Dell 3007WFP Crazy Picture
  • Gadjet
    • Aug 2012
    • 248
    Got a Dell 3007WFP with a broken screen not sure if anything else was wrong with it. Placed another lcd in it and this is what I got, any suggestions?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Dell 3007WFP Crazy Picture
    If its not the screen itself, then the t-con is likely bad.
    However, bad capacitors or corrupted EEPROM on the mainboard could cause this too, but rarely.
    Muh-soggy-knee
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Was the new screen from another Dell 3007WFP or from something else? If from something else, it just may not be compatible even if the connector on the t-con fits.
      • Gadjet
        • Aug 2012
        • 248
        Ok can someone tell me if this could be the reason for the picture displayed above.
          The bonding between the flexible circuit board and the LCD panel is lifted! Not sure if you can press it back down and make it stay down. That will make Vertical lines on the screen.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Yep, that is definitely a problem!
            Muh-soggy-knee
            • Gadjet
              • Aug 2012
              • 248
              Thanks bud and ben for your input. The before picture is the way the screen look when my company sold it. Our customer is returning the screen because they are getting the picture that's shown on the screen at the top of this post. When they returned it the after pictures show it's condition. With the finger prints that are clearly shown on the screen and the positioning showing directly over the 2 problem areas we are guessing that the installer damaged the flex boards during installation. The customer said he had a professional come out and he told him the screen had bad chips??? Shouldn't he have noticed the 2 areas that are circled?
              • seanbarman
                • Jul 2014
                • 16
                • United Kingdom
                Hi I have a dell 3007 wtp if you switch it on it runs through the color cycle test fine, but when i connect to pc image is disstorted, its not cables or pc as i have test with a 3008 wtp
                is it fixable ?
                • selldoor
                  Slow Learner
                  • 7870
                  We are not keen on double posts for the same problem pick a thread and stick to it. As you are not adding info to either thread edit the one your not using to say " Double post"
                  Then we need a picture of the problem before we can even guess
                  Use manage attachments jpg less than 3mb will upload ok
                  • seanbarman
                    • Jul 2014
                    • 16
                    • United Kingdom
                    double post
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • Akhlz001
                      by Akhlz001
                      09-20-2025, 07:15 PM
                    • master3112
                      by master3112
                      07-29-2025, 01:55 PM
                    • timeless
                      Dell U2518 no picture
                      by timeless
                      I've been troubleshooting a Dell U2518 that produces no picture yet the backlight is turned on, the PSU produces 19v, It is detected over HDM and its firmware could be upgraded over USB. So to me the controller board and PSU seems (somewhat) functional.
                      There is however a ticking noise from the T-Con board to the left side of the RT6811 chip when power on (not when off). Also the RT6811 chip gets quite hot (cannot be touched for long) otherwise there is no physical sign of damage and everything around the board is neatly covered with plastics and does not show any...
                      04-14-2024, 08:30 AM
                      Dell Thunderbolt Firmware
                      by SMDFlea
                      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                      The SKU is in brackets (****)
                      EDIT: NVM65...
                      01-26-2025, 06:22 AM
