Faulty Philips PSU (715g5246-p01-000-002s )
  • Mr_K
    • 106
    This PSU was pulled from a faulty 42" Philips LED TV.
    TV was not turning on. I was told that it has been damaged from lightning.
    Here is a Pic of MY PSU:
    For better view pls check out this page
    First of all i´d like to know why there are so many missing components (and heat sinks) on my board, especially on the primary side. The serial numbers match exactly.....
    Don´t mind the 5 missing FETs on the secondary side. I removed them for testing....They are fine.
    Here is what i found so far:
    Primary seems to be ok. On the output, there is no 5v standby voltage. The 12v rail has a short to ground.
    Any help appriciated
  • selldoor
    Slow Learner
    • 7870
    Re: Faulty Philips PSU (715g5246-p01-000-002s )
    Some members prefer it if pictures are posted using manage attachments
    which can be found in "Go Advanced" which is under quick reply.
    Also perhaps you could update your profile with country and mains voltage.
    I dont know the answer, Budm would know straight away, but depending where you live the board may not be configured with PFC booster circuit.
    • randtek
      • Oct 2011
      • 280
      • US
      Boards for these cheaper variety sets are often printed/drilled for multiple models and configurations. Seeing a board with many components not loaded is not uncommon, especially in lower end TVs.
      • Mr_K
        • 106
        That´s what i thought....
        And i´m from germany so mains voltage is 230V AC
        BTW: sorry i can´t edit the first post
        • selldoor
          Slow Learner
          • 7870
          Hmm well I would have thought Germany would definitely have pfc whereas the amazon probably not required.
            For an LED TV they might be able to get away with it (<150W) though it is very unusual, maybe it has been worked on before??
            • Mr_K
              • 106
              Originally posted by tom66
              ......maybe it has been worked on before??
              No, i dont´t think so. All the solder joints look very clean....like "out of factory"
              Maybe we should focus on my 12v problem.
                Have you owned it since new?
                • Mr_K
                  • 106
                  No, got it as faulty.
                    Can you supply a picture of the bottom of the board?
                    • Mr_K
                      • 106
                      Here are fresh ones with the best quality i can get:
                      I´ll upload an edited one in a sec....
                      I´v added the pinout for the connector. Blue FET´s are removed. Short from 12v to GND
                        OK, there is clearly no PFC circuit there, no control components... I was just concerned that part had to been removed!
                        It is normal for a winding to appear shorted as it is just a coil of wire wrapped around the transformer core. Are you saying there's a short beyond the coil?
                        • Mr_K
                          • 106
                          Oh, my bad. I didn´t mean they are shorted to each other. They are all shorted to ground. and the 12v output is shorted to ground. So yes, there must be a short beyond the coil.
                            With the diodes remove it's pretty common to real the coils shorted together -- they are tied to a common node, usually ground.
                            • Mr_K
                              • 106
                              Ok, and what about the 12v rail?
                                The 12V might power the LED boost converters at the top of the board. Is there any way to isolate these?
                                • lorins_core
                                  BlackSmith
                                  • Dec 2012
                                  • 551
                                  • Philippines
                                  Sir Would you Try to Check the Primary AC Input to PSU. the Check The Secondary Supply if Have Voltage Flow. then Check The Rectifier and The Capasitor Filter?
                                  • lorins_core
                                    BlackSmith
                                    • Dec 2012
                                    • 551
                                    • Philippines
                                    Sir i think. if this Component Destroy of Lightning Flux. hmmp. may be the 7 pin IC.
                                      If he is seeing a short on the secondary, it is not the TinySwitch/7pin IC
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        Hi - what is this- may be just a link or the picture, but it looks a bit odd.
                                        • lolich112
                                          GTX 1660 Ti: Missing GPU Details & Abnormal Behavior - Possible Faulty IC?
                                          by lolich112
                                          I've been encountering some perplexing issues with my ASUS ROG STRIX GTX 1660 Ti Gaming OC and am seeking insights or potential solutions from the community.
                                          Symptoms:
                                          Initially experienced a gradient-style black screen from the top.
                                          Poor performance: ~10 FPS on the lock screen.
                                          Encountered artifacts followed by black screens.
                                          After addressing a PSU-related problem, still observed a performance drop (~10 FPS).
                                          Upon using GPU-Z:
                                          Memory size shows as 0MB.
                                          Unknown bus width and bandwidth reported....
                                          10-27-2023, 06:17 AM
                                        • tony359
                                          Faulty CRT AKF12/Philips CM8500: bad flyback?
                                          by tony359
                                          I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                                          What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                                          There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                                          Can it be a short somewhere...
                                          08-22-2023, 04:39 PM
                                        • ein_individuum
                                          Missing Capacitator Intel I9-12900KF CPU
                                          by ein_individuum
                                          I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                                          I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                                          Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                                          Today, 01:36 AM
                                        • ugamazing
                                          820-02020 PPBUS_AON missing
                                          by ugamazing
                                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                          02-05-2025, 04:21 PM
                                        • jpreza
                                          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                          by jpreza
                                          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                          Looking at the card, it appears to be missing the following:
                                          1x 1.0uH inductor - orange square
                                          2x...
                                          11-01-2024, 10:54 PM
