Sharp LC-40LE810UN question
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sharp LC-40LE810UN question
    I was alone with my 4 year old daughter and didn't have time, but later today I will measure and take pictures.
    • tibimakai
      • Jan 2012
      • 3680
      OK, T-con is not receiving anything.
      Point
      #1= 5.555V
      #2= 13.04V
      #3= 13.04V
      #4= after like 10 sec. becomes 12.17V for a second and then drops toward 0V.
      #5= 0V(alternates between + and -)
      Here are the pictures:
      • olegi
        • 63
        Hi tibimakai,can you remove all cable from power supply lave only 110v ,apply PS_ON manually and see V on main caps.Post results.
        • tibimakai
          • Jan 2012
          • 3680
          Nothing happens.
          • tibimakai
            • Jan 2012
            • 3680
            I don't think this power supply is as simple as other TVs. This is probably has a smart power supply also, since the TV is a smart TV(kidding).
            I see an AC detect there, I guess that one has to receive some signal too, no?
            • olegi
              • 63
              Signal (PD-9)AC-det is output signal from Q7061 to detect it they use 3rd optocoupler PC7703
              • tibimakai
                • Jan 2012
                • 3680
                So, what should be the next step?
                • tibimakai
                  • Jan 2012
                  • 3680
                  OK, to bring back the attention I'm posting the measurements that I have at the PS connector.
                  So it takes a couple of seconds to turn on, as Olegi said like 10 sec.
                  When the TV is turned on, I have the right voltages(not sure about the PWR_POW at pin#12).
                  #1-2= 13.02V
                  #3-4= 13.02V
                  #5-6= 0V(GND)
                  #7-8= 0V(GND)
                  #9= 3.13V(AC_DET)
                  #10= 3.03V(PS_ON)
                  #11= 5.02V(STBY)
                  #12= 0.12V(PWR_POW)
                  When the blinking code comes up, the only voltage is left is the standby.
                  I know that the 400V is missing and that is most likely the problem of this TV.
                  I guess we have to look at the DAC002, am I right?
                  When the TV comes on the 168V drops to 155V and then back up to 168V when tghe code kicks in.
                  • olegi
                    • 63
                    You said that you have bought 2nd power supply .Do you have same reading on this connector ?When you have on pin #10= 3.03V(PS_ON) there has to be ~400V on main caps.Can you tell what is the voltage on C7961A ;C7962A for first 10 sec til you get error code?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      It was exactly the same as mine, so no reason to keep it. I will let you know about the voltages, now I'm at the beach.
                      • olegi
                        • 63
                        here is similar schematic
                        • tibimakai
                          • Jan 2012
                          • 3680
                          The voltages are 13.04V and 6.38V.
                          Thanks for the schematics, I will have to look at them.
                          • Mt.Man
                            • 53
                            Had a LC-40LE835U last week that uses the same power board. It also had a 2 long, 5 short error with no back lights coming on.
                            Turns out the panel was cracked. The TCON senses an voltage error on the panel and produces the 2 long, 5 short panel power error.
                            Try forcing on the TV, which should power up the back lights. On the TV touch pad, Press and hold Vol DN and Ch Up, while holding those press PWR. Do not release PWR till the icon LED lights steady then release the PWR button only but still hold the other 2. The back lights should come on.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Thank you, I will try it when I will be home, but I hope I don't have the same issue though.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Unfortunately it's not working this method, because as I plug it in it's already booting up by itself.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  DDA002C is not getting Vcc. I don't know how much it should be this voltage.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    The PS_ON is 3.03V that is normal? You guys are saying that it should be brought up to 5V?
                                    Last time when Olegi told me to try starting manually, I have applied 3.3V to PS_ON. I should try with 5V?
                                      That is more than enough to turn on the transistor to turn on an Optoisolator.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        What do you think that it should be the next step?
                                        The NCP1608 IC(8 pin) "makes" the 400V?
                                        To me it seems that the 400V is not turning on. Everything turns on, then when the code kicks in they are all gone.
                                        Unfortunately I have three TVs that are a pain in the axx to fix. Very soon I will have to take a look again at that shorted LG PS. Without the FETs there is no short(!!).
                                        I still have those two 22" LG and Samsung and that 24" Asus with the burned resistors.
                                        Not looking forward to these repairs.
                                        I will probably bug you guys with these devices. Sorry about that in advance.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          Can somebody please answer to my question?
                                          Holiday shopping is here and I need some money.
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
