PS5 digital / No Power / No Beep / Good power supply
  • MisterAIL
    • Oct 2021
    • 10
    • France
    Brought a non functionnal PS5. Apparently only a bad PSU...
    No beep, nothing.
    After some tests i found this :
    - PSU is fine (12 volts stable)
    - 12 volts line is shorted
    - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
    - By the way, nothing change. No signal, no power, no beep.
    Mesuring all rails with my workbench psu (12 volts input)
    - 0.00 amp drawing
    - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is job)
    - 3,3 volts, 1,8 volts aren't there.
    Mesuring resistance to ground for these faulty rails
    3,3 volts => 35Kohms / 0.445 volts in diode mode
    1,8 volts => 200 ohms / 0,228 volts drop (diode)
    0,8 volts (D9081 output) => 77 ohms / 0,100 volts (diode)
    I don't understand why 3,3 volts isn't generated, 02V PMIC is good, 5v input is present, but 3,3 volts isn't, like 1,8 volt
    Trying to inject voltage on 1,8 volts line. I only have a 0,02A consumption at 1,8 volts, unable to warm nothing at all and finding faulty component.
    Any idea ?
    Some pictures joined.
    Thanks a lot for your help
  • drpc
    • Mar 2022
    • 20
    • spain
    Same problem here. Bios checked and same problem
    • u666sa
      HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
      by u666sa
      Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
      Platform: ipa32 la-m024p rev 1b
      Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
      I found a short on the other side:
      10-04-2025, 05:03 PM
    • Loretto
      Samsung SMPS BN44-00339A
      by Loretto
      this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
      I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
      I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
      I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
      03-29-2025, 08:30 AM
    • Loretto
      by Loretto
      03-28-2025, 10:28 AM
    • Mcfeetroy
      Fishing bite alarm drains battery
      by Mcfeetroy
      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
      08-01-2025, 03:52 AM
    • BretCraytor
      Sony SDR-DH540
      by BretCraytor
      Having issues troubleshooting a Sony SDR-DH540 with the thermistors. Following the service manual, the voltage at the digital board protector pin is ~0,06 volts, when it should be 0.6 volts. They suggest checking the thermistors, which both Thermistors register 4.7k ohms which makes me think they are bad. I suspect that they should read 470 ohms at room temp. Thus, it looks like they are bad. Am I right? Also, I can't find the actual replacement part from sony or the encompass parts web site as they just say no longer available for the sony part number 1-804-045-11 thermistor. And if I am...
      05-14-2026, 05:25 PM
