Sharp LC-32SB24U
+ More Options
Posts
  • shorteddiode
    • 221
    Sharp LC-32SB24U
    The stand by light will flash 5 times which indicates a lamp problem. I removed and tested the 5 inverter transformers and they test fine. I pulled and tested the power mosfets Q7502 & Q 7504 ( J655) and tested with an analog meter. With the black on drain and red on source, touched the drain and gate and needle goes up to the top of the scale, stops and then drops about as fast as it went up. Am I safe in saying they are bad? The electrolytics have good ESR and do not show shorts
    The board number is RUNTKA448WJQ2. I have not tested the lamps, I can get a full picture at times for a second or two and it does not appear to have any dark spots, and I do not have a lamp tester. I can't find a service manual or a schematic, so if anyone has any ideas where I can find one or any ideas about the problem with the set I thank you in advance
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sharp LC-32SB24U
    You coud remove the screen and you can see if all the lamps turn on or not.
    I had a Sony recently, that had a ccfl problem and this is the way that I have found the bad tube.
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      you have a 2 seconds to black issue,could be caused by bad ccfls,inverter transformers,bad wiring to ccfls, etc test the secondary windings of all your inverter transformers ,compare the results of each one if one is out by a small margin then you got the culprit,retiredcaps has a write up about the problem i think ,find that and troubleshoot from there
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • selldoor
        Slow Learner
        • 7870
        I understand lc 32d44u is virtually the same set -have a look and see what you think
        • shorteddiode
          • 221
          All my inverter transformers test the same, used a ring tester on them. Thanks for the help and links
          • randtek
            • Oct 2011
            • 280
            • US
            Not sure where you got the info that a 5 blink error on this model is lamp error. Lamp error is a 1 blink per second steady blink. If Power LED is flashing "2", and OPC LED is flashing "5" it is a panel 5v failure. If only Power LED is flashing, and it is flashing "5" it is a "Monitor Temp Fail" on the main board.
            • shorteddiode
              • 221
              Found some CCFL's with black ends, if I measured right they are 30mm X 705MM. does that sound about right for a 32" sharp TV. Can't find a part number for them so do just order by size? Thanks guys
                You mean 3mm? not 30mm dia.?
                • shorteddiode
                  • 221
                  I guess I better double check,
                  I thought it was 3cm which converts to 30 mm,, right?? 10mm to a cm?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    http://www.lcdparts.net/CCFL13D.aspx
                    • shorteddiode
                      • 221
                      Thanks vinceroger69
                      • selldoor
                        Slow Learner
                        • 7870
                        Spot on ! BUT 3cm is about 1 inch!!!
                        You need to be exact as they come in 3 ,3.4 . 4 .mm
                        3 mm seems a bit thin for 32 inch
                          More likely to be 3.2 or 4mm Dia.
                          • shorteddiode
                            • 221
                            Guess I better break out the metric calipers, thanks guys.
                            • multimeter
                              • Jan 2011
                              • 739
                              • united kingdom
                              if i were you ,id measure the ccfls with a micrometer (digital) to be absolutley sure ,as others have said they come in .decimals of a mill so be carefull !
                              • shorteddiode
                                • 221
                                I checked it with the old manual analog calipers, it is exactly 4 32's wide which converts to 3mm, so I need 3mm X 705mm. I took my meds and my senior moment passed so I hope I have it right this time, lol. Now all I need is to find a good price for them.
                                Thanks guys
                                  That is small for 32"
                                  • shorteddiode
                                    • 221
                                    There are 10 of them in the set, I'll have to see if I can find a digital c aliper somewhere
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Did you try turning on the TV to see if they turn on or not? Those that are bad would not turn on anymore.
                                      I have purchased 3mm for the 40 Sony, though they were slightly small, maybe 3.4mm would have been the right diameter, but it still worked but did not pop in those plastic tabs. I had to add some glue to make it stay in place.
                                      There is a TV with broken screen on craigslist in LA for $30:
                                      http://losangeles.craigslist.org/sfv...992561113.html
                                      • shorteddiode
                                        • 221
                                        OK, have the digital calipers and the CCFL's measure 3.36mm.
                                        Do I round up and go for 3.4mm lamp?
                                        • Eric D.
                                          Sharp LC-60LE810UN Lamp error
                                          by Eric D.
                                          Hello everyone!
                                          I just acquired a Sharp Aquos for free.
                                          When I plug it in, it will try to power on, but it fails.
                                          The "error code" is 1 long flash, then 1 short flash, which suggests it is a lamp error code, according to the manuals.
                                          I did a bit of research and did what I found could be the possible issues;
                                          I removed the back panel, checked for continuity on both fuses where the power cable connects, and I get somewhere around 0.05. That should be good.
                                          I also tested the leads going into the psu board from the wall connector; I get 120V.
                                          I disconnected...
                                          01-18-2025, 05:14 PM
                                        • vestaviascott
                                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                          by vestaviascott
                                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                          Here's what happens:
                                          1) Power on
                                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                          3) Blue status light flashes for appx 4 minutes...
                                          07-29-2020, 06:08 AM
                                        • AJ847.63e
                                          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                          by AJ847.63e
                                          Hi All.
                                          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                          09-18-2023, 06:42 PM
                                        • mikey5791
                                          Tiny Tech ATX480W output power ticking
                                          by mikey5791
                                          Hi to all forum members,
                                          ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
                                          Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
                                          02-20-2025, 01:11 AM
                                        • Yanleb
                                          Sharp LC-60LE810UN Lamp Error
                                          by Yanleb
                                          I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                                          I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                                          Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                                          I've tried all the key...
                                          08-24-2021, 11:48 PM
