samsung 58 inch plasma
  • adamp91gvm
    • Jan 2014
    • 706
    #41
    Re: samsung 58 inch plasma
    Gold black red blue
      62 ohm... that should be OK... so when you put it in place do you see any glow from the screen?
      If not you would need to connect another resistor of around the same value (100 to 470 ohm ideally, a little less is OK) from 5V to VS ON.
      • adamp91gvm
        • Jan 2014
        • 706
        #43
        So what ohms are the ones in them pics tried to find em on the calculator but nothing also got gold gold violet yellow
          It's blue red black gold which is 62 ohm.
          Gold is last band.
          Third band generally black or brown only, to help narrow it down.
          • adamp91gvm
            • Jan 2014
            • 706
            #45
            Right ok well I get the power board to click once and stay on using one resistor so does that tell me there is a fault with the A board if when I plug that in I get constant clicking ?
              No, because the control board could cause the clicking once the main board sends the 2nd ON/OFF (VS ON) to power board. It's important to bring the board up completely and have test patterns or you can't tell if control, main or y-main/x-main are at fault.
              • adamp91gvm
                • Jan 2014
                • 706
                #47
                Right I'm just checking the board and with nothing connected to the power board just the power wire should I be getting any power to va or vs ?
                  Nope. You need VS ON to get VS and VA.
                  Stick some 100 ohm through hole resistors in that CPC order and keep them for future tests... will cost less than £1.
                  • adamp91gvm
                    • Jan 2014
                    • 706
                    #49
                    I tried to find them on the site could not find them
                      http://cpc.farnell.com/_/mcf-1w-100r...00r/dp/RE04045
                      • adamp91gvm
                        • Jan 2014
                        • 706
                        #51
                        dam cpc have already printed my order and i can not add to it ill have a trip to maplins in a bit
                          In which case ask for:
                          http://www.maplin.co.uk/p/metal-film...resistor-m100r
                          • adamp91gvm
                            • Jan 2014
                            • 706
                            #53
                            Got My resistors like this ?
                            • adamp91gvm
                              • Jan 2014
                              • 706
                              #54
                              But I have 2 sets of 4 pins ?
                                1st pic looks OK, so do you have Vs/Va and glow from panel?
                                As for the two sets of pins... that's a good one. Never had that before. I think it's CN2008.
                                • adamp91gvm
                                  • Jan 2014
                                  • 706
                                  #56
                                  Should it be instant ?
                                    After a few seconds of clicks and whining sounds from PSU, Vs/Va should come up. Could take around 5 seconds to screen glow. Once glowing a few more seconds to test patterns.
                                    • adamp91gvm
                                      • Jan 2014
                                      • 706
                                      #58
                                      Nothing comes up
                                      • adamp91gvm
                                        • Jan 2014
                                        • 706
                                        #59
                                        Just one green flashing light from the t con there is 2 lights on there one flashes once then the other keeps flashing I'm getting the right values from vs and va though
                                          Check screen carefully for glow. Try without jumper. Anything?
                                          • KYBOSH
                                            Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                            by KYBOSH
                                            Saved this beast from the landfill this weekend.
                                            Manfactured July 2013 in Mexico.
                                            I love working on plasma TVs.
                                            Its been a while but I was lucky enough to find 2 this week.
                                            The TV powers on and stays on but no picture. Havent checked for sound yet.
                                            No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                            Will start troubleshooting tonight.
                                            10-17-2024, 01:17 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • joel warren
                                            Looking for some help please. Samsung UN75RU800DFXZA rebooting, no picture, clicks
                                            by joel warren
                                            TV was working fine and then just shutdown one day. It will not turn back on. I get a backlight for a little while, then it just clicks and won't fully boot.
                                            I took off the back panel and did the basic troubleshooting and it seems like it's a panel issue.
                                            The backlight will stay on if I disconnect either of the ribbon cables going to the panel. I've watched this video (https://www.youtube.com/watch?v=77tymvTJDxo) and am wondering if this could be the issue, just a bad cap on the panel.
                                            Any assistance is appreciated.
                                            01-27-2025, 06:31 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
