Sylvania LC320SS9 Flashing Green LED
  • heavymachines
    • Mar 2011
    • 1028
    Re: Sylvania LC320SS9 Flashing Green LED
    Originally posted by Mr Bill
    Do all the transformers read 5.3 Mohm with your meter set to 20M?
    yep they do...
    • heavymachines
      • Mar 2011
      • 1028
      yep they do but it starts off at 12. something and stops at 7.6 m ohm soo? not 5.3 sorry
      • heavymachines
        • Mar 2011
        • 1028
        any ideas anybody? anybody had success fixing this poorly designed p.o.s?
        • Mr Bill
          • Nov 2011
          • 648
          If all 4 are reading roughly the same then they are probably good. Check the board and see if there are any cracked solder joints.
          • Jerry7591
            • Aug 2011
            • 30
            Hi guys! same problem with mine here. I'll keep checking things till I figure it out and re-post.
            • heavymachines
              • Mar 2011
              • 1028
              That would be great!!! will be very grateful, Having a heck to a time with it i will keep tinkering as well. Please do let me know what you find thanks...
              • heavymachines
                • Mar 2011
                • 1028
                any progress? thanks
                • Jerry7591
                  • Aug 2011
                  • 30
                  Nada Buddie. Still burning on it. Hope you got that Sharp going. My diodes are good on psu board. Thanks!
                  • heavymachines
                    • Mar 2011
                    • 1028
                    That's all right, the diodes are good on this one far as i can tell at this point, funny how all three tv's i am working on are putting up a fight about being repaired the sharp might be the easiest of the bunch. seiki second, but this beast has everyone miffed LOL.....including myself. I will try to keep working on it, here n there but first other 2 tv's Thanks alot fer the update.
                      OK
                      1) the transformer resistance reading, it will show real high resistance because you are reading the lamp terminals not at the transformer terminals, the blue ballast caps are connected between the transformer output winding and the lamp, the cap is an open circuit device, you need to read at the transformer's terminals.
                      2) Do get DC reading on the Cathode side of the three Diode you replace? Black probe on the chassis, red probe on the Banded (Cathode) side of the Diode.
                      3) You need to check the sub-power supply on the main board also, you can see a bunch of black body diodes by the switching transformer.
                      • heavymachines
                        • Mar 2011
                        • 1028
                        the three diodes are fine in this set unsoldered and tested and shows readings one way and not the other all three of them...at the ccfl connectors, only way i can get a reading is set my dmm to 20m ohms and readings are starting from top transformer 1 to 5 5 being bottom
                        1. 9.0
                        2. 7.89
                        3. 6.5
                        4. 8.9
                        5. 5.65
                        thing is it never stays put it has fluctuations from 15.0 to 5.6 all over on pretty much all 5... its weird....but that's pretty low resistance anyhow.
                        • heavymachines
                          • Mar 2011
                          • 1028
                          i only have 4 diodes that read both ways on who knows what board you call it not the inverter circuit but the power board i would imagine.
                          • heavymachines
                            • Mar 2011
                            • 1028
                            budm ?
                            • Mr Bill
                              • Nov 2011
                              • 648
                              What are the locations on the board? I have the power/inverter board in my basement and i can see if i get the same results. Was this in circuit or removed?
                                The big board to the right of the inverter board as shown in Bill post 1, it has Tuner and input jacks on that board, as you can see, it is sub- power supply/Main board. You can see a yellow transformer and a bunch of Diodes, If any one of them read both ways, then you should lift one leg off the board and take reading again, common Diode failure on this board also, beside the bad inverter/power board.
                                Unless your TV is not the same as shown by Bill.
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  its exactly same tv as bill same goofy design i will lift legs and retest em, but the difference in the symptom is only that mine will show digital tv logo briefly before it turns off and flashes the green led, i think it may be bad ccfl, i tried to simulate bulbs with a resistor to see if it would stay on longer and it did kinda, still not sure.... but thanks for your help and patience...
                                  • Jerry7591
                                    • Aug 2011
                                    • 30
                                    heavy,bill,bud> Still making no headway with this poor design. Following you guys for direction. I get a couple green blinks and can hear H.V shut down on secondary power board at transformer. This one is driving me nuts. It's got to be something simple. This T.V looks like it's new inside. We'll get her. Thanks guys for all info,and posts
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      okay update tested all diodes on inverter board and all tested good, checked the bulbs are ok they light up, does have signs of age but still good and its the u type... now checking power/tuner board will report back....
                                      • heavymachines
                                        • Mar 2011
                                        • 1028
                                        okay another update tested all diodes on all boards and the ones that read both ways i desoldered and retested and it tested fine when leg lifted. however one tested short and lifted leg and it tested fine so i will keep that one in mind and even thou when the bulbs lit up for two seconds were nice and bright and not dead like it was in the sharp tv that we fixed, thou there are beginnings of black rings where the connector is but i doubt thats the problem...so there is something else wrong with this set any ideas where to check next?
                                        also it took me good portion of the day to test these crazy amounts of diodes on this set. and all solder joints are good.....
                                          Can I get good pictures of both sides of the inverter board, the whole board both sides, then 1/4 shot of board (both sides) so I can see the traces to figure out how it works.
                                          • shelby5041
                                            clock radio / radio lifespan?
                                            by shelby5041
                                            hi
                                            ive got a modern digital clock radio approx 15yrs old
                                            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                            it uses very little power just a few watts i would imagine that may have something...
                                            09-14-2024, 03:30 AM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • jimjoe123
                                            LCD TV Green/Pink screen problem
                                            by jimjoe123
                                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                            Then each time...
                                            02-23-2020, 01:29 AM
                                          • beetle1303
                                            Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
                                            by beetle1303
                                            Sharp TV flashing green light 2x per second at constant rate. Various reset methods do not have any effect on it. Search here and found flashing green 2x per second indicate bad power supply, which I am quite certain now.
                                            I am seeking help with basic trouble shooting to find the short-circuit on the secondary side that I believe is the cause:
                                            The main PD connector:
                                            PD-1 (PNL12V) : 0.02V
                                            PD-2 (PNL12V) : 0.02V (fluctuating)
                                            PD-3 (SGRN) : 0V
                                            PD-4 (SGRN) : 0V
                                            PD-5 (UR13.2V) : 0.05V (fluctuating)
                                            PD-6 (UR13.2V) : 0.05V (fluctuating)...
                                            04-19-2022, 09:26 AM
                                            The History of Radio Shack YouTube video
                                            https://www.youtube.com/watch?v=bidLW5x_yyk
                                            04-24-2025, 07:54 PM
