Dell U2518 no picture
  • timeless
    • Apr 2024
    • Netherlands
    I've been troubleshooting a Dell U2518 that produces no picture yet the backlight is turned on, the PSU produces 19v, It is detected over HDM and its firmware could be upgraded over USB. So to me the controller board and PSU seems (somewhat) functional.
    There is however a ticking noise from the T-Con board to the left side of the RT6811 chip when power on (not when off). Also the RT6811 chip gets quite hot (cannot be touched for long) otherwise there is no physical sign of damage and everything around the board is neatly covered with plastics and does not show any sign being shorted. The VDD of the T-Con board measures 10v, as I don't have the schematics I cannot say for sure if this is normal but the other test pads with a voltage printed next to them like VCC_3.3, VCC_1.2 and such measure correctly. As the T-Con board is divided into 2 separate boards connected with a flex cable, I tried to disconnect the flex cable and hopefully identify that part of the screen to be at fault. But this did not help and as the T-Con board is bonded to the screen I have no way unplugging the other part.
    To me it seems very likely to be a panel problem, but I'm curious if there might be other suggestions I could try.
    Thanks in advance.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8150
    Probe the LVDS signals with an 100MHZ or better oscilloscope and change the menu OSD all the time, or give some input like a YouTube vid. If the signals change, it's the tcon. Pretty much this is a lost cause, because of the welded tab bonds. A shorted panel can be unshorted, but I don’t recommend doing this, unless you know exactly what you are doing.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Garret Matt.
      DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
      by Garret Matt.
      I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
      Thank you in advance for any assistance you can render.
      Inductor In question. Buzzes like...
      06-20-2025, 01:21 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • layad
      Dell Precision 3591 with board number 223092-1
      by layad
      I’m repairing a Dell Precision 3591 with board number 223092-1.
      I need a full BIOS dump (W25Q16 and W25Q512 if available), clean and bootable.
      The original chips could not back it up as i used 3,3v instead of 1.8v programmer which ,killed the chip
      bought new empty chip
      the reason was to remove the bios password
      Any working dump (from working unit) will help
      is there anyway to rebuild one from scratch?
      Dell Precision 3591
      motherboard 223092-1
      st 75nbp54
      is there boot guard in Dell Precision 3591 with board number 223092-1 , which stored...
      07-28-2025, 09:37 AM
