ESR meter came to the rescue again today with a PLC I/O card fault
    • Jul 2011
    • 6063
    I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
    I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
    One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference
    The first thing I did was to remove I/O cable card off of the PLC still had the I/O card connector fault then I reinstalled the first cable and removed the second I/O cable connector and then the PLC booted up and the I/O fault went away so I checked for short to machine ground and found the wire that was shorted to machine ground starting from the I/O card cable connector and working backwards towards the valve location I did not have to go very far when I found a section of cable that the installation was worn to the wire on both cable wires and kept going because I still had the short to machine ground and after I went a few more feet of cable is when I found the cable was rubbing on a bracket that holds the hydraulic hose to hydraulic motor after giving the cable some slack and separate the wires from each other the short when away and the I/O fault was gone and no controller errors were noticed but by that time the other maintenance/ technicians had gone home for the day and my boss had also gone for the day as well and I had other duties that I had to get done before I could go home for the day
    They will run the machine tomorrow morning and see if there is anything else wrong with the machine which they will take care of because I do not know how to run these machines because they have not trained me how go into the machine controller menu and clear fault this will come in time
    • Jul 2011
    • 6063
    There are still issues with this machine but it is operational but the system has issues with the display screen being somewhat scrabbled on one line and another line some of the segments are not functioning properly either we are thinking that display card has some type malfunction so we are ordering some replacement cards
      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
      12-14-2023, 07:45 PM
    • chth96
      by chth96
      03-09-2024, 10:03 PM
      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-12-2024, 03:28 PM
    • CG2
      Janome DC3050 Sewing Machine Pedal Resistance
      by CG2
      OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
      Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
      04-14-2023, 07:53 AM
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
