Samsung le46b530p7w
  • sordids999
    • May 2013
    • 2149
    #81
    Re: Samsung le46b530p7w
    thats the thing tom today 6hrs before it failed now 5 mins then backlight goes off so now i have no time to heat it up to test
    • sordids999
      • May 2013
      • 2149
      #82
      @tom in the 5 mins that i have before it shut off i tried heating up the main board and it shuts down pretty quick
      • newtothis
        • Mar 2013
        • 1556
        • england
        #83
        Get a tube.. rolled cardboard or something similar and blow warm air down it in different areas of the board until you get the fault to occur faster again.... can start to close in on the faulty component
        • sordids999
          • May 2013
          • 2149
          #84
          ok so i got a empty toilet tube put it on the end of a hair dryer then heated the main board,the area ive ringed in red almost suddenly shuts the backlight down once i heated onto it tried it 3 times
          • sordids999
            • May 2013
            • 2149
            #85
            ok scratch that now i thought ill try it again heated the same area for a fourth time wont shut off now the backlight is staying on im confused now
              Please double check ON/OFF signal. If it is holding steady when it fails, then it cannot be main board fault.
              • sordids999
                • May 2013
                • 2149
                #87
                hi tom after heating up the main board the backlight was staying on last night,even when i got up this morning the backlight has not shut off as of yet
                • sordids999
                  • May 2013
                  • 2149
                  #88
                  tom should the heat sink be really hot after only 5 minutes of the tv being on ?
                    Yes. That is why it has a heatsink.
                    • sordids999
                      • May 2013
                      • 2149
                      #90
                      ok well i think ill keep this in the cuboard for a rainy day definitely temperamental this one been running fine most of the morning so decided to put the cover back on,so turned it back on cut out in 30 secs so turned it off then back on working again
                        It just sounds like something temp sensitive. Narrowing down the exact part may be tricky. Also have you tried turning off READY from the service menu?
                        • mmartell
                          • Oct 2013
                          • 3189
                          What is this Samsung "READY" option ?
                          • sordids999
                            • May 2013
                            • 2149
                            #93
                            i know i cant find it in the service menu either ?
                              What options do you have under CONTROL in service menu?
                              READY puts the set into a somewhat annoying auto-restart mode which is unpredictable.
                              • sordids999
                                • May 2013
                                • 2149
                                #95
                                EDID
                                SUB OPTION
                                PDP OPTION
                                HOTEL OPTION
                                SHOP OPTION
                                SOUND
                                CONFIG OPTION
                                TEST PATTERN
                                tom is there a way to set the contrast to 50 always on 100 in menu bright as hell I change it but resets back to 100 every time ?
                                  Sounds like SHOP is on. Try factory reset, when it restarts, make sure to select "Home mode".
                                  • sordids999
                                    • May 2013
                                    • 2149
                                    #97
                                    Its already in home mode and already done a factory restart just very strange the other setting like brightness etc is at 55 but contrast is 100
                                      Is it on Dynamic, Standard, or Movie mode?
                                      • sordids999
                                        • May 2013
                                        • 2149
                                        #99
                                        Standard
                                        Backlight 8
                                        Contrast 95
                                        Brightness 45
                                        Sharpness 50
                                        Colour 50
                                        Movie
                                        Backlight 6
                                        Contrast 95
                                        Brightness 45
                                        Sharpness 20
                                        Colour 50
                                        Dynamic
                                        Backlight 10
                                        Contrast 45 was 95 but I changed it
                                        Brightness 45
                                        Sharpness 55
                                        Colour 55
                                        • sordids999
                                          • May 2013
                                          • 2149
                                          #100
                                          Opps on dynamic at the moment
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • arbitarytwist
                                            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                            by arbitarytwist
                                            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                            03-01-2025, 01:16 PM
