Samsung UN55H8000 sound but no backlight no video
  • Max514
    • Apr 2022
    Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
    The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
    I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
    • Unplugging the main board cable at the power supply >>> backlights came on.
    • BLU_ON signal from the main board >> 3.5V
    • The tcon board only had two out of three LEDs lit up >>> When disconnecting both ribbons to the panel, the third LED still did not light up.
    • Powering up the TV with only one side connected at a time >>> no backlight nor picture.
    At that point while I was performing the test it seems like my tcon fried (ceramic fuse) and would not start again (0 blue light). When turning the set on the backlight would light on but still no video.
    So I ordered a new one (hopping this was the faulty part anyway), replaced it and I am now back to square one with no video / no backlight.
    Thinking the issue comes from either the power supply board or the mainboard. Do you know how I could isolate the culprit here, since it looks like it's not a tcon issue? I read 12.86v on all the 13v outputs but not sure what to check now...
  • yokoono
    • Apr 2010
    • 510
    Re: Samsung UN55H8000 sound but no backlight no video
    The LED off the t-cone indicates that the t-cone is protected. You have a short circuit in the panel. Depending on the type of t-con, protection can be undone to determine which part of the panel is defective. Some TVs only turn on the image when both ribbons are connected. First of all, look for how to cancel the protection of the t-cone.
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • arctor
      samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
      by arctor
      hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
      04-26-2025, 05:22 AM
    • wolf1976
      samsung ue40d6100 has no backlight no sound and image
      by wolf1976
      hi to all
      on the above model of samsung i have the faults i have told already on the title
      iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
      any idea from someone what can i measure so i can find the problem ?
      the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
      11-17-2024, 01:02 PM
      09-07-2024, 05:50 AM
