Samsung UE55MU6120K Boot loop with backlight no video
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4518
    • Italy - Milan
    #81
    Re: Samsung UE55MU6120K Boot loop with backlight no video
    yes, it seem the correct T-RDY3 point is the one marked by Lotas, not so easy to understand..
    Don't expect it will work for long time.. something wrong may exist too..
    Let us to know how it goes, i'm much curious..
    • fanaticgames
      • May 2017
      • 138
      • italy
      #82
      Originally posted by lotas
      You didn't seem to put a jumper there.
      according to your photo then I made the bridge between pwm4 and rdy1, how can it be that it works now? it's still on without the jumper
      Update
      take some current photos with the TV on, the temperatures seem perfect both on the motherboard and on the flats of the right and left panel cards which are usually always hot
      • fanaticgames
        • May 2017
        • 138
        • italy
        #83
        it certainly won't last for now it's been on for 30 minutes, maybe I'm talking bullshit could it be that some component "discharged" during these days of inactivity? the esd diodes??
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4518
          • Italy - Milan
          #84
          no, nothing discharged, pwm4 might be the signal that goes to the power board and is for brightness level setting, T-RDY1 might be a fixed 3v i guess, putting pwm4 set to steady 3v could have set brightness of part of the backlights bars to full brightness.. nothing to do with lcd panel i think.. those 2 mosfets are probably final switching transistors for the pwm signals
          • fanaticgames
            • May 2017
            • 138
            • italy
            #85
            but the jumper was held for 4/5 minutes with the TV on, now there is no jumper, I also turned it off for 5 minutes and turned it on again and it works regularly
            I also redid this wrong jumper last time
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4518
              • Italy - Milan
              #86
              As obvious i don't know what happened, no schematics, no answers, i have a doubt but i let it stay in silence.. we will see
              • fanaticgames
                • May 2017
                • 138
                • italy
                #87
                out of curiosity I disconnected all the flats and reconnected (just to rule out a false contact) and I mounted the cover behind, it still works. Now I'm going to leave a movie playing, let's see...
                • fanaticgames
                  • May 2017
                  • 138
                  • italy
                  #88
                  has been on more than 10 hours without problems, I don't know what to say but it works
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4518
                    • Italy - Milan
                    #89
                    i am developing from also other threads an idea that the main board stores in an eprom something like an error flag, the forcing of the tcon outputs can restore a visualization and reset that flag, maybe in certain cases the error flag is set due to a temporary malfunction, i'm following another interesting thread, if i have some news i'll let you inform..
                    • fanaticgames
                      • May 2017
                      • 138
                      • italy
                      #90
                      which of the two eeprom? because I made a backup before doing other tests (I wanted to understand if it had a damaged firmware), I could do a new dump and compare if there are differences
                      • lotas
                        • Jan 2016
                        • 4805
                        • Russia
                        #91
                        25Q80 is responsible for T-Con.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4518
                          • Italy - Milan
                          #92
                          No, i think the more possible responsible is the main settings eprom, that is the 24c series eprom
                          • fanaticgames
                            • May 2017
                            • 138
                            • italy
                            #93
                            I have a backup of this before making the attempts I've made
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4518
                              • Italy - Milan
                              #94
                              and the comparation what says?
                              • fanaticgames
                                • May 2017
                                • 138
                                • italy
                                #95
                                identical dumps, no difference
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4518
                                  • Italy - Milan
                                  #96
                                  comparison not comparation sorry..
                                  • fanaticgames
                                    • May 2017
                                    • 138
                                    • italy
                                    #97
                                    bad news, the tv was installed on the wall in its old place with only the power cable and tv antenna connected, the first time it was turned on the error again ... it has been turned on 4:5 days lately without problems
                                      • 12307
                                      • U.S.
                                      #98
                                      almost seems like something on the mainboard is just getting too hot once you get the back on and it back on the wall.
                                        • 12307
                                        • U.S.
                                        #99
                                        my buddy tampatec fixed one by putting some good heatsinks on every chip that got pretty warm on the mainboard, might not do the trick but something pretty easy to try.
                                        • fanaticgames
                                          • May 2017
                                          • 138
                                          • italy
                                          #100
                                          impossible has worked with the backcover for over 30 total hours
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                          • signedupfordownload
                                            Samsung UE49KU6500U boot loop
                                            by signedupfordownload
                                            My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                            With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                            I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                            07-29-2024, 01:56 PM
