Sharp LC-60LE810UN Lamp error
  • Eric D.
    • Jan 2025
    Hello everyone!
    I just acquired a Sharp Aquos for free.
    When I plug it in, it will try to power on, but it fails.
    The "error code" is 1 long flash, then 1 short flash, which suggests it is a lamp error code, according to the manuals.
    I did a bit of research and did what I found could be the possible issues;
    I removed the back panel, checked for continuity on both fuses where the power cable connects, and I get somewhere around 0.05. That should be good.
    I also tested the leads going into the psu board from the wall connector; I get 120V.
    I disconnected the cable from the main board to the psu board, it stops the blinking, but that obviously doesn't help (I just like to test things out in case there some weird shenanigans happening)
    I looked around, some people suggest Vol- Ch+ and Power, others suggests Vol- Input and Power, others suggests Vol- Ch- and Power, other suggests Vol- and Input.... I tried all of these combinations, while the TV is on, and also before plugging it in, it still refuses to power on.
    The woman who gave it to me says it was working fine the day before, then she came back from work, tried to power it on and it did that issue.
    I'm trying to see if it can be a board issue as those are pretty easy to replace and find, compared to LEDs over here. I cannot seem to find the TK4459P anywhere, but I can find the TK4458P...
    What could cause a TV to not want to go into the service mode?​
  • lotas
    • Jan 2016
    • 4879
    • Russia
    Your TV is blocked due to excess errors, the eeprom 24C02 is full of the lamp error error, erase it on the programmer (fill in FF FF...) and your TV will turn on, but you will need to eliminate this error (repair the backlight).
    • Superbee_dad
      • Jan 2025
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing green led.
      > I have 110 volts DC at the LED driver MOSFET and 192 DC volts at the L1 LED string input connection. I found a spec for the LED input voltage of 215 volts.
      > I removed the front panel and checked the LED strips with an LED backlight tester. I recorded 183 volts at each light strip and all LEDs light up bright. There are 15 rows with 21 to 24 LEDs per row.
      > I checked voltages at the FETS on the return circuit. The voltages at the collector pin were 36 volts DC (+ or - 1/2 volt) at every FET. There are 15 FETS, one for each light string.
      > This is where I found a peculiarity. I checked the voltage at the emitter of each FET and I also got 36 volts which I would expect … except for 4 FETS all beside each other had double or triple voltages. Three were 70 volts and one had 93 volts. I checked the gate voltages and they all are 5.5 volts except these 3 have 1.5 volts and is one has 18.4 volts. I removed the FETS from the board. There are 4 per heat sink so I removed 8.
      > I checked the FETS with a multi meter following an online transistor test procedure. They all checked the same … okay.
      Any ideas as to what is going on here and or what my next steps should be????
      Thank you in advance. All expert opinions are immensely appreciated.
      • Eric D.
        • Jan 2025
        Why are you using my post for your issues?
        • Superbee_dad
          • Jan 2025
          Sorry, it was my inexperience in using this forum. I was trying to make my first post and couldn’t find where to start. I was reading your post and only saw an area to post not realizing it was responding to yours. Then I couldn’t find out how to remove it.
          • Superbee_dad
            Sharp 80” long short flash backlight error - Help
            by Superbee_dad
            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
            01-24-2025, 11:51 PM
          • Yanleb
            Sharp LC-60LE810UN Lamp Error
            by Yanleb
            I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
            I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
            Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
            I've tried all the key...
            08-24-2021, 11:48 PM
          • u666sa
            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
            by u666sa
            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
            Platform: ipa32 la-m024p rev 1b
            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
            I found a short on the other side:
            10-04-2025, 05:03 PM
          • supermattch
            HP 15dy-2021nr wont power on mystery volts
            by supermattch
            Hi everyone.
            I am diagnosing my personal laptop, because it wont power on and no leds light up.
            At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
            Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
            09-23-2025, 12:13 PM
          • MisterAIL
            PS5 digital / No Power / No Beep / Good power supply
            by MisterAIL
            Brought a non functionnal PS5. Apparently only a bad PSU...
            No beep, nothing.
            After some tests i found this :
            - PSU is fine (12 volts stable)
            - 12 volts line is shorted
            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
            - By the way, nothing change. No signal, no power, no beep.
            Mesuring all rails with my workbench psu (12 volts input)
            - 0.00 amp drawing
            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
            03-12-2024, 03:24 PM
