Sylvania LC320SS9 Flashing Green LED
  • Jerry7591
    • Aug 2011
    • 30
    Re: Sylvania LC320SS9 Flashing Green LED
    Did the same here today guys. awhhhhhhhhhhhh WHAT CAN THIS BE!!!!!!!!!!
    • heavymachines
      • Mar 2011
      • 1028
      best i could get camera sucks at best....
      • heavymachines
        • Mar 2011
        • 1028
        hey jerry you got a better camera to take pics with so budm can help us? my camera sucks i can see why budm has not replied and i don't blame him those pic's sucks....sorry budm i will see if a friend of mine has a better camera....
          Boy! There are lots of parts on the bottom of the board, a lot more than I expect.
          So right now, the backlights flashes on then go off?
          • Jerry7591
            • Aug 2011
            • 30
            I'll try to take some tom. Are there any surface mount fuses I am missing guys. Mine is a JVC LT 32em20 but they are the same. This ones got me nuts hahaha I got red light then when I try to pwr on two green flashes then back to red. All diodes are good out of circuit. the big ones on both boards. I checked all that were mentioned in posts. nothing. doing the double two step ass hole polka with this one.
              OK, I hope I can see focused pictures on the next post, in the mean time, lest check the condition of the 4 MOSFETS that drive the high voltage transformers.
              Just take the resistance reading between:
              1 & 2
              1 & 3
              2 & 3
              • Jerry7591
                • Aug 2011
                • 30
                My pics are just as bad guys. As far as mosfets.
                1+2=7.2 meg
                1+3=3.75meg
                2+3=2.165meg
                The others are the same.
                Thanks for all your help guys. This is a bad design.
                • Jerry7591
                  • Aug 2011
                  • 30
                  here u go. There terrible guys sorry
                  • Jerry7591
                    • Aug 2011
                    • 30
                    I took one more but it's still crappy. Next time I will put white in the background.
                    • heavymachines
                      • Mar 2011
                      • 1028
                      correct.....
                      • Jerry7591
                        • Aug 2011
                        • 30
                        no back lights here. 2 green flashes then back to red. Are there any surface mount fuses on t-con i am missing?
                        • heavymachines
                          • Mar 2011
                          • 1028
                          1 & 2
                          1 & 3
                          2 & 3
                          i tried to get resistance reading can't no matter the setting however i found this guide to test mosfet http://www.utm.edu/staff/leeb/mostest.htm and i found i can switch it on and off when desoldered from board ....weird thing is i did a resistance test on mosfet on a motherboard and i can get resistance readings so not sure whats up with that....
                          • XmouseX
                            • Aug 2011
                            • 158
                            • US
                            #53
                            What voltage are you guys getting on CN601 (the red and black power connector) while the TV is plugged in?
                            • heavymachines
                              • Mar 2011
                              • 1028
                              i get 175 volts at that connection
                              • heavymachines
                                • Mar 2011
                                • 1028
                                here is top view pic from shop jimmy nice and clear..working on bottom view
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  new pics hope you can work with this budm....
                                    Hate to say this, but pictures #1~3 (100-2059~1002061) are out of focus.
                                    There are 3 IC hsown on the first picture, do you have the P/N printed on them?
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      yeah different camera still sucks...
                                      ic starting from top
                                      ic#1.....87 a3 95km
                                      lm324
                                      ic#2 0z9926asn
                                      mb4334 2g
                                      0827c2
                                      ic#3 same as ic#1
                                      • heavymachines
                                        • Mar 2011
                                        • 1028
                                        ic#1.....87 a3 95km
                                        lm324
                                        ic#2 0z9926asn
                                        mb4334 2g
                                        0827c2
                                        ic#3 same as ic#1
                                        and ic # 1 and 3 are Texas Instruments parts
                                          LM324 is the Quad Op-amp.
                                          OZ9926 is the PWM IC made by O2 MICRO.
                                          I need to study its function first.
                                          • shelby5041
                                            clock radio / radio lifespan?
                                            by shelby5041
                                            hi
                                            ive got a modern digital clock radio approx 15yrs old
                                            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                            it uses very little power just a few watts i would imagine that may have something...
                                            09-14-2024, 03:30 AM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • beetle1303
                                            Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
                                            by beetle1303
                                            Sharp TV flashing green light 2x per second at constant rate. Various reset methods do not have any effect on it. Search here and found flashing green 2x per second indicate bad power supply, which I am quite certain now.
                                            I am seeking help with basic trouble shooting to find the short-circuit on the secondary side that I believe is the cause:
                                            The main PD connector:
                                            PD-1 (PNL12V) : 0.02V
                                            PD-2 (PNL12V) : 0.02V (fluctuating)
                                            PD-3 (SGRN) : 0V
                                            PD-4 (SGRN) : 0V
                                            PD-5 (UR13.2V) : 0.05V (fluctuating)
                                            PD-6 (UR13.2V) : 0.05V (fluctuating)...
                                            04-19-2022, 09:26 AM
                                          • UserXP
                                            Vintage SONY Digital Clock Radio ICF-C12W no audio
                                            by UserXP
                                            Dear all,
                                            I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                            i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                            My question is, do you know of this brand of capacitors and how bad are...
                                            07-21-2025, 08:35 AM
                                          • jimjoe123
                                            LCD TV Green/Pink screen problem
                                            by jimjoe123
                                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                            Then each time...
                                            02-23-2020, 01:29 AM
