Bush DLED32287HDCNTDFVP - Is this a screen fault or a Tcon Issue
  • jdawg99
    • Sep 2022
    • 11
    • United Kingdom
    Trying to fix a bush TV. The Tcon is integrated onto the main board by the looks of it but before I buy a replacement does this look like a screen fault? The lines at the bottom are concerning me. I have check for shorts on the caps etc and can't see anything obvious. Nothing is overly hot and I've tried heating different boards and pressing down on the flex but no change in picture.
    Any advice welcome. Thanks in advance.
  • lotas
    • Jan 2016
    • 4854
    • Russia
    Re: Advise Please -Is this a screen fault or a Tcon Issue
    It looks like a panel (CKV signals), T-CON is built into the bar of the matrix itself.
    • Storyteller12
      • Jun 2020
      • 625
      Try the tape method. Sometimes in works on lg TVs with similar issues. It’s the panel on lg TVs
        • 12330
        • U.S.
        try turning the backlights down, see if it the double image lessens, looks like a gate driver issue. tape method as mentioned may work, it works on many double image issues.
        • jdawg99
          • Sep 2022
          • 11
          • United Kingdom
          Thanks for the replies guys, if the T-CON is built into the LED matrix bar then how do you do the tape trick. I have tried it from the main board on the ribbon going down without much luck.
            • 12330
            • U.S.
            Re: Bush DLED32287HDCNTDFVP - Is this a screen fault or a Tcon Issue
            did you try turning the backlights down? taping doesn't always work, try taping the ribbon cable end that's going to the driver board, sometimes you have to adjust how many pins are taped/blocked, maybe check the components on panel driver board, like the little ceramic caps, or bad diodes, can check the caps for shorts or very low ohms.
            • jdawg99
              • Sep 2022
              • 11
              • United Kingdom
              Yes I did but unfortunately it didn't make any difference. Tried the tape method and even cut some tracks but couldn't solve this one so it's gone to TV heaven. Thanks for the help though, much appreciated.
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • wizard13
                Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                by wizard13
                I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                I have checked the forum and the available documentation but could not find a solution specific to my issue.
                • Brand & Model: Dynabook Satellite Pro C50D-B-100
                • Part Number (P/N): PYU13E-00C00PFR
                • Serial Number (S/N): 22028896H
                • System Configuration (SC): A1PYU13E1127
                • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                • Power Input: DC 19V –
                02-28-2025, 02:43 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • cloudy
                HELP - Contrast/brightness issue with subtitles on screen
                by cloudy
                Hi everybody
                Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                It occours both on ubuntu and windows...
                01-01-2023, 05:12 PM
