Sony XR-77A80J OLED 5 Blink
  • Diah
    • Feb 2013
    • 6483
    Re: Sony XR-77A80J OLED 5 Blink
    Originally posted by EazyBone
    Okay will do. And to confirm the evdd coming from PSU is 21.7 v not 24v as Davi said.
    Report back soon
    it is wrong... its always between 20-23V no standard for 24V. as its for OLED driver... currents will depending on adjustment.
    • EazyBone
      • Jun 2023
      • 1356
      • United states
      And diah what's a while? 5 min?
      • Diah
        • Feb 2013
        • 6483
        maybe less or more depend on yours luck..
        you have OLED Cells shorted on the Module... if the short went out... the screen will light complete pattern... its look that the you have blue cells line had short , as you don't get blue.... only 2 lines white... mean at the white lines the blue worked but they are shorted with red and green.. do displaying white... RGB
        • Diah
          • Feb 2013
          • 6483
          but be careful.... the module could get fire on the shorted area.. so be ready
          • EazyBone
            • Jun 2023
            • 1356
            • United states
            I get blue red white green
            • Diah
              • Feb 2013
              • 6483
              Originally posted by Davi.p
              if the tcon gives the correct supply lines to panel (24v, 17v, -6v, all approx.) then you can try with panel.
              PSU on OLED Tvs used only ONE for all TV size... V to T-CON ( main boards are all the same.
              but the V to OLED driver which go to T-CON will be different depending on TV size and how much OLED cells build in module ans how much currents they need
              • Diah
                • Feb 2013
                • 6483
                the 2 white line disappeared ?
                • EazyBone
                  • Jun 2023
                  • 1356
                  • United states
                  #28
                  Fire also should be something say before hand lol I was not ready. But no fire. And okay on voltages
                  The white lines in the middle? Yea they show up and leave randomly. It just cycles the picture shown. Red white green blue back and fourth with small white line randomly in middle of full screen
                  • Diah
                    • Feb 2013
                    • 6483
                    well from my experiences its Module... but the way the line it show from left to write... its T-CON responsible on it... if the lines from top to downside then 100% module... take the risk and replace t-con if its cheap LOL
                    • EazyBone
                      • Jun 2023
                      • 1356
                      • United states
                      #30
                      Okay, all the lines are left to right. Although that color line is up and down, all the lighting up is all doing left and right lines. No lines are up and down.
                      Will do, tcon ain't that expensive thank you
                      • Diah
                        • Feb 2013
                        • 6483
                        by the way... inspect all 4 ribbon cable under loop from both sides... who knows could some play with them before and damaged them,,, just in case
                        Note important.. after inspecting you should put them back at same order before... to avoid later line light in image
                        • EazyBone
                          • Jun 2023
                          • 1356
                          • United states
                          #32
                          I did look at those as well. I even cleaned them off, appreciate that. Owner did say he didn't do anything at all, looks like had never been opened before. TCON like $45 so gonna go with that option. Thx for all info diah, davi, Sony. This one will go on the wall if it's fixable
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4506
                            • Italy - Milan
                            #33
                            1) In your pictures it lacks the one that shows the table of pins for the psb to tcon cable,
                            in your list it lack also..
                            2) in the linked thread the other model appears almost the same and he has 24v not 21v
                            • Diah
                              • Feb 2013
                              • 6483
                              1)
                              he got V on pin labeled 24V. doesn't mean its 24V LOL... 21-23 V all will be called found V on 24 PIN... at the end mean PSU 100% fine same in this threat..
                              so do you think he measured 24.0V LOL
                              if you want to know exact V. the PSU should be stand alone with out any load.. just it alone on table
                              • EazyBone
                                • Jun 2023
                                • 1356
                                • United states
                                #35
                                Stand alone was also 21.7.
                                • EazyBone
                                  • Jun 2023
                                  • 1356
                                  • United states
                                  #36
                                  I have that picture on first post. Pic 3
                                  1-3 tcon 12v
                                  4-18 is grounds 19-30 evdd
                                  • Diah
                                    • Feb 2013
                                    • 6483
                                    its fine.
                                    you can let the tv in original all cable plugged in... lvds etc ribbon... only the socket evdd disconnect it from power boards side then turn on... tv should start and you have the audio optic port lit red and remain on.
                                    • Diah
                                      • Feb 2013
                                      • 6483
                                      if you look on the LVDS down one ( which you disconecct it before and TV remain ON.with black screen ) there are test points ( EVDD_RESET ) this points go high to round 3.3V at time the Tv shutting down because of the SOS signal.
                                      if this points jumper to chassis to remain always low the TV will remain on and you could see the screen on... but in which condition this is the questions..
                                      so if the the points go high.. mean EVDD at the module had short cells too
                                      • EazyBone
                                        • Jun 2023
                                        • 1356
                                        • United states
                                        #39
                                        The only way TV turns on as normal is if I disconnect the bottom lvds from main to tcon. Any other combinations of cable disconnect does not allow TV on and throws error code. Gonna report back once I get tcoj on Tuesday and then test voltages. Thx
                                        Edit I reread your message and you realize that cable disc keeps on lol. But yes I'm gonna wait since it's on the way anyway. Let's pray to the panel gods that it's the TCON
                                        • EazyBone
                                          • Jun 2023
                                          • 1356
                                          • United states
                                          #40
                                          TV is done. New tcon same results. Panel short. Thanks for trying. I have bad luck with expensive tvs
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
                                          • jason123
                                            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                            by jason123
                                            Hi there,
                                            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                            I see 2 posts that are relevant:
                                            https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                            https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                            10-29-2025, 02:01 PM
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
