Philips 52PFL5704D/F7 Sound and Backlight, No Video.
  • dejo87
    • Jul 2013
    • 22
    Re: Philips 52PFL5704D/F7 Sound and Backlight, No Video.
    TV has been working great for me now, not sure what caused the streaking issue.
    • sammy76
      • Mar 2013
      • 25
      • usa
      #142
      ok update time. after doing the acetone soak the tv worked great for about two weeks. then out of nowhere it showed the same symptoms when i tried turning it on. took apart again soaked in acetone replaced and worked great, for about an hour then vertical lines everywhere and when turned off and back on no pic. seems like a weak solder joint somewhere that breaks when heated up. so would the tcon cause the vertical lines?
      • dejo87
        • Jul 2013
        • 22
        Mine did that too, been working fine since I took off the shield and thermal pads (take the thick gray pad and cut it down so it just barely covers the one small chip on the back of the tcon board, and slice it in about half thickness-wise) and zip tied a 120mm computer case fan to the tcon board area and plugged it into an empty spot on the power supply. Watch out for the tcon ribbons when you zip tie the fan down.
        • dejo87
          • Jul 2013
          • 22
          Be sure you clean it again though, alcohol will work too
          • dejo87
            • Jul 2013
            • 22
            Also, I believe the motion/scene blending problem on digital stations I described before was a firmware glitch when Noise Reduction is turned off, try turning it on and possibly off again to fix it, I just left it on.
              Noise reduction on many sets I have found causes motion blurring, due to the filter used. I don't really recommend it unless an analog source you're using is extremely noisy, don't use it at all on digital sources (MPEG NR may help but not by much...)
              • dejo87
                • Jul 2013
                • 22
                It's not a blurring, I'll post a video of it when I get home, if I can get it to happen again. Pretty trippy effect.
                • dejo87
                  • Jul 2013
                  • 22
                  http://www.youtube.com/watch?v=VgJnO8kigmo
                  • sepp256
                    • Nov 2013
                    • uk
                    #149
                    Hi, I am trying to diagnose my T-con board. So far I have found that the fuse labeled XD is open. Is there a way to test other components or are there other components that commonly fail? Or should I replace the fuse first and then go from there?
                    The input voltage to IC201 is 0V when the TV is on. Would that be powered by the XD fuse, or does it's power come from a different source?
                    • gamethriller
                      • Oct 2014
                      • 153
                      Originally posted by tibimakai
                      Both
                      Hey whats up bro.... lol maybe you can help me threw skype. Lol
                      • gamethriller
                        • Oct 2014
                        • 153
                        Heads up ..... cleaning the gook on the bottom of the t-con, fixed the problem. Thanks for the forum this place is great.
                        • ahardb0dy
                          • Jan 2015
                          • 24
                          Hello all, Just received one of these TV's today, my old boss gave it to me to see if I could get it working, he said I could have it. it's a Philips 52PFL5704D/F7
                          Can anyone post a pic of what each part is when you remove the back panel? I hear everyone talking about different parts but don't know which is which.
                          Right now the tv's back light is on and I get sound but nothing else,
                          • capkid
                            • Oct 2010
                            • 1339
                            The small board in the pics (t-con) is the problem child: https://www.badcaps.net/forum/showpo...&postcount=128
                            Large tan board on the left: Power supply
                            Large board with accessory inputs on the right: Main board
                            Long vertical boards on outer edges: Inverters
                            TV repair library: https://www.badcaps.net/forum/showthread.php?t=25836
                            LG Plasma Mal-Discharge Correction Service
                            • ahardb0dy
                              • Jan 2015
                              • 24
                              Thanks so the T-con board is the one in the center, right?
                              • capkid
                                • Oct 2010
                                • 1339
                                Yes, it's the small board in the center near the top of the screen.
                                • ahardb0dy
                                  • Jan 2015
                                  • 24
                                  Thanks, going to take the rear panel off tomorrow and have a look.
                                  • ahardb0dy
                                    • Jan 2015
                                    • 24
                                    Removed the rear panel, removed the T-con board, cleaned it, let it dry, re-installed it, nothing, pressed on the ribbon connectors on the top of the board and got something on the screen, lines, than one side was white the other was black, now nothing.
                                    • ahardb0dy
                                      • Jan 2015
                                      • 24
                                      Just went out and plugged the power cord back in, TV came on half the screen bright white, the other half like grey and black horizontal lines, than one side was multi color vertical lines other side was white, when ever I touch the socket (s) where the ribbon cables plug in ( top of the T- con board) the screen changes colors but still no picture.
                                      Question, I unplugged both connectors on the bottom of the T-con board and the screen stayed the same with the lines, what might that mean?
                                      • ahardb0dy
                                        • Jan 2015
                                        • 24
                                        any tricks to make sure the ribbon cables are connected properly?
                                        • ahardb0dy
                                          • Jan 2015
                                          • 24
                                          Today's update:
                                          Determined I didn't have the ribbon connectors seated properly, the small tabs on each side I had above the socket, noticed they need to be in the socket, got the cables seated correctly and I now have a picture, well almost a full picture,
                                          About 12" on the left side is still scrambled, can see the picture through the lines but not clear like the rest of the picture is.
                                          Any idea on that? Going to try re-cleaning the ends of the ribbon cables with alcohol in a few than will try it again.
                                          • Max514
                                            Samsung UN55H8000 sound but no backlight no video
                                            by Max514
                                            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                            • Unplugging the main board cable at the power supply >>> backlights came on.
                                            • BLU_ON signal from the
                                            04-14-2022, 10:34 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • bohaboha
                                            PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
                                            by bohaboha
                                            when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
                                            Do I disconnect the plug from the power supply, no backlight
                                            Thought the backlight would light up when you remove the plug from the power supply but no
                                            What could be wrong if both halves work separately?​...
                                            03-07-2025, 09:45 AM
                                          • gl4709
                                            Samsung un55cu7000d with backlight and sound No Video / Picture
                                            by gl4709
                                            I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                                            01-23-2025, 06:21 PM
