Got a Dell 3007WFP with a broken screen not sure if anything else was wrong with it. Placed another lcd in it and this is what I got, any suggestions?
Dell 3007WFP Crazy Picture
Re: Dell 3007WFP Crazy Picture
The bonding between the flexible circuit board and the LCD panel is lifted! Not sure if you can press it back down and make it stay down. That will make Vertical lines on the screen.Never stop learning
Thanks bud and ben for your input. The before picture is the way the screen look when my company sold it. Our customer is returning the screen because they are getting the picture that's shown on the screen at the top of this post. When they returned it the after pictures show it's condition. With the finger prints that are clearly shown on the screen and the positioning showing directly over the 2 problem areas we are guessing that the installer damaged the flex boards during installation. The customer said he had a professional come out and he told him the screen had bad chips??? Shouldn't he have noticed the 2 areas that are circled?Comment
Hi I have a dell 3007 wtp if you switch it on it runs through the color cycle test fine, but when i connect to pc image is disstorted, its not cables or pc as i have test with a 3008 wtp
is it fixable ?Comment
We are not keen on double posts for the same problem pick a thread and stick to it. As you are not adding info to either thread edit the one your not using to say " Double post"
Then we need a picture of the problem before we can even guess
Use manage attachments jpg less than 3mb will upload okPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
by timelessHi,
I've been troubleshooting a Dell U2518 that produces no picture yet the backlight is turned on, the PSU produces 19v, It is detected over HDM and its firmware could be upgraded over USB. So to me the controller board and PSU seems (somewhat) functional.
There is however a ticking noise from the T-Con board to the left side of the RT6811 chip when power on (not when off). Also the RT6811 chip gets quite hot (cannot be touched for long) otherwise there is no physical sign of damage and everything around the board is neatly covered with plastics and does not show any...2 Photos-
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... - Loading...
