Sharp Aquos LC-60LE635E three blinks
  • klassic
    • Oct 2023
    • fr
    Hi community,
    I will describe my problem with a TV in those short following terms to be the most precise :
    What i have :
    power board DPS-162KP-1
    main logic board QPWBXF733WJN2
    symptoms :
    white led light logo at startup,
    after 2 minutes, blinking 3 times a row, repeating
    no backlight (and apparently no picture, checked panel with flashlight)
    no startup sound
    powerboard investigations :
    1-2 PNL : 0v
    3-4 GND
    5-6-7-8 UR : 13.15v
    9-10-11-12 GND
    13 AC_DET 3.29v
    14 PS_ON 2.84v
    15 BU5V : 5v
    16 PNL_POW : 0v
    17 PWM1
    18 x
    19 DIM
    20 x
    21 OFL : 0v
    22 ERR : 0v
    23 PWM2
    24 STB :0v
    i have 400v at the big caps
    if i short BU5v and PNL_POW together, board alone and separated, i get 12v at 1-2pins PNL
    i have nothing at the backlight connector
    mainboard investigations :
    13.12v is going into a bunch of step down regulators
    i get several voltages from here, 3.3v , 5v, 1.74v and other voltages (if i measure them right, i'm not 100% sure)
    there seem to be a smd led near cpu, no blinking
    any ideas ? I've have my own, but i wouldn't like to influence you if i'm wrong
    thanks for advices in advance, it's my first head scratching (no bad capacitor) repair and i've learned what to check here
  • klassic
    • Oct 2023
    • fr
    from my investigations, i think, but not sure, that my main logic board is dead ?
    • CoppellTVRepair
      Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational, Take 2
      by CoppellTVRepair
      There's a thread on the site titled "Sharp Aquos 80" TV ~ Model # LC-80LE844U ~ Not operational", detailing the process of the most common problem affecting power supply board PSD-0888D.
      For the sake of bringing something of value I'd also add (even though it probably belongs in the thread itself) that what's described there is one of the TWO possible variants of the failure - blown IC, blown fusable resistor 2.2 Ohm or 2 Ohm.
      The other is an internally failed, but not shorted IC, resulting in resistor that's still intact, but the board spontaneously losing power...
      Today, 06:25 PM
    • scubacamper
      Sharp Aquos LC-70C6400U Half Screen Dark
      by scubacamper
      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
      05-03-2025, 12:19 PM
    • sefoster
      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
      by sefoster
      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
      11-20-2022, 09:29 AM
    • jonah1024
      Sharp Aquos LC-40UG7252E LCD TV burn in?
      by jonah1024
      Hello!
      I'm a few days old into this TV screens repair universe so please bear with me.
      Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
      - I did the classic unplug and hold power button to discharge the caps but it didn't help.
      - I did a factory reset as well...
      07-16-2024, 04:23 AM
    • joblo37pam
      Sharp LC-80LE844U Blinks 2 slow, 5 fast
      by joblo37pam
      It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
      The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
      10-26-2023, 02:17 PM
