A funny fuse story – Lumix LX100 II
  • corrize
    • Apr 2021
    • 283
    • France
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping to 0v.
    I can't understand this repair attempt ? Visual confusion of letters O and G ? The camera-repair-man had only fuse G in stock ???
    Anyway, I have a question : I can replace by « O » fuse (32V 2,5A). But, that seems low. The camera is good, there is no reason why the original fuse should have blown.
    I hesitate to upgrade a little bit the fuse, at least 32V 3A, or 3,5A ? What do you thinks pls ?
    For example, the camera fuji X100V (same specs and same battery 7,2v 1Ah) has a T fuse (32v 5A) at first fuse, like another Nikon camera.
    • 31156
    Re: A funny fuse story – Lumix LX100 II
    so the cap shorted and blew the fuse and somebody did a swift bodge-fix!
    • corrize
      • Apr 2021
      • 283
      • France
      I checked that, I disassembled the two fuses, and you are right, there was one « O » fuse under. And it is blow. (The G one is good).
      I’m not convainced for the cap, the missing cap is a 0402 one. Too small for blow for me. The big one on the picture is ok and untouched. But possible.
      When I pushed a little bit the 2 fuses soldered, they left alone from the board. So bad solder. Maybe the camera repair man did a bad solder and accidentaly moved the cap too ?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8290
        That sums it up very nicely. What I am thinking too.
        • petehall347
          • Jan 2015
          • 4432
          maybe there never was a cap there .one pad looks not touched .the other pad probably was the solder supply for the bodge .
            • 31156
            but it doesnt explain the blown fuse - a bad cap would.
            • corrize
              • Apr 2021
              • 283
              • France
              There was of something soldered on the pad, so I guess there was a cap. I just never saw the small 0402 cap blown. (The big component is an inductor).
              I guess I will replace the fuse by the same original "O" one (32V 2,5A). The max power come probably from the direct charge via USB cable for charging a 1000mAh battery. So it probably don't has fast charge (not in the specs). So the fuse should protect 1A max réal at 7v. So 32V 2,5A seems alwready oversized if i'm not wrong ?
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8290
                To me there was a cap there.
                • Kg74
                  • Feb 2013
                  • 67
                  • Usa
                  Working on a GH5. Similar part with same blown fuse. I caused it by leaving battery in while taking out another part that was bad. I used the stack method to repair the blown "O" fuse as I didn't want to risk melting the screen. I don't think there was a cap there. If you dig you can find the schematic or look for the part on Ebay and check.
                  I know this is old, but I bumped into it while checking on my issue. The "O" fuse is a common Panasonic part - on their cameras they of course use their own parts. Makes it easy.
                    Surface Mount Fuses Fundamentals Datasheet
                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                    10-07-2024, 06:07 AM
                    TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                    FF Series (Very Fast Acting), 0603 Size
                    Features
                    ● Very fast acting at 200% overload current levels
                    ● Low DCR
                    ● High inrush current withstanding capability
                    ● Fiberglass enforced epoxy fuse body
                    ● Copper termination with nickel and tin plating
                    ● Halogen free, RoHS compliance and lead-free
                    Applications
                    ● Notebook computers and tablets
                    ● Digital cameras
                    ● Memory cards
                    ● Toys
                    ● Bluetooth earphones
                    ● Portable electronic devices​...
                    10-07-2024, 05:50 AM
                  • eidam655
                    GPU 1206 SMD fuse markings & replacement fuses
                    by eidam655
                    I need to replace a fuse on one of the graphics cards I am working on. It is a 1206 SMD fuse, white in color and has a "10" written in a blue rectangle on it.
                    How do I find a suitable replacement? What is the general rule to identifying fuses' parameters? I found something in an eshop near me (see photo) but am very hesitant to use this as a replacement....
                    04-14-2022, 12:46 AM
                  • jesterace
                    Samsung UE46ES8000 Blown fuse but no other signs of short
                    by jesterace
                    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                    09-11-2024, 03:14 PM
                  • jshhh
                    Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                    by jshhh
                    Hi guys,
                    I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                    How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                    Anybody know how to remove this type of fuse?
                    (The fuse is toward the bottom of the image labeled F2)...
                    06-17-2025, 01:35 AM
