BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
  • AJ847.63e
    • Aug 2020
    • 166
    • Africa
    Hi All.
    Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
    The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights red. I found the ZIF socket for the sensor was in the unlocked position so once I sorted that, confirmed the pins on the sensor and the socket itself was fine, and confirmed all the fans/airflow was ok I thought ah easy the ZIF socket was the issue. Nope! When I turned it on it ran fine for about an hour or so than same symptoms. Tried a few more times moving it to a different location to see if it was a fluke to no avail. But if I removed the clear plastic cover that sits on top of the lamp it would run indefinitely.
    I tore it down again and now it comes on for 30 seconds full fan spin red lamp light gives 3 beeps and shuts off. Checking the power to the light sensor I am getting 5v on the power pin but the colour wheel sensor detect signal is not dipping down like it should. I've been watching fix it frank on youtube and he mentioned the line should dip to 2.5 or 2.7 once the wheel fires but it constantly sits at 4.35V until the projector shuts off. Visual inspection returned nothing, all components visually look fine nothing corroded or burned. Traced both the power input from the PSU and the colour wheel connector and made sure there were no shorted components which there weren't.
    So I'm unsure whether I should be looking into the mainboard more or the ballast more. What are the bare minimum components so I can try to eliminate variables? If I disconnect the colour wheel should the projector stay on? If I disconnect the ballast should the projector stay on? Want to get back to bare basics so I can remove variables but I'm unsure what is required and what isn't.
    Thanks for the assistance.
  • kodox
    • Jul 2017
    • 322
    • Indonesia
    Re: BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not start
    have u watched this? https://www.youtube.com/watch?v=BG3ELt67vxM
    i think it had similiar issue
    • vestaviascott
      Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
      by vestaviascott
      Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
      Here's what happens:
      1) Power on
      2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
      3) Blue status light flashes for appx 4 minutes...
      07-29-2020, 06:08 AM
    • Grouickman
      Hofmann geodyna 6300 Wheel balancer
      by Grouickman
      Hi there,
      First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
      Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
      I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
      I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
      03-31-2025, 05:29 AM
    • Ven
      Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
      by Ven
      Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
      Issue Description:
      1. CPU Overheating to 100°C
        • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
        • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
        • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
        • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
        • Thermal
      02-12-2025, 03:57 PM
    • mikey5791
      Help on Samsung Syncmaster T220 dead ccfl lamp
      by mikey5791
      This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
      Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
      10-18-2020, 03:17 AM
    • khelane
      test active pfc power with lamp test
      by khelane
      Hello
      I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
      Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
      Is there a way...
      06-03-2025, 01:00 AM
