Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
  • jason123
    • Oct 2015
    • 1110
    Originally posted by lotas
    Actually, the "ERROR DETECTION" pin is in a completely different place, don't burn the T-CON.
    So add a jumper (short) the error detection test point to mounting screw? What was the first test point you had a triangle on in post #38 ?
    • Diah
      • Feb 2013
      • 6483
      hahaha now Lotas... you are wrong the points are no 12 after the ESD Diode... we have threat on it..
      this is original threat photo look with glasses and compare. other wise keep silent as other.
      • jason123
        • Oct 2015
        • 1110
        Ok, Shorted the "Error Detection" test point to mounting screw. TCON now has 19.x V and 12.6 V - Panel is not burning and not turning on - fuses on TCON intact -
        • Diah
          • Feb 2013
          • 6483
          LVDS 51 pin in place?
          • lotas
            • Jan 2016
            • 4796
            • Russia
            #45
            Click image for larger version  Name:	3C97CAAC-C441-4FBA-8EC1-64D7E56A0AED.jpg Views:	0 Size:	497.0 KB ID:	3755852
            If you don't understand the checkpoints, then we'll wait for your experiment!
            • Diah
              • Feb 2013
              • 6483
              lotas please don't distributed the threat , he did it and Tv are ON so stop please let me thinking how to bring his screen on
              • jason123
                • Oct 2015
                • 1110
                yes
                and the TV seems responsive to button and remote, I can hear the beeps when going to "home" screen .. turns on and off with remote.
                Only odd part is the white LED in front, has absolutely no activity (doesn't turn on)
                • Diah
                  • Feb 2013
                  • 6483
                  Originally posted by jason123
                  yes
                  do you have laser temperature measure tools or any....if yes.. try monitor the Temp on T-CON and screen corner .... try to put back the T-CON heat skin on.. and keep this configuration... to start with early talking hard reset. ... after u push the power and plug it in wall. count 16-15-1413-till 10 then release and wait 10-15 minute,,, it could reboot 2 time so eyes on screen if any change and your Optic Port
                  • Diah
                    • Feb 2013
                    • 6483
                    white LED could be disabled by user from setting early... hard rest will bring it back as sign
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4508
                      • Italy - Milan
                      #50
                      ok now you really break the balls, now i see what you do with your useless info, i'll wait your technical defeat.. i prepare for a loud laugh
                      • jason123
                        • Oct 2015
                        • 1110
                        I do not unfortunately have an infrared temp device. I felt with my hand around the edges of the screen, and nothing is warm even. The main processor on TCON gets hot, but touchable.
                        I'll attempt the reset again.
                        • Diah
                          • Feb 2013
                          • 6483
                          there are no experiment at all... all my ways here in this forum or other are KNOW HOW
                          • lotas
                            • Jan 2016
                            • 4796
                            • Russia
                            #53
                            On different LG T-CONs (OLEDs), the locations of the control points are different. You need to read the labels to find out where they are, and not just take a sample from one T-CON. Here is another example of where ERROR DETECTION is located!
                            • lotas
                              • Jan 2016
                              • 4796
                              • Russia
                              #54
                              And following this advice (photo), you short-circuited the "EVDD RESET" to ground!
                              • lotas
                                • Jan 2016
                                • 4796
                                • Russia
                                #55
                                And according to this photo, everything is correct, "E.D." matches.
                                • Diah
                                  • Feb 2013
                                  • 6483
                                  why you are warm writing and the result as expected.. calm down and learn that all.
                                  • lotas
                                    • Jan 2016
                                    • 4796
                                    • Russia
                                    #57
                                    Yes, in order to prove something to you, you need to spend a lot of time and still prove nothing, just like with the amputation of the IR sensor output on MICOM.
                                    • Diah
                                      • Feb 2013
                                      • 6483
                                      you are stupid person at OLED ..like others from Italian
                                      • lotas
                                        • Jan 2016
                                        • 4796
                                        • Russia
                                        #59
                                        I get the impression that you are a complete zero when it comes to TV repairs.
                                        • jason123
                                          • Oct 2015
                                          • 1110
                                          I attempted reset a couple of times. PS cycles few times while I am holding the power button. No activity on the front LED (No white /green / red/ blue)...after I release the power button the main board comes on (screen is lit) then 40 or so seconds later it reboots.. then back to main board on and screen is lit. I can hear the beeps when pressing remote buttons. So responsive just no picture
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • Dogindelusion
                                            Sony XR-77A80K 5 Red Blinks Troubleshooting
                                            by Dogindelusion
                                            Hi everyone! I am a new member and am new to electronics repair. I have a background in electrical engineering, but little experience in electronics.
                                            I have a Sony XR-77A80K which will not turn on and has 5 blinking red lights in the stand-by light. I had previously done a forced factory reset, which removed the error code, and the TV regained functionality for a few weeks. I repeated the factory reset and again regained functionality. This happened a few times until I so I had to begin troubleshooting the error.
                                            Observations:
                                            1) I noticed I was not getting...
                                            08-09-2023, 09:44 PM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                          • Glaval
                                            Sony OLED XBR-65A8G 4 flashes
                                            by Glaval
                                            Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                                            01-23-2025, 04:04 PM
