phillips lcd keeps blowing fuse
+ More Options
Posts
  • Dannyx
    UC3842 Power Adapter Blowing Fuse
    by Dannyx
    Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
    Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
    12-05-2023, 12:06 PM
  • Tips
    Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
    by Tips
    Looking for some assistance please.
    Trying to repair a PD27AOQ samsung power board.
    Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
    Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
    Testing it the fuse blows immediately power is turned on.
    diodes dm852 and dm853 test as shorted when in the board but fine when removed.
    any assistance, guidance would be appreciated.
    04-11-2024, 11:24 AM
  • RogerH58
    Samsung 46" TV LE46B530 blowing fuse
    by RogerH58
    I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
    I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
    I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
    06-10-2023, 10:27 AM
  • corrize
    A funny fuse story – Lumix LX100 II
    by corrize
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
    10-19-2023, 09:58 AM
  • Bootleg1
    Samsung UN65KS9800FXZA T-con fuse blowing
    by Bootleg1
    Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
    02-04-2020, 01:05 AM
