Samsung LNT3242HX/XAA Power Supply Issue
  • kevinm34232
    • May 2012
    • 1884
    TV shows red standby LED, will not power on.
    After inspection of PS board, noticed high voltage blue cap CM810 leaked all over main filter cap CP803, and one leg was burnt off of the blue cap (B 222K 1KV). Also, nearby RM801 is open, and CP803 tested bad.
    Does it sound like the blue cap caused this? I have not found the value of RM801 in the SM I have either, I read somewhere that this is some type of fuse resistor?
  • kevinm34232
    • May 2012
    • 1884
    Re: Samsung LNT3242HX/XAA Power Supply Issue
    Is this correct list?
    • vinceroger69
      • Mar 2012
      • 6714
      this may help
      http://www.electro-tech-online.com/r...er-supply.html
      • selldoor
        Slow Learner
        • 7870
        Resistor appears to have Red Red silver gold bands, if that is correct then it is 0.22 ohms 5%. Hard to tell but if the casing was pale blue then it could have been fusible.
        Parts lists tend not to include the components on the power supply - I dont think you will find the other components listed either. A faulty big cap could have caused this if it went short however you will need to test other nearby parts QM802 and the one next to it.
        • kevinm34232
          • May 2012
          • 1884
          Im trying to check QM801 and QM802 (FQPF5N50C), I get 0.00ohms reading from G to S on both, .0L on all other combinations, does that mean anything?
            Out of circuit? Sounds like gate-source short. If you touched the leads of the transistor, you could have ESD-zapped them.
            • kevinm34232
              • May 2012
              • 1884
              Sorry this is in circuit right now, what readings should I expect between pins if good and bad?
                Gate source should read open or very high resistance.
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  FQPF5N50C have a high failiure rate on samsung power supplys.
                  rm801 is def a 0.22ohm ,and a fusable resistor.
                  out of curiosity have you checked the main bridge rectifier also?,i wondering if a shorted main filter cap has done this damage.
                  fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                  please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                  • senndogg
                    • Dec 2011
                    • 383
                    • Albania
                    i think you should do a list with the failed components. begin with the transistor, resistor, diodes etc. remember when this mosfet fails it takes several components after. in your case (gate-source short) the main IC may have gone.
                    btw, this psu is 70$ on ebay.
                    • kevinm34232
                      • May 2012
                      • 1884
                      I think G and S are pins 1 and 3, out of circuit is fine, but checking pads where pins 1 and 3 go into show no resistance.
                      I just ordered the main cap, the resistor and the high voltage cap, we'll see what happens.
                      • selldoor
                        Slow Learner
                        • 7870
                        rather than just " see what happens "I think you should wire a lamp across
                        the fuse - if there is still a short it may save your new parts burning out as it
                        gives you a little time to switch it all off.
                        • kevinm34232
                          • May 2012
                          • 1884
                          OK, can you elaborate on that? Just hook up wires of a lamp to each side of fuse? By the way initially when I checked voltage I had 120v at bridge rectifier, not sure if that means anything tho.
                          • selldoor
                            Slow Learner
                            • 7870
                            Didnt word that very well did I - I have seen it done like that but it should
                            really be as well as, not instead of the fuse. So you wire a 60 or100watt bulb into the live side of the mains lead. read about it here:
                            http://www.vintage-radio.com/projects/lamp-limiter.html
                            [QUOTE
                            By the way initially when I checked voltage I had 120v at bridge rectifier, not sure if that means anything tho.[/QUOTE]
                            Is that on the AC contacts? Usually the inner two)- what do you get on the DC contacts. ( Meter on DC - observe the polarity shown on the bridge)
                            • kevinm34232
                              • May 2012
                              • 1884
                              OK I've read about that before.. Are these sold anywhere premade?? It doesn't look hard to make but the time..
                              • selldoor
                                Slow Learner
                                • 7870
                                not that i know - heres a wiring across fuse contacts example
                                https://www.badcaps.net/forum/showth...lamp+bulb+fuse
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Replaced those 3 components (main cap CP803, high voltage cap CM810, and resistor RM801). TV Powers up now and is working!
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    Missed that last post somehow - well done- another one saved.
                                    • purduejay
                                      • Jun 2015
                                      Kevinm34232I'm having the same issue with the CM810. What is the parts numbers of the parts you used to replace CP803, CM810 and RM801?
                                      • Dangermouse1
                                        • Nov 2016
                                        • 3
                                        Hi. Joined just to ask you a question or two. Did that repair keep? Also, did you double check the components you removed to see if they were really dead/damaged?
                                        I ask because I opened up a LN3242HX and found a damaged RM801 (fusible .22 Ohm) with the gunk on it and the nearby caps, just like you reported. Unlike you though, I believe that gunk is the adhesive they add to... to ... well whatever reasons they have for gooping parts together. Reduce vibrations? The same goop was in a number of other places too. Just a little darker and a little crumbly around the RM801 because of heat damage (I think). I could be wrong, but the HV cap seems to be fine from what I can tell (tested in place with ESR meter). Since the gunk could only have come from the HV cap, which seems fine, I think it must be just adhesive.
                                        Obviously there should be some reason the fusible resistor blew... that's why I was hoping you could also report back on if the fix was stable since then.
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
                                        • lp20th
                                          Samsung Plasma TV Power Supply Issue
                                          by lp20th
                                          I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                          11-28-2023, 10:28 AM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • captainKKK
                                          Samsung Bn4400612b Power Supply issue on Samsung UN50F6300
                                          by captainKKK
                                          Samsung Bn4400612b Power Supply issue takes out a new 5A fuse on my Samsung UN50F6300, without any the BL or main board cables connected. Please advise if this board has known issues and fixes. There are no evident fried components and the caps look ok. Nothing unusal on the bottom side of the board under magnification. Is the ICM801CS under that heat sink a known issue? SJ (https://www.shopjimmy.com/samsung-bn...-1473373576096) out of stock, so component level repair may be my best shot. Thanks.
                                          02-17-2022, 08:59 PM
                                          09-07-2024, 05:50 AM
