Samsung UE55MU6120K Boot loop with backlight no video
    Re: Samsung UE55MU6120K Boot loop with backlight no video
    Originally posted by nomoresonys View Post
    my buddy tampatec fixed one by putting some good heatsinks on every chip that got pretty warm on the mainboard, might not do the trick but something pretty easy to try.
    it was installed on the wall, maybe some bad welding and with the deformation of the weight... I don't know what the hell to think, it's the strangest thing that happened to me
      not sure, but probably retaining a lot more heat if it's snug against the wall, well was it sitting straight when running for 30 hours as in same position as on the wall.
        It just didn't turn on, plugged into the wall...turned on and baamm rebooting like always
          probably won't work but if it's still on the wall try a quick reset before you wrestle it back off the wall, unplug tv, hold power button for 30 seconds and try it, prolly no joy, then off the wall again.
            already done unfortunately it doesn't work, i have to disassemble everything again
              lmao...hate when that happens.
                Don't waste time with thoughts of bad soldering joints and Macumbeiras... the problem reseats on the display and obviously without surgeries and with the eprom comparison equal you have a alternating defect maybe little heat related, maybe to gate COG , better to start the tespoint searching, clock lines, and prepare masking flats with tape..
                  doubt it very much, can not recall a shorted panel ever not working then working for 30 hours.
                    I maskered the world to no avail last time, I'll see tomorrow anyway a bit and I do various tests
                      Evidently if you have forced TCon-Ready signal and something heated on the main board, the main goal is to locate the short circuit, actually it can also be on a small cap on mainbboard, thethermal cam helps, but also if you go to the supermarket you can ask the shop man for a piece of adhesive thermal paper for the fiscal record, if the heat comes from an inductor only on mb then better to search on the panel distribution boards
                        Originally posted by lotas View Post
                        You didn't seem to put a jumper there.
                        I'm back, I bridged the points indicated by you (without connecting the display flats) and the TV turns on and off repeatedly as always, at this point I buy a motherboard once and for all
                          Well you can replace the mainboard 47 times but it still won't fix it if the problem isn't the mainboard.
                            Well, now try, with each lvds cable (from the left, then from the right).
                              maybe you missed some pieces :-)
                                i heated this area up with 350 degree hot air and the tv started working again
                                  Actually it probably is the mainboard, well there's your proof, posted this after the above post, as in wrote this before your above post so didn't see that til after I posted.
                                    he seems to be the problem, probably some cracked welding since it now works after being heated
                                      so I wonder what exactly it could be, do any of those little mlc caps test short, maybe check those resistors too, what is that chip the ethernet switch?
                                        This is a DC / DC converter for powering the panel, there may be a problem in tying this converter with ceramic capacitors.
                                          Yes it's a power main control chip, the nearby capacitor had a cracked solder, I re-soldered it, let's see it works for now
