samsung 58 inch plasma
  • adamp91gvm
    • Jan 2014
    • 706
    #141
    Re: samsung 58 inch plasma
    getting the same reading from the top pin on the black connector
    • adamp91gvm
      • Jan 2014
      • 706
      #142
      View My Video
        OK, now try without buffers; any change? Y-main is looking bad.
        • adamp91gvm
          • Jan 2014
          • 706
          #144
          I'll have to check it tomorrow I'll do it as soon as I finish thank you for your help so far mate its very much appreciated
          • adamp91gvm
            • Jan 2014
            • 706
            #145
            Can they be fixed ? Also would that transitor being slightly different make any difference
              Without schematics, you're likely to spend a lot of money and time fixing it. Beyond my time, at the moment, at least; you're free to try yourself. The X-main should be checked next, I'll attach an image when you're ready.
              • adamp91gvm
                • Jan 2014
                • 706
                #147
                Checked the board with out buffers and readings don't change
                  Will check X-main tonight, when I get back from uni.
                  Just for comparison, here's a Y-sustain(=Y-main) output test on a Fujitsu/Hitachi plasma panel I was testing: http://www.youtube.com/watch?v=nGr5ydz9gTk&t=3m10s
                  • adamp91gvm
                    • Jan 2014
                    • 706
                    #149
                    Hi mate just tried it on the same blue thing on the x main and got a much better reading
                    • adamp91gvm
                      • Jan 2014
                      • 706
                      #150
                      any more checks i could do on the y main ?
                        Could you show X-main waveform.
                        • adamp91gvm
                          • Jan 2014
                          • 706
                          #152
                          Here It goes up and down a bit though
                            Still doesn't look right - show me where you're probing please.
                            • adamp91gvm
                              • Jan 2014
                              • 706
                              #154
                              The blue one like the other side
                                Which lead of that; top or bottom?
                                • adamp91gvm
                                  • Jan 2014
                                  • 706
                                  #156
                                  top
                                    The wave should look better if X-main were working, then.
                                    Check that the X- and Y-main boards are both getting Vcc.
                                    Could be a bad control board.
                                    • adamp91gvm
                                      • Jan 2014
                                      • 706
                                      #158
                                      i think it might be the control board too there is a glass fuse on it thats only got power to one side nothing at all to the other just where the power comes into it i was just going round it before just checking everything if that makes any sense ??
                                        Where is this fuse?
                                        • adamp91gvm
                                          • Jan 2014
                                          • 706
                                          #160
                                          Here I just took it off to have a look at the back
                                          • KYBOSH
                                            Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                            by KYBOSH
                                            Saved this beast from the landfill this weekend.
                                            Manfactured July 2013 in Mexico.
                                            I love working on plasma TVs.
                                            Its been a while but I was lucky enough to find 2 this week.
                                            The TV powers on and stays on but no picture. Havent checked for sound yet.
                                            No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                            Will start troubleshooting tonight.
                                            10-17-2024, 01:17 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • joel warren
                                            Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
                                            by joel warren
                                            TV was working fine and then just shutdown one day. It will not turn back on. I get a backlight for a little while, then it just clicks and won't fully boot.
                                            I took off the back panel and did the basic troubleshooting and it seems like it's a panel issue.
                                            The backlight will stay on if I disconnect either of the ribbon cables going to the panel. I've watched this video (https://www.youtube.com/watch?v=77tymvTJDxo) and am wondering if this could be the issue, just a bad cap on the panel.
                                            Any assistance is appreciated.
                                            01-27-2025, 06:31 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
