Bush LCD37TV016HD
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    #121
    Re: Bush LCD37TV016HD
    holding the probes together reads 00.2
    ok kettle lead is in switch is on
    black lead on negative on plug
    red on 1 then on 2 reading 00.4
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      #122
      we are testing in 200 ohms
      • Radio Fox
        • Jan 2010
        • 281
        Originally posted by selldoor
        This really doesnt seem to be making much sense. It is almost the same test as in 106/107...
        Unless the blue wire has come away from the switch tag hidden underneath the heat shrink!
        In your photo in post 118 the blue wire which you have marked "neg to board" could have become disconnected.
        LEEDASH...could you give that lead a tug to see if it moves. If it stretches the heatshrink then it looks like it may be disconnected from the switch.
        It could also be the blue connection to the plug that connects to the PSU board.
        ________________________________________________
        Invisible airwaves crackle with life
        Bright antennae bristle with the energy
        • selldoor
          Slow Learner
          • 7870
          #124
          Radio Fox - he does seem to get a reading though on both sides of the switch on the negative -post 121 IF he means 0.4 0n both. Of course we cant see and as you suggest it may be a loose wire - intermittent problem.
          Or intermittent bad switch connection.
          Lee - did you try tugging your meter leads whilst holding the probes together.
          We have had many cases of weird test results due to meter probe wires.
          If all that seems ok then I suggest you go back and try this test again-
          f you cannot find something to short out the pins on the mains plug, you could also try putting one probe on the Live pin of the mains plug, and the other probe on one of the pins on the connector that goes to the PSU. One of the pins (probably the one connected to the brown lead) should show zero Ohms when the rocker switch is in the ON position.
          Then put one probe on the Neutral pin on the mains plug and the other on one of the pins on the connector that goes to the PSU board. Again, one of the pins (probably the one connected to the blue lead) should show zero Ohms.
          Make sure the probe tips are cleaned
          • Radio Fox
            • Jan 2010
            • 281
            Radio Fox - he does seem to get a reading though on both sides of the switch on the negative -post 121...
            ...but that reading was directly on the tags of the switch.
            ...If all that seems ok then I suggest you go back and try this test again-
            LEEDASH has already done that. This was his reply to that same test that I suggested earlier:-
            Originally posted by LEEDASH
            Ok radio fox ! Blue wire showing nothing brown wire reading 00.8
            So it looks like the O/C is between the switch tag & the pin on the PSU connector.
            • selldoor
              Slow Learner
              • 7870
              #126
              I hope so - dont think i have ever seen 7 pages of posts just to establish
              voltage to the patient.
              • Radio Fox
                • Jan 2010
                • 281
                LOL. At least it should (hopefully) be an easy fix!
                • LEEDASH
                  • Dec 2012
                  • 481
                  • Bedfordshire
                  #128
                  So we have established that we are getting some kind of power in to the block connector that goes in to the psu,ok and we are getting power in to the on/off switch,so why is it not going in to the psu ? can i suggest the two pin may be at fault ?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #129
                    basically between the switch and the power board reading the last few posts
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      #130
                      yeah,mmm,its basically connected to the switch then straight through to the psu ? really bugging.
                      • Radio Fox
                        • Jan 2010
                        • 281
                        So we have established that we are getting some kind of power in to the block connector that goes in to the psu...
                        No we haven't!
                        When you did a test between the mains plug & both switch tags (blue wires), it measured OK.
                        When you did an earlier test between the mains plug & the blue pin on the connector that plugs into the PSU, it measured open circuit.
                        So there is an open circuit between the switch tag & the pin on the connector that connects to the PSU (in the blue lead).
                        Have you tried gently pulling on the blue leads to the connector and the switch? It is something really simple now.
                        • LEEDASH
                          • Dec 2012
                          • 481
                          • Bedfordshire
                          #132
                          ok testing with unit on ! neutral and on blue reading 00.4 and on live and on blue 0.00
                          • selldoor
                            Slow Learner
                            • 7870
                            #133
                            What on earth are you doing NEVER test resistance /OHMS with power on.
                            Surprised you didnt blow your meter. - perhaps you have.
                            PLEASE will you just do the wire tugging tests we are asking for - blue wire
                            and meter wires.
                            EDIT
                            Probably over reacted there - you mean with the switch on dont you - not the power.
                            • LEEDASH
                              • Dec 2012
                              • 481
                              • Bedfordshire
                              #134
                              not with the power on with the power switch in the on position,
                              • LEEDASH
                                • Dec 2012
                                • 481
                                • Bedfordshire
                                #135
                                the only way you get a reading is with meter on the neutral side of the plug and attached to the blue,no reading on live side.
                                Ive pulled wires on meter and near switch and block connector to psu.
                                  Where's your black probe going?
                                  • LEEDASH
                                    • Dec 2012
                                    • 481
                                    • Bedfordshire
                                    #137
                                    black probe on neutral side of the plug and the red on the blue wire under rocker switch,either way still reads 00.5
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #138
                                      You originally said that you had connectivity right through on the live side.
                                      Are you just having a laugh?
                                      And what happened - we are not mind readers - did the meter change
                                      did the blue wire move at all inside the shrink
                                      Can you roll back the shrink to expose the connection.
                                      • LEEDASH
                                        • Dec 2012
                                        • 481
                                        • Bedfordshire
                                        #139
                                        no just the neutral side and its 00.4 dont go up and dont down,can sort of roll it back the wire is soldered to the switch and seems ok.
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #140
                                          OK Meter on ohms 200 black probe on the pin in the board connector which connects to the blue wire.
                                          Red probe on the point marked 1 then on 2 in my picture of the switch (post 118)
                                          • jdawg99
                                            Bush DLED32287HDCNTDFVP - Is this a screen fault or a Tcon Issue
                                            by jdawg99
                                            Trying to fix a bush TV. The Tcon is integrated onto the main board by the looks of it but before I buy a replacement does this look like a screen fault? The lines at the bottom are concerning me. I have check for shorts on the caps etc and can't see anything obvious. Nothing is overly hot and I've tried heating different boards and pressing down on the flex but no change in picture.
                                            Any advice welcome. Thanks in advance....
                                            09-18-2022, 05:30 AM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
                                            ESR meter came to the rescue again today with a PLC I/O card fault
                                            by sam_sam_sam
                                            I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                            I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                            One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                            12-18-2023, 08:17 PM
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
