vizio E320-A1 not working
    Re: vizio E320-A1 not working
    Did you read POST #56?
    Repeat again, look at your meter display, is it 96.3V OR 96.3mV? NO WAY IT CAN BE 96V without the TV blowing up.
    Bad DATA = Bad troubleshooting.
    Take the picture of your meter showing 96.3V.
    • lolaeng
      • May 2017
      • 23
      Yes, I did read that post. Hence, I tried to be as detailed and clear in my answer as possible. I do now have a photo of the multimeter at 96.3. You can also see in it that the meter is set on DC. It has only 4 settings. You will simply have to trust that the positive probe is on pin 12. All I need to know is how to upload the photo. I've no clue how to do it. Thanks.
      • vinceroger69
        • Mar 2012
        • 6714
        #63
        when you type a reply on the left at the bottom it says post quick reply on the right it says go advanced click on that then you will see a little paper clip icon click on that then browse/add your photo and then click upload
        • lolaeng
          • May 2017
          • 23
          Thanks vinceroger69.
            96.3mV ( or 0.963V) as I suspected as you can see on the screen of your meter. Not 96.3V!
            • lolaeng
              • May 2017
              • 23
              Having reread my posts I clearly did not claim it was 96.3V. (That to me is AC.) I set the dial to DCV & explained that I did not change the dial while testing all the pins. And I did not claim it was not mV as I have absolutely no clue what mV is. I didn't join this thread to be right or wrong, I came for help.
              As stated in my first post "From all that I've read I'm thinking my power card is working and the problem lies in my main board. Are there any DVs I can test on the main board to confirm it is the problem?" Or can anybody here confirm or tell me how to confirm that the main board is indeed the one that is broken? Thanks.
                Your Post #55:
                I took the readings again of the DCVs.
                Pin Off On
                1
                2 5.22 5.22
                3 5.22 5.22
                4 4.7 4.7
                5 24.6 24.6
                6 24.6 24.6
                7 GND
                8 GND
                9 GND
                10 12.37 12.3
                11 12.36 12.3
                12 96.3 47
                13 57.7 30
                So I am not going to argue with you at this point, we just want to get the correct DATA, bad DATA does not help. Always show what is being display on the meter.
                Your main board is not sending out the command signals.
                • lolaeng
                  • May 2017
                  • 23
                  Thank you.
                  • lolaeng
                    • May 2017
                    • 23
                    The main board seems to be out of stock everywhere I click. All that I can find is repair kits containing 4 eeproms.
                    Is there a way I can test the eeproms on the main board to determine if, indeed, one or all are the source of my problem?
                    • attainteddragon
                      • Apr 2013
                      • 764
                      • australia
                      #70
                      you can freeze the eeprom chips to normally get them to work if they are failing.
                      have you checked the voltage regulators?
                      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                      • lolaeng
                        • May 2017
                        • 23
                        Thank you, attainteddragon, for responding. I willingly admit I am not an electrician or anything related. I am a mathematician, a DYI type, and a person not afraid to do my own fixes.
                        I'm here to learn from you experts on this forum.
                        Freeze eeproms? How does one do that?
                        How do I check the voltage regulators and where are they?
                        Thank you!!!!!
                        • attainteddragon
                          • Apr 2013
                          • 764
                          • australia
                          #72
                          i am only a hobbyist, just one that spends way too much time playing with these things. bud is the true pro here. i'm always learning something from him.
                          i have marked out your regulators, but there could be others under the metal cover or underneath on the under side of the board.
                          there is probably only one that has any voltage on it at this point, but we need to know.
                          list your findings with the top row of writing on each ic and board placement, then measure from the side that has the 3 legs from left to right. make sure you list if it is v or mv. vital information.
                          eg.
                          ic 201
                          dg117-adj
                          1.25v
                          2.46v
                          5.01v
                          the easiest way to freeze a component is just with a can of air duster, turn it upside down and spray the component. wait a few seconds and hit it again. it will literally freeze as you are hitting it with a refrigerant. always a several seconds for it to truly freeze the component internally.
                            "How do I check the voltage regulators"
                            https://www.badcaps.net/forum/showth...999#post300999
                            • jetadm123
                              • 2169
                              #74
                              If "freezing" the eeproms doesn't work, try heating them up with a hair dryer. I've seen it work both ways.
                              • lolaeng
                                • May 2017
                                • 23
                                I have to use a magnifying glass to see these tiny things so I already pulled the main board off the back of the TV & probably, therefore, I won't get any kind of volts. A lot of what you guys are offering is going over my head. I'm trying to learn and trouble shoot for myself as Vizio was totally useless. They want me to buy a new Vizio; this one didn't last a full 4 years.
                                Those items you circled, attainteddragon, look like items Tampatec tried to show how to test in his youtube "How to check fuses, diodes, transistors, voltage regulators." If yes then can I test these using other settings on my multimeter? Starting from the top right ics that you circled and moving counter clockwise, the 1st is U702, then U703, then U701, and the last on the bottom is U102. Using the + and 1 probes can I find the culprit?
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  #76
                                  You will need to reinstall board and test under power. The eeprom looks to be 8 pin ic just above the metal shield with the white dot. It probably has a 24 or 25 in part number. Freeze it and then try to turn on tv
                                  • lolaeng
                                    • May 2017
                                    • 23
                                    Any suggestions where to purchase a can of freezing spray? A local type store rather than over the internet?
                                      You can use canned air duster up side down as cooling spray. That is what I use.
                                      • lolaeng
                                        • May 2017
                                        • 23
                                        Thanks, budm, I'll give mine a try.
                                        • attainteddragon
                                          • Apr 2013
                                          • 764
                                          • australia
                                          #80
                                          you have to test regulators with power applied as they normally tend to go slightly out of tolerance.
                                          • u666sa
                                            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                            by u666sa
                                            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                            Platform: ipa32 la-m024p rev 1b
                                            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                            I found a short on the other side:
                                            10-04-2025, 05:03 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • supermattch
                                            HP 15dy-2021nr wont power on mystery volts
                                            by supermattch
                                            Hi everyone.
                                            I am diagnosing my personal laptop, because it wont power on and no leds light up.
                                            At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                                            Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                                            09-23-2025, 12:13 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
