Samsung le46b530p7w
  • sordids999
    • May 2013
    • 2149
    #41
    Re: Samsung le46b530p7w
    sorry 0.09
      OK, it looks like we've been chasing a wild goose. I should have asked you for that measurement before.
      Check the pin 23 inverter on/off is staying HIGH from main board (connector going between main & power.)
      • sordids999
        • May 2013
        • 2149
        #43
        if ive read pin 23 right on the main board
        12.5 v
          That doesn't seem right -- it's probably the one right next to it. If it's a double row connector, maybe the one above it. See page #1 of schematic for the pin diagram.
          [SCH].pdf&mfg=Samsung
          • sordids999
            • May 2013
            • 2149
            #45
            your schematics hosting keeps timing out on me ? so ive upload some pics to see if that helps
            • sordids999
              • May 2013
              • 2149
              #46
              ok found it reading is 4.9 v
              • sordids999
                • May 2013
                • 2149
                #47
                could it be the main board then tom ?
                • sordids999
                  • May 2013
                  • 2149
                  #48
                  hi any more ideas on this problem getting close to scrapping this one
                  thanks
                    Try this, then:
                    http://www.toms-service-manuals.com/...df&mfg=Samsung
                    Had copied url wrong.
                    The BL ON signal is steady when it stops working?
                    • sordids999
                      • May 2013
                      • 2149
                      #50
                      tried again the backlight comes on when you first turn the tv on but after 5 mins it goes off again, i have to short PCI801 to get the backlight on again all voltages from the psu to main board seem steady even when the backlight switches off
                        So a brief short across PCI801S gets the backlight going, but what about a permanent short?
                        • sordids999
                          • May 2013
                          • 2149
                          #52
                          no tom a permanent short will not work tried that when i first turned on the tv no backlight had to remove the wire then the backlight comes on,then when it goes off i just touch PCI801S to get it going again
                          • sordids999
                            • May 2013
                            • 2149
                            #53
                            ok totally baffled now if i do a picture reset in the menu the tv is still working its been 30 mins now and counting
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              #54
                              Odd, I have an LED here that did the same... backlights kept shutting off... reset and works :S
                              • sordids999
                                • May 2013
                                • 2149
                                #55
                                opps spoke too soon picture gone well it lasted longer this time
                                  If you repeat the reset does it last again? Could be a coincidence.
                                  • sordids999
                                    • May 2013
                                    • 2149
                                    #57
                                    coincidence
                                      I've got another idea but will have to wait for tomorrow when I am more awake. Some error detect is firing. UVLO is one of them but there is also a few others that can cause this issue.
                                      • sordids999
                                        • May 2013
                                        • 2149
                                        #59
                                        ok thanks m8
                                          Just a thought before you go diving in checking things, have you inspected for cold joints and loose connectors?
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                          • Kiberge
                                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                                            by Kiberge
                                            HI guys!
                                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                            04-22-2024, 11:28 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • arbitarytwist
                                            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                            by arbitarytwist
                                            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                            03-01-2025, 01:16 PM
