Sharp LC-40LE810UN question
  • olegi
    • 63
    Re: Sharp LC-40LE810UN question
    What did you do exactly?
    • tibimakai
      • Jan 2012
      • 3680
      I have placed the DMM probes to the LED DRV. pins and I have started it up, then I have touched the two pins on that opto and for a second the light bulb(I have a short circuit tester with a 100W bulb) turned on and then off. Then the V Led did not tun on. All this time the voltage haven't changed, stayed at 0.009V.
      • tibimakai
        • Jan 2012
        • 3680
        Ok, I'm back with the error code blinking.
        I had to replace the 3BS03LJG IC, I was lucky to have an extra one.
          any LED-ON signal or similar coming up?
          • tibimakai
            • Jan 2012
            • 3680
            No. I measure 0.009V at the LEDs. At one connector the voltages are positive and at the other are negative. I'm affraid to toch again the opto. It will take more then two weeks to get new ICs.
            • tibimakai
              • Jan 2012
              • 3680
              Do you mean on the bezel? If yes ,then yes the same as before two long and five short blinks.
              Should I take the LCD apart to check for bad LED?
              • Alohamora
                • Aug 2012
                • 37
                No. 2 long & 5 short is 12V panel power, i.e. t-con problem or LCD panel short.
                Disconnect both of the flat cables between the t-con and the panel, then power it on. What happens?
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have tried disconnecting each cable at a time from the T-con, with no change.
                  At this time I'm suspecting the LEDs in the panel.
                  I will take it apart.
                  Replacement power supply/inverter board didn't change anything(hopefully it was a good board from partstore), removing the EEPROM didn't change anything, there is only the LCD panel left.
                    I do not think it will be bad LED assemblies since there are at least two strings of LED and I doubt that both of them went bad at the same time. Iworked on LED backlights monitor last week and one of the pin on the connector for one of the sting was bent, the other string still lights up.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      What else can I try?
                      I'm becoming frustrated, I have three monitors(2 small TVs) and three TVs that I'm having a hard time fixing them.
                      42" LG shorted PS, 42" Philips 7422D/37 no power, 24" Asus w/blown components, 22" LG M2262, 22" Samsung w/mystery PWM chip.
                      • olegi
                        • 63
                        Last week I had same model 60" (two long 5 short). SHARP 60" has full 4 LED strings .Problem was Only 1 single led of one string. Tv was very hard to disassemble , because of the size (very fragile to ) Hope this helps.
                        Backlight diodes http://www.sharpsma.com/lighting/led...es/GM2BB45BMAC
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I will give it a try. Thank you.
                          I guess it would be very good if we could start the inverter to make sure that it starts, but I don't know how come last time blew that IC.
                          You are sure that that's the opto for that?
                            As you can see, there are two transformers that supply the power to the LED strings, one per string, It has to be some thing in that LED drive power supply whcih is common to both strings. Bothe transfoemrs primary are connected in series and driven by the the same set of MSOFETs Q7601A/7601A setup as a half bridge drive. Which IC that you blow when you short the Opto? U????
                            • tibimakai
                              • Jan 2012
                              • 3680
                              36BS03LJ.
                              It makes sense, since I'm not getting any increase in voltage at startup.
                                So what voltage do you at pin 19 and 16 of the DDA002? The one in the primary side that drives the 2 MOSFET's.
                                And what is the P/N of the Optos that you hsorted the pins?
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Opto :
                                  Cosmo
                                  1010
                                  817
                                  K12
                                  H
                                  Pin#16= 0.3-0.8V then drops when the code starts
                                  Pin#19= 0.46V
                                  It's not getting the Vcc.
                                  • Alohamora
                                    • Aug 2012
                                    • 37
                                    2 long, 5 short error rarely has anything to do with the backlights. If the power board is good, and you get the same error code with *both* cables between t-con and panel disconnected, that leaves the t-con board or LVDS cable.
                                    Bad backlights give 1 long, 1 short error code.
                                      Post 191 "Last week I had same model 60" (two long 5 short). SHARP 60" has full 4 LED strings .Problem was Only 1 single led of one string"
                                      Post 197 "2 long, 5 short error rarely has anything to do with the backlights. If the power board is good, and you get the same error code with *both* cables between t-con and panel disconnected, that leaves the t-con board or LVDS cable.
                                      Bad backlights give 1 long, 1 short error code"
                                      Which one is the correct one? Looks like I will have to download the service manual to find out.
                                      In the mean time, cam you leave the meter on pin16 and see if the VCC voltage even jumps up when you first turn on the TV, that way we can tell if it even try to turn on.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Tha is what I did and from 0.3V went to 0.8V and when the code came up went even more down, to 0.009V.
                                          So right now we are working on the replacement board that you installed because the old one will not always get the 5 and 12V output. And the voltage on the two large caps on primary side does not jump up to 400V either?
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
