samsung 58 inch plasma
    Re: samsung 58 inch plasma
    Well, the control board appears to be functioning. So, it must be something more fundamental. Have you got 15V going to each of the X- and Y-main boards?
      No4
        Vcc i have 15.30 to the x main and y main 15.30 v
          The fuses where the wire comes into the power board I get 0v ether end of both of them is that right ?
            That's bad. Can you test the same fuse on the Y-main?
              Yer changed them they get 202 in the y main
                I'm referring to the small little green fuse with leads each end, soldered into the board.
                  I'm on about the 2 proper like plug fuses
                    Yes can you check both types, maybe highlight voltages on a diagram.
                      But on the top green one 15.4v and on the bottom 0.02v
                        That's bad.
                          :s
                            Where I go from there the bin ha ha
                              Bad, I mean, the fuse is bad. Not that it's a bad thing. Finding blown fuses is good. Try replacing the fuse.
                                Ok ill try now
                                  Do they have to be like for like or can I upgrade
                                    Ideally like for like.
                                      I have a 1al 125v but the one in it is a 500mal 125v ? Can I temp try this
                                        That should be OK but be prepared to quickly pull power. Is a similar fuse on Y-main blown?
                                          It's on the y main lower fuse on the ymain
