Sharp LC-40LE810UN question
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sharp LC-40LE810UN question
    What should I do next? I don't see conventional VDOs on the mainboard to check.
    Since the replacement power supply acts the same way as the original board, I assume that it's not the power source is the problem.
    I don't understand why there is no voltage at the connector(only 4.7V stby).
    Special order mainboard at partstore is $155.
      You are not getting PSON so why did you replace the power supply? Sorry - missed this thread.
      • tibimakai
        • Jan 2012
        • 3680
        I got frustrated because sometimes I had voltages and sometimes were all gone.
        Hopefully they will take it back.
        • tibimakai
          • Jan 2012
          • 3680
          With the original board back in the TV, I have measured the voltages before the feedback kicks in.
          This is what I'm getting:
          Pin#--Designation---Volts
          1-----13.2V-------= 13.02V
          2-----13.2V-------= 13.03V
          3-----SGND-------= 0
          4-----SGND-------= 0
          5-----SGND-------= 0
          6-----SGND-------= 0
          7-----SGND-------= 0
          8-----SGND-------= 0
          9-----AC-DET-----= 3.12V
          10----PS-ON------= 3.03V
          11----BU5V-------= 5.017V
          12----PNL-POW---= 0.12V
          So, the mainboard it's OK too?
          When I turn on the TV there is a very-very tiny buzz.
          Can I measure the LED transformer outputs? They should be like 90V or more?
          • olegi
            • Jun 2012
            • 63
            Hi tibimakai. Do you still have this blinking code in front of tv, if it is yes what is the sequence.
            • tibimakai
              • Jan 2012
              • 3680
              2 slow and 5 fast.
              • olegi
                • Jun 2012
                • 63
                On your main board there is eprom (chip finish with 04) on the backside of the board You have to erase it (blank it).Inside this chip is store a lot errors . you can find this chip on picture on post 129 on the bottom .I had 52 " sharp same blinking code .After erase this
                chip ,tv is working again .Don't forget to hit factory settings. Hope this helps
                Post your results.
                • tibimakai
                  • Jan 2012
                  • 3680
                  How you do that, since the Tv doesn't turn on?
                  • olegi
                    • Jun 2012
                    • 63
                    You have to desolder this chip,erase it with eprom programmer and soldered back.You can use brand new chip too.
                      Does this chip also store firmware? I am trying to understand how it works if it is blank.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        I don't have a programmer.
                        • olegi
                          • Jun 2012
                          • 63
                          In this particular board you have tree eproms .First with firmware is on top side on the board (left side on heat sink on post 129 ic3401 if i see correct from picture) Second for settings (channels , brightness ...) it is 64kbit .
                          Third is it 4kbit .That chip you have to erase.For programmer go to google and search for ( 24c04 programmer )
                            Darn, they have to make it so complicated. Why can't they put a simple clear button to clear out the garbage from the chip, but then they cannot sell more TV, I guess.
                            • olegi
                              • Jun 2012
                              • 63
                              Consider your tv it is like computer.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I don't understand which IC I have to replace. No matter which one, it.doesn't look easy at all.
                                  Because then you need a microcontroller or some processor to erase the chip - which adds expense - and TVs are really slim margin so where-ever cost can be cut...
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Which one is that chip?
                                      ^Reply to budm on why there's no reset button not relevant to your problem.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I understand, but I'm having a hard time figuring out which one is that eeprom chip.
                                        • olegi
                                          • Jun 2012
                                          • 63
                                          Hi tibimakai, i check today and that chip is IC2004 and is it 24c02 not 24c04.You can find it on the back on the board in red circle .That was in my tv before i erased.Hope this helps.
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
