Samsung UE55MU6120K Boot loop with backlight no video
  • Diah
    • Feb 2013
    • 6357
    Re: Samsung UE55MU6120K Boot loop with backlight no video
    Originally posted by lotas
    Do not try to supply 12v anywhere, otherwise you will completely kill your panel and motherboard! Check with a multimeter for resistance these leads on the protective diode assemblies relative to gnd.
    +10
    Originally posted by Davi.p
    inject 12v on the 15v line, prepare to remove it when you see something wrong, better if you increase current slowly..
    could you please stop this stupid suggestion..
    as Lotas said ESD diode... but if one shorted.. you will have cell shorted.. the solution block all ckv from the top LVDS socket at MB side. other wise this is rubbish Panel.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4299
      • Italy - Milan
      Diarrhea don't bother me ok? So now you must keep a lesson on why this is dangerous.. we listen..
        • 12120
        • U.S.
        2 of the best professional techs here just advised against it and stated what will happen if you do that, so WHAT don't you understand about it davipee.
        • fanaticgames
          • May 2017
          • 138
          • italy
          just check that they are not shorted? because I had already tested in continuity mode
          • fanaticgames
            • May 2017
            • 138
            • italy
            Originally posted by Diah
            +10
            even if i want to do it as individual ckv lines? on the motherboard I don't see any ckv indication
            • fanaticgames
              • May 2017
              • 138
              • italy
              #26
              I don't know if it can be useful as information but someone has already repaired or attempted to repair this motherboard in the past because this component had its soldering redone (I don't know if it was changed or just re-soldered)
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4299
                • Italy - Milan
                #27
                to make things short, locate on MB two test points named T-RDY1 , T-RDY3, join them, in this way protection is disabled, now turn on tv and watch on to the screen's small boards if something gets hot or smokes, prepare to turn off tv rapidly, hope that there is a cap or diode in a half short state..
                • lotas
                  • Jan 2016
                  • 4555
                  • Russia
                  #28
                  Points T-RDY1, T-RDY3 do not disable protection, they are intended for something else.
                  • fanaticgames
                    • May 2017
                    • 138
                    • italy
                    #29
                    but there is no way to make a uart connection to the motherboard via usb serial ttl to understand the reason for the reboot, before reaching these extreme attempts? on consoles like ps4 or phones it's useful, on tv's i don't see many arguments about this
                    • lotas
                      • Jan 2016
                      • 4555
                      • Russia
                      #30
                      The UART is locked in the firmware itself.
                      • lotas
                        • Jan 2016
                        • 4555
                        • Russia
                        #31
                        When you disconnect which cable (left or right), does the TV stop overloading?
                        • fanaticgames
                          • May 2017
                          • 138
                          • italy
                          #32
                          this is what i'm trying to explain from the beginning, i recap:
                          (with TV off)
                          I turn on the TV only with the left flat connected and it turns on
                          I turn on the TV only with the right flat connected and it turns on
                          I turn on the TV with both flats connected and it goes on and off endlessly
                          same thing even if I disconnect the flats with the TV on, just disconnect any one and it stays on
                          the problem occurs only when both flats are connected
                          Damn
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4299
                            • Italy - Milan
                            #33
                            Lotas i have tested it on a Panasonic with Samsung panel, the image appears and stays on with many artifacts and a coil starts to heat on tcon.
                            Fanaticgames, there's no need of the uart, the fault is in the screen, this is clear for who has experience enough, the uart is possible maybe but it's a very long process to enable it..
                            • lotas
                              • Jan 2016
                              • 4555
                              • Russia
                              #34
                              (with TV off)
                              Damn
                              It's clear, now put a jumper between T-RDY1 and T-RDY3 (imitation of panel connection) and check also with the loops disconnected (with left and right).
                              • fanaticgames
                                • May 2017
                                • 138
                                • italy
                                #35
                                jumper done, it works
                                • lotas
                                  • Jan 2016
                                  • 4555
                                  • Russia
                                  #36
                                  T-RDY1 and T-RDY3
                                  • fanaticgames
                                    • May 2017
                                    • 138
                                    • italy
                                    #37
                                    T-RDY1 and T-RDY3
                                    yes, jumper done, the tv doesn't restart and works, so it's definitely the faulty panel
                                    EDIT
                                    I used this, isn't he?
                                    • fanaticgames
                                      • May 2017
                                      • 138
                                      • italy
                                      #38
                                      now I have connected them correctly and the tv keeps restarting all the time, so the motherboard is bad??
                                      • lotas
                                        • Jan 2016
                                        • 4555
                                        • Russia
                                        #39
                                        I don’t know, it’s not clear where, in one place there is a point, and its inscription in another, now on which half is the defect in the matrix?
                                        If the cable is inserted one of a kind, is there also a reboot?
                                        • fanaticgames
                                          • May 2017
                                          • 138
                                          • italy
                                          #40
                                          at the point I indicated it does not restart, at the point you indicated it restarts, the flats are disconnected I have not tried to connect them
                                          from the tests I did yesterday by putting the tape on the left side flat it didn't go out but you couldn't see anything anyway
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • NolesFan
                                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                            by NolesFan
                                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                            10-24-2024, 06:36 PM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                          • signedupfordownload
                                            Samsung UE49KU6500U boot loop
                                            by signedupfordownload
                                            My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                            With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                            I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                            07-29-2024, 01:56 PM
