Sony LED 65X9005A shuts down after few seconds - looking for help
  • tec3000
    • Mar 2024
    • 119
    Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
    I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours! Here I uploaded a picture of it:
    Online research tells me there is a backlight error and I can bypass it by grounding the wire that sends the error signal to the main board. I know it won't fix the underlying issue but chances are my TV will work just fine for the time being - once I disable the error signal.
    I already replaced the powerboard and grounded the BL_ERR wire. My observations:
    1) When I disconnect the powerboard end of the BL_ERR wire and ground it to one of the powerboard screws nothing changes. TV turns on and off within a few seconds. Then I get the 4 blinking error code.
    2) When I disconnect the mainboard end of the BL_ERR wire and ground it to one of the mainboard screws the TV gives me 6 red blinking error code. The TV doesn't even turn on.
    Right now I don't know how to proceed. I am grateful for some advice!
    Here some more pics. (I can upload more pictures if needed.)
    First a close-up of the powerboard:
    And here is the complete back of my tv:
  • lotas
    • Jan 2016
    • 4839
    • Russia
    Code error 4
    • tec3000
      • Mar 2024
      • 119
      thank you. So what do I do?
      • tec3000
        • Mar 2024
        • 119
        I first want to try to disable the wire that sends the error signal so that the TV doesn't turn off.
        • EazyBone
          • Jun 2023
          • 1362
          • United states
          So you have bad led driver board or panel. It says to check the voltage in the picture of that connection. According to the blink code anyway
          • tec3000
            • Mar 2024
            • 119
            Is it possible or not to bypass the error signal that is sent that turns the TV off? I have described everything in my initial post. The TV doesn't turn off when I'm in the i-Manual. I think there is a way to take out one wire and my TV won't shut off.
            • lotas
              • Jan 2016
              • 4839
              • Russia
              Have you tried doing a hard reset (if it was a software failure)?
              • tec3000
                • Mar 2024
                • 119
                I did a reset. I had to hold the up button on my remote and press the power button on the back of my TV. Then it said reset on my TV. Not sure if this is a hard reset though.(This is a non-Android Smart TV.) Nothing changed unfortunately.
                • lotas
                  • Jan 2016
                  • 4839
                  • Russia
                  No, there are two buttons pressed on the TV Vol - and Power, keep them pressed and insert the plug into the socket.
                  • tec3000
                    • Mar 2024
                    • 119
                    Yes, I did tried the volume down AND Power button combo too. Then plugged in my TV. Kept holding both buttons until the TV turned on. But then it simply turned off again... This is a TV is from 2013. At least with the other combination a reset message appeared on my TV.
                    • tec3000
                      • Mar 2024
                      • 119
                      I still have not the slightest clue what to do next. Like I said, I'm not after fixing the backlight problem (yet) since the i-Manual clearly shows my TV still operates normally. I want to bypass the problem. Question is HOW?
                      • EazyBone
                        • Jun 2023
                        • 1362
                        • United states
                        If you read what he posted, I assume lotas posted the codes for your tv, error codes are different depending on the TV. So what he posted for 4 blinks is not the backlight. It's the led driver board. The code says to check the voltage on the pin indicated. That's your next step. The led driver board doesn't mean backlights are bad.
                        According to the first part of the code. It's your led driver, or your panel is bad.
                        • Diah
                          • Feb 2013
                          • 6550
                          you have clearly LED defect and can be noticed from first picture... all other parts on TV are fine... Sony will never admit or write at Service Manual any issue at LEDs... so the refer to the service manual are useless.
                          yours LED BL Edge one... by pass BL_error.will not work when you have shorted one or more LED ( see the black shadow at the first Picture )
                          if yours plan to use the TV with out replacing LED BL. then at least you need to have access to LED BL edge boards and from there remove the shorted one.or replace one or more.
                          if you want to by pass then the work should be on the LED driver boards... nark first the line which had shorted ( high currents ) pill line.. cut it and add external load ( such Filament Lamp ) to suck all the extra currents which produced because of the shorted LED ). the LED driver boards will no more generated BL_error signal to MB.
                          • tec3000
                            • Mar 2024
                            • 119
                            Originally posted by lotas
                            Code error 4
                            Ok, I have to ask. I have my meter here. But can't find the board in question. Where is the B board? I couldn't locate JL9112 anywhere.
                            • tec3000
                              • Mar 2024
                              • 119
                              Thank you. It's a bit confusing to be honest. If it's the LED driver board replacing should fix my issue, right?
                              • tec3000
                                • Mar 2024
                                • 119
                                Thank you. Gotta say, I'm a noob. I won't be able to do what you suggested. Like adding extra load etc... I CAN buy a new LED driver board and change it. But not sure it will fix my issue?
                                • Diah
                                  • Feb 2013
                                  • 6550
                                  Man, from yours first photo ( E. Manual ) the screen had black spot shadow on the top... this is remark. one or more LED Units are off.... new driver boards will not help even if you change all boards..
                                  e.manual section at Sony displaying and TV remain ON... just because the SOS ( BL_ERR ) will be ignored from main boards... its same when you call diagnostic service menu.... this facts make you and other thinking LED are fine.. but they are not..
                                  you have 2 flat ribbon cable going under the screen from LED driver boards.... remove the heat sink and post clear photo of it... also try remove one ribbon cable at once and turn on... see if the set remain on... or it will give error immediately.
                                  • Diah
                                    • Feb 2013
                                    • 6550
                                    or instead to call e.manual .. try at the time the set on so fast try change the picture setting , backlight level to down as much you can
                                    • tec3000
                                      • Mar 2024
                                      • 119
                                      here the pic. Is that the correct board?
                                      • lotas
                                        • Jan 2016
                                        • 4839
                                        • Russia
                                        This is T-CON, L.Dr. board. is located here.
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • mauda
                                          Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                          by mauda
                                          I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                          Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                          05-21-2023, 11:56 PM
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
                                        • riki_22
                                          ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                          by riki_22
                                          I’m working on an ASUS B5402CEA notebook.
                                          B5402CEA_MB_R2.2
                                          HA4YT LA-L861P
                                          REV:1B
                                          The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                          I suspect the BIOS might be corrupted.
                                          Could someone please check and clean (repair) the attached BIOS dump?
                                          I’ve also attached a few photos of the motherboard for reference.
                                          Thanks in advance for your help!
                                          11-03-2025, 04:38 AM
                                        • APOPAP
                                          Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                          by APOPAP
                                          Hello everybody,
                                          First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                          The same question is also posted on another site, here it is:
                                          Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                          I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                          08-25-2025, 10:12 AM
