Sony LED 65X9005A shuts down after few seconds - looking for help
  • tec3000
    • Mar 2024
    • 119
    ok, here it is:
    and where is the B board located? That's just a different name I assume?
    • Diah
      • Feb 2013
      • 6545
      Originally posted by tec3000
      ok, here it is:
      screw the boards to tv chassis , then try one flat ribbon cable each time )to disconnect and turn on ( you have 4 ) ... see the Tv register error 4 blink at once or start on and tell which cable and the tv reaction.
      • tec3000
        • Mar 2024
        • 119
        hi, what exactly do you mean here? Should I screw one particular wire to the TV chassis? If so, which wire?
        • Diah
          • Feb 2013
          • 6545
          LOL
          you removed the heat sink of the boards... now the boards are free no screw tight it to tv chassis... need to put 2 screw at least in place
          the flat cable one by one disconnect them and turn on,,, see if the tv give error or stay on
          • tec3000
            • Mar 2024
            • 119
            ah yes of course. So it doesn't fall. I just thought you maybe want me to ground something...but understood.
            I did that and also tested one by one. First the bottom left, then right. Then I did the other two on the top right. One by one. Unfortunately the TV always turns off after approx. 15 seconds - if I don't switch to the i-Manual.
            • Diah
              • Feb 2013
              • 6545
              do it again by disconnect 2 together , start with 2 on the top
              • tec3000
                • Mar 2024
                • 119
                Alright. Interesting observations (especially Point 5):
                1) I tried all sorts of combinations. All with the same outcome. I tried taking out the two at the top, then at the bottom. I took out an up/down pair. Then the other pair. I even took out three at once. TV shuts off after 15 seconds and I get the 4 blinking error code.
                2) Interesting to note is: taking out the flat cable on the top right results in a dimmer picture right from the off. It's barely visible when I turn on the TV. With the other 3 it's normal light output in the beginning.
                3) I turned down the backlights to minimum. TV still shuts off.
                4) I turned on maximum power saving settings - which results in disabling the backlights - TV STILL SHUTS OFF.
                5) I enabled an eco mode "Picture off" (which is useful when listening to music I guess). TV DOES NOT TURN OFF. Like with the i-Manual TV stays on forever.
                I'm curious if you guys know what this means. Especially Point 5!
                Appreciated!
                • Diah
                  • Feb 2013
                  • 6545
                  Point 5 indicated the LED driver boards when it shutting down. tv remain on, in other words boards over load defect...
                  BUT for me i will never invest to replace this boards unless i inspect the LED BL visually to see the real status of them.. just because if there are shorted LED they will make the same load on the boards..
                  the reset all to you
                  • tec3000
                    • Mar 2024
                    • 119
                    So you think I can replace the LED driver board and it will get rid of the problem? Or not? I don't have a real backlight problem so far. Light output is satisfactory - even with the darker spots that can be seen on the i-Manual. With real world content I never noticed any issues with the backlights. This is an 11 year old tv. It doesn't have to be perfect.
                    • tec3000
                      • Mar 2024
                      • 119
                      Originally posted by lotas
                      Code error 4
                      Where do I find BACKLIGHT_MON? I can't locate it anywhere.
                      • Donny2derby
                        • Apr 2023
                        • 228
                        • Uk
                        #31
                        If I were you I would break the tv down to the back panel, test the LED's and the you know for certain where the issue is. You have been told by very knowledgable people what the issue seems to be. Don’t ignore their advice.
                        • Diah
                          • Feb 2013
                          • 6545
                          Donny2derby​ , he knew very well he have defect LED... but he said satisfied with black spots on screen...
                          replacing boards will bring nothings.... if i teach you now how to by pass the error... your TV will toasted the LED driver boards and LED power boards (the one on the left side of the power boards ).
                          post clear photo of the LED power boards... and ready under yours hand fire extinguishable LOL
                          • tec3000
                            • Mar 2024
                            • 119
                            I wouldn't know how.
                            • tec3000
                              • Mar 2024
                              • 119
                              Here the photo. Hope it's the correct one!!
                              Thank you!
                              • lotas
                                • Jan 2016
                                • 4839
                                • Russia
                                #35
                                As a rule, over time, LEDs degrade (especially after 11 years) and the LEDs begin to consume more current than necessary, the controller monitors this and the protection in LD is triggered and the LD controller sends an error to the motherboard and the motherboard blocks LD and turns off the TV (snorting code error "4").
                                • Diah
                                  • Feb 2013
                                  • 6545
                                  write over here the pins chart of socket CN6601 name and Pin No. we cant see it clear
                                  • tec3000
                                    • Mar 2024
                                    • 119
                                    I took a close-up. Made sure everything is readable. Have a look.
                                    • Diah
                                      • Feb 2013
                                      • 6545
                                      pin 11 LD_ERR pull it out from the socket ..put yours DM probe on it with reference to tv chassis.... turn on and read the value at start the tv and later
                                      • tec3000
                                        • Mar 2024
                                        • 119
                                        Speaking of which... I wanted to describe how this whole mess began. It might be a coincidence and the TV simply aged. However, the timing was a bit odd. I am doing skinning stuff for Kodi. I was working on a window where I had no background - meaning 90-95% of the window was pitch black - for hours and hours. Even days. Finally the TV got darker and automatically turned off - while I was actively using the TV. That was odd. But I was able to turn the TV back on and continue to work. Then I added a coloured background and for a few days I had no issues whatsoever. But after a few days the TV started to turn off again and since then I have this issue. So did I cause this with the black background or is all a coincidence?
                                        • tec3000
                                          • Mar 2024
                                          • 119
                                          I don't wanna mess this up. Have a look at the pic. I pulled out the LD_ERR wire. Do I need to ground it? Where do I go in with the red probe of my MM? Wire, connector, socket? Where exactly? Thank you.
                                          • riko 656
                                            Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                            by riko 656
                                            I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                            Laptop Model:
                                            • Model: Lenovo Legion Slim 5 16APH8
                                            • GPU: NVIDIA GeForce RTX 4070
                                            • Main BIOS chip size: 32MB
                                            • VBIOS chip size: 16MB
                                            Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                            What I Have Tried So Far:
                                            1. I
                                            11-04-2025, 05:14 AM
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • riki_22
                                            ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                            by riki_22
                                            I’m working on an ASUS B5402CEA notebook.
                                            B5402CEA_MB_R2.2
                                            HA4YT LA-L861P
                                            REV:1B
                                            The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                            I suspect the BIOS might be corrupted.
                                            Could someone please check and clean (repair) the attached BIOS dump?
                                            I’ve also attached a few photos of the motherboard for reference.
                                            Thanks in advance for your help!
                                            11-03-2025, 04:38 AM
                                          • APOPAP
                                            Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                            by APOPAP
                                            Hello everybody,
                                            First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                            The same question is also posted on another site, here it is:
                                            Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                            I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                            08-25-2025, 10:12 AM
