Sharp LC-32SB24U
    Sharp LC-32SB24U
    The stand by light will flash 5 times which indicates a lamp problem. I removed and tested the 5 inverter transformers and they test fine. I pulled and tested the power mosfets Q7502 & Q 7504 ( J655) and tested with an analog meter. With the black on drain and red on source, touched the drain and gate and needle goes up to the top of the scale, stops and then drops about as fast as it went up. Am I safe in saying they are bad? The electrolytics have good ESR and do not show shorts
    The board number is RUNTKA448WJQ2. I have not tested the lamps, I can get a full picture at times for a second or two and it does not appear to have any dark spots, and I do not have a lamp tester. I can't find a service manual or a schematic, so if anyone has any ideas where I can find one or any ideas about the problem with the set I thank you in advance
    Re: Sharp LC-32SB24U
    You coud remove the screen and you can see if all the lamps turn on or not.
    I had a Sony recently, that had a ccfl problem and this is the way that I have found the bad tube.
      you have a 2 seconds to black issue,could be caused by bad ccfls,inverter transformers,bad wiring to ccfls, etc test the secondary windings of all your inverter transformers ,compare the results of each one if one is out by a small margin then you got the culprit,retiredcaps has a write up about the problem i think ,find that and troubleshoot from there
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        I understand lc 32d44u is virtually the same set -have a look and see what you think
          All my inverter transformers test the same, used a ring tester on them. Thanks for the help and links
            Not sure where you got the info that a 5 blink error on this model is lamp error. Lamp error is a 1 blink per second steady blink. If Power LED is flashing "2", and OPC LED is flashing "5" it is a panel 5v failure. If only Power LED is flashing, and it is flashing "5" it is a "Monitor Temp Fail" on the main board.
              Found some CCFL's with black ends, if I measured right they are 30mm X 705MM. does that sound about right for a 32" sharp TV. Can't find a part number for them so do just order by size? Thanks guys
                You mean 3mm? not 30mm dia.?
                  I guess I better double check,
                  I thought it was 3cm which converts to 30 mm,, right?? 10mm to a cm?
                    http://www.lcdparts.net/CCFL13D.aspx
                      Thanks vinceroger69
                        Spot on ! BUT 3cm is about 1 inch!!!
                        You need to be exact as they come in 3 ,3.4 . 4 .mm
                        3 mm seems a bit thin for 32 inch
                          More likely to be 3.2 or 4mm Dia.
                            Guess I better break out the metric calipers, thanks guys.
                              if i were you ,id measure the ccfls with a micrometer (digital) to be absolutley sure ,as others have said they come in .decimals of a mill so be carefull !
                                I checked it with the old manual analog calipers, it is exactly 4 32's wide which converts to 3mm, so I need 3mm X 705mm. I took my meds and my senior moment passed so I hope I have it right this time, lol. Now all I need is to find a good price for them.
                                Thanks guys
                                  That is small for 32"
                                    There are 10 of them in the set, I'll have to see if I can find a digital c aliper somewhere
                                      Did you try turning on the TV to see if they turn on or not? Those that are bad would not turn on anymore.
                                      I have purchased 3mm for the 40 Sony, though they were slightly small, maybe 3.4mm would have been the right diameter, but it still worked but did not pop in those plastic tabs. I had to add some glue to make it stay in place.
                                      There is a TV with broken screen on craigslist in LA for $30:
                                      http://losangeles.craigslist.org/sfv...992561113.html
                                        OK, have the digital calipers and the CCFL's measure 3.36mm.
                                        Do I round up and go for 3.4mm lamp?
