Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    • Jan 2016
    • 4621
    • Russia
    #101
    Originally posted by Me_you_them
    Hi lotas,
    can you help me with this firmware???
    Samsung UE55MU6400U
    M/B BN41-02568B (BM94-12401R)
    Hi, I can, try it.
    • Me_you_them
      • Aug 2024
      • 5
      • Italy
      #102
      Nothing to do....
      Standby led turns on and immediately off, sometimes led bars turns on and off imediately
      • lotas
        • Jan 2016
        • 4621
        • Russia
        #103
        Nothing to do....
        Was this dump native, original, status register (0x88, 0x42) written after recording the dump?
        • Me_you_them
          • Aug 2024
          • 5
          • Italy
          #104
          Yes the dump was the original native one, status register done, i followed the instruction on the post #4
          • lotas
            • Jan 2016
            • 4621
            • Russia
            #105
            What program did you use?
            NeoProgrammer V2.2.0.10 ?
            Did you program the chip through a clothespin or solder the chip through an adapter?​
            • Me_you_them
              • Aug 2024
              • 5
              • Italy
              #106
              I've used NeoProgrammer V2.2.0.10 and I've desoldered the chip from the mainboard and soldered on the adapter to program it
              • Me_you_them
                • Aug 2024
                • 5
                • Italy
                #107
                Maybe I found the problem...
                I noticed that the component indicated in the photo it's no longer there,​ probably has blown out during the desoldering of the chip.
                Is there any solution?
                • Mr.Pc
                  • Jan 2023
                  • 41
                  • Brasil
                  #108
                  Hey guys! I also have my Samsung TV UN65MU6100G whith main pcb model/code: BN41-02568B and power supply: BN44-00808D which is not turning on and only has the standby LED blinking. I opened the TV and did some tests with the source board and the LEDs light up and the voltage is stable. It has two eproms and I believe the problem is in one of them. Could anyone help me with this, I extracted the file from both. Thank you in advance for everyone's attention!
                  • lotas
                    • Jan 2016
                    • 4621
                    • Russia
                    #109
                    25Q40 is working, have you disconnected the lvds cable from the motherboard? (in this case how TV behaves)
                    • Mr.Pc
                      • Jan 2023
                      • 41
                      • Brasil
                      #110
                      I disconnected the lvds cables and it remains the same. I noticed that when I plug in the power supply, the voltage fluctuates as if there was a short on the main board. I found an inductor L406_UT on the main board that has a very low resistance of 0.04ohms. I don't have the schematics so I don't know if it's right.
                      • lotas
                        • Jan 2016
                        • 4621
                        • Russia
                        #111
                        There is a negative voltage (VGL) on the T-CON, so one inductor should be connected to ground with one terminal, to convert the negative voltage relative to the ground, rather this is this inductor, check how it is connected.
                        • Mr.Pc
                          • Jan 2023
                          • 41
                          • Brasil
                          #112
                          I have already checked your connection and everything is normal considering this negative voltage. I've already checked the USB and HDMI and there is no short. I also checked two mosfets that are in the connector that comes from the power supply and there are no shorts, which is why I was doubting the 25q40.
                          • lotas
                            • Jan 2016
                            • 4621
                            • Russia
                            #113
                            Did you place a jumper on the motherboard between contacts FB_TRDY_1 and FB_TRDY_3 (feedback)?
                            • Mr.Pc
                              • Jan 2023
                              • 41
                              • Brasil
                              #114
                              Not yet because I don't know how to identify these points. What I did was disconnect the lvds cables and turn on the TV without them. 😅
                              • lotas
                                • Jan 2016
                                • 4621
                                • Russia
                                #115
                                Post a high-quality photo in the area of ​​the lvds connectors.
                                • Mr.Pc
                                  • Jan 2023
                                  • 41
                                  • Brasil
                                  #116
                                  I managed to find the points you mentioned, but I don't know how to identify them like that on the PCB. My camera isn't the best, but I believe I can see it. I marked a red dot in each place. I also want to thank you for your time and attention.
                                  • lotas
                                    • Jan 2016
                                    • 4621
                                    • Russia
                                    #117
                                    These ones.
                                    • Mr.Pc
                                      • Jan 2023
                                      • 41
                                      • Brasil
                                      #118
                                      These ones.
                                      So I make a jumper between the two, connect the LVDS cables and turn on the TV?
                                      • lotas
                                        • Jan 2016
                                        • 4621
                                        • Russia
                                        #119
                                        One at a time, and you will see which half of the panel is not working, if the problem is in the panel.
                                        • Mr.Pc
                                          • Jan 2023
                                          • 41
                                          • Brasil
                                          #120
                                          I made the jumper and tested one side at a time, but it still didn't work. In any case, I am grateful for your dedication.
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • jeangonbay
                                            Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                            by jeangonbay
                                            Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                            The model of my TV is UE43MU6105K
                                            Main Board: BN41-02568B
                                            BN94-12007Y
                                            Could you help me to repair the dump please. Thank you.
                                            02-16-2024, 05:46 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
