Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
  • JunkmanJimbo
    • Mar 2017
    • 200
    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
    No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
    Please help. Thanks in advance!
  • nomoresonys
    • 12370
    • U.S.
    Had one of these models that did the same thing, a replacement mainboard fixed it.
    • JunkmanJimbo
      • Mar 2017
      • 200
      Thank you for the quick reply nomoresonys. I will get a mainboard ordered. Thanks again!!!
      • EazyBone
        • Jun 2023
        • 1438
        • United states
        • Anything I can do with my hands
        If you turn it on and leave it for like 20-30 minutes some Samsungs will show a Samsung logo move across the screen like the old direct TV used to be. Told me it was main board before. Mine was a older QLED that did that.
        • lotas
          • Jan 2016
          • 5398
          • Russia
          Problem with eMMC.
          • frannyjunk
            Hisense 40H4F no backlight but turns off after splash screen
            by frannyjunk
            So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
            TIA.
            09-24-2025, 10:59 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • odie34
            TCL 55S451 Stuck on Logo Screen But Working Otherwise
            by odie34
            I have a TCL 55S451 that's stuck on the logo screen. I've done all of the traditional troubleshooting steps (power cycling, holding the reset button, etc.), but nothing has worked. I thought the main board was dead, but then I realized that even though it was only showing the logo screen, it appeared to be responding to remote buttons.
            So I pressed the reset button again and used the remote to put the TV into screen reader mode. I was then able to navigate through the setup menus (including successfully connecting to the internet) in order to update the firmware. I thought that that...
            04-25-2026, 03:40 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • Cardinal Fang
            Aixun T3A screen flashes every 11 minutes when switched off! (?)
            by Cardinal Fang
            If the unit is left powered ON and allowed to go to sleep, everything is fine. But if the power switch is off, every 11 minutes the screen flashes solid white for about 1/10 second.
            There is no voltage leaking through the power switch when it's off. What the heck is going on here?
            Using 1.31 firmware, I have not tried others; I'm not really a fan of the idea that I should install a proprietary piece of software just to put a file onto a USB device.
            01-08-2026, 07:27 AM
