 178
                                  Well not for free!!
                                  No but a data sheet would I believe. I have the google -just not the experience or background knowledge...
                                  I hope you are in Algeria for pleasure on a vacation, regardless, enjoy!
                                  Thanks for the help.
                                    I will try and check your part requested as soon as I open the TV again.
                                    • Fwrothy
                                      • Feb 2014
                                      • 178
                                      Thanks in advance Tom66.
                                      As far as I can tell the Q7808 does not exist in the RDENCA231WJQZ.
                                      • Fwrothy
                                        • Feb 2014
                                        • 178
                                        Thanks anyway Tom66 I have confirmed it does not exist on that board nor does the second coil l7802 under the cage.
                                        I have ordered a new MOSFET but do not have a scope to check the L6552 (IC7801) oscillator that drives the gate. Any suggestions?
                                          So your board is not the same as the one from Shopjimmy that we were using to troubleshooting your board? it does not have Dual PFC circuits?
                                          I will not taking a chance of installing the new MOSFET without replacing the IC, if the the out put of the IC is stuck on HI (instead of turning the MOSFET ON-OFF), it will cause your new MOSFET to blow, so makes sure to leave the lamp in place of the fuse.
                                          Your picture in post 18 I see two MOSFETs and two PFC diodes though.
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • jonah1024
                                            Sharp Aquos LC-40UG7252E LCD TV burn in?
                                            by jonah1024
                                            Hello!
                                            I'm a few days old into this TV screens repair universe so please bear with me.
                                            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                            - I did a factory reset as well...
                                            07-16-2024, 04:23 AM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
