Sony XR-77A80J OLED 5 Blink
  • ChattFix
    • Oct 2021
    • 79
    • US
    #81
    See pictures below
    • Diah
      • Feb 2013
      • 6365
      Originally posted by ChattFix
      See pictures below
      please work and test on the boards from the downside not from top
      • EazyBone
        • Jun 2023
        • 1324
        • United states
        #83
        • Diah
          • Feb 2013
          • 6365
          Originally posted by EazyBone
          you are celebrating LOL.... please continue with him when he found the STBY pins active to do next step to test PSU as stand alone to know if there T-CON 12 and EVDD after it will prove please tell how it need to test the psu and t.con and panel as stand alone.... no LVDS or main boards socket in place. thank
          • EazyBone
            • Jun 2023
            • 1324
            • United states
            #85
            Not celebrating, just enjoying the show
            • lotas
              • Jan 2016
              • 4595
              • Russia
              #86
              See pictures below
              You are measuring on the wrong contacts, your probe is set to 11 pin.
              • Diah
                • Feb 2013
                • 6365
                you are the owner of this threat and you know better than us all.... so do yours human job lol
                • EazyBone
                  • Jun 2023
                  • 1324
                  • United states
                  #88
                  The thread has all the info. I've come a long way since this TV. I have also learned that I hate sonys. Once he can test the panel then I'm sure we will have an answer. I haven't seen one of these tvs get fixed yet.
                  • ChattFix
                    • Oct 2021
                    • 79
                    • US
                    #89
                    Diah I apologize for my lack of knowledge and not paying attention as much as I should. My readings were incorrect as you stated as I did not read the pins on the bottom part of the connector. I have been stopping my work on other repairs to learn TV's and have noticed my mind has been split between this and working on my other repairs so I apologize for my absent mind during these posts!
                    In saying that I do have 3.5v for the STBY. Staying on 2 I still don't have any readings on the 2 black connectors going to the T-CON as well as the white connector.
                    EazyBone I also was laughing at myself going back through these posts lol. I also apologize for adding two pages to this thread of nonsense haha
                    • Diah
                      • Feb 2013
                      • 6365
                      disconnect the MB socket from PSU , and disconnect the 2 LVDS from T-CON, the sockets between PSU and T-CON should be in place
                      jumper STBY to pin 5 ( Power ON, & to pin 3 EVDD ON, and to pin 1. t-con on see the photo i attached at my post 84
                      turn ON and look at the screen how it will come on with pattern color
                      • lotas
                        • Jan 2016
                        • 4595
                        • Russia
                        #91
                        This is not a simple T-CON, and when power is applied to it, there will be nothing, no colors you will see!
                        • ChattFix
                          • Oct 2021
                          • 79
                          • US
                          #92
                          I have 3.5v going to pin 1,3,5 but no picture. Do I need to jump some points to turn the TV on or do I just plug it in?
                          • ChattFix
                            • Oct 2021
                            • 79
                            • US
                            #93
                            EazyBone are these the same steps that you followed with turning the tv on with just plugging it in?
                            • Diah
                              • Feb 2013
                              • 6365
                              if you did the jumpers correctly on the assigned pins. and you plug the tv in wall.... if no screen... test the sockets on the t-con all at fuses from both side if you have V.
                              • ChattFix
                                • Oct 2021
                                • 79
                                • US
                                #95
                                I'm getting 12.8v from 3 pins on the white socket but nothing from the black sockets.
                                • Diah
                                  • Feb 2013
                                  • 6365
                                  you need now take out the PSU alone on table and do the jumpers all 3 as i wrote before and trouble shooting the circuit of EVDD circuit at cold area... u worked on it before... you may forget put back the R in place LOl or missed with some parts
                                  • ChattFix
                                    • Oct 2021
                                    • 79
                                    • US
                                    #97
                                    Put it on the table and the bridge is good. CN6601 only have 12.8v in Pin 1 and 3, Pin 2 only has .07. Everything else is 0v. What is the R or LOI?
                                    • Diah
                                      • Feb 2013
                                      • 6365
                                      R the Resistor you moved before one leg at early testing... do you have on bin 3 socket 6401 3.3V as the STBY
                                      • ChattFix
                                        • Oct 2021
                                        • 79
                                        • US
                                        #99
                                        Resistor is getting 12.8v on the positive side. Bin 3 socket 6401 is getting 3.5v
                                        • Diah
                                          • Feb 2013
                                          • 6365
                                          this rail pin 3 are EVDD which right now missing V on socket 6101, you need to follow the rail from pin 3 socket 6401 circuit till the optocoupler , there you have issue which the EVDD circuit didn't start
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                          • EazyBone
                                            Sony 85x90CK 4 red blink
                                            by EazyBone
                                            So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                            But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                            Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                            Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                            07-18-2025, 12:53 PM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
