Samsung un55cu7000d with backlight and sound No Video / Picture
  • gl4709
    • Jan 2025
    I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
  • EazyBone
    • Jun 2023
    • 1363
    • United states
    Google fixing TV with tape,try that if it works then main board won't help you. Or take a pic of full back and then close up of main board, sometimes there's a way to test
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Mgiffune
      by Mgiffune
      06-09-2024, 10:28 AM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • jchang
      Samsung UN70NU6900F no picture and no sound
      by jchang
      Hi all
      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
      Symptom:
      No picture no sound.
      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
      No sound at all.
      What I tried:
      1. I tried unplugging the left or right ribbon...
      01-09-2023, 06:28 PM
    • marekk
      Samsung QE55Q67RAT no sound and bad picture when streaming
      by marekk
      I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
      I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
      Mainboard is based on pcb BN41-02695A BN94-14007B
      I will appreciate any help
      Many thanks
      Marek...
      05-29-2025, 02:23 AM
