Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    • Jan 2016
    • 4745
    • Russia
    #121
    How many times does the standby LED blink between pauses?
    • Mr.Pc
      • Jan 2023
      • 41
      • Brasil
      #122
      It blinks non-stop, without pause, there is no error code. Measuring the voltage on the main PCB connector, the power supply oscillates between 11.5v and 9v. I did the test without the 25q40 and the voltage stabilizes at 9.5v. When I disconnect the power supply cable, the panel LEDs light up normally and the source voltage stabilizes at 12.65v.
      I did the test with a bench source too, I injected 12v into the main PCB and there is very low consumption and it goes back to zero, this keeps looping
      • lotas
        • Jan 2016
        • 4745
        • Russia
        #123
        What model, panel number, I want to check 25Q80 if I find a dump, and what is the motherboard number BN94-xxxxx?, it is written on a paper sticker on the motherboard.​
        • Mr.Pc
          • Jan 2023
          • 41
          • Brasil
          #124
          What is written on the paper is BN94-12811S. Model: BN41-02568 - Code: BN41-02568B is printed on the motherboard. If you want I can take a photo of everything
          • lotas
            • Jan 2016
            • 4745
            • Russia
            #125
            What is the panel number? CY-GK065HGNVBH ?
            • Mr.Pc
              • Jan 2023
              • 41
              • Brasil
              #126
              Hello Lotas! Sorry for the delay, but it was due to the time. I picked up the TV again and saw the panel number: CY-GK065HGNV5G
              • lotas
                • Jan 2016
                • 4745
                • Russia
                #127
                Everything is fine with 25Q80 too, you can read dump 25Q40 again and show what its status registers are.​
                • Mr.Pc
                  • Jan 2023
                  • 41
                  • Brasil
                  #128
                  I can yes! Just to let you know that since I read them the defect is the same. These are the same ones I already sent you, but if you want I can read them again and send them, but as I already told you the problem has been the same since then.
                  • lotas
                    • Jan 2016
                    • 4745
                    • Russia
                    #129
                    You don’t understand me, I don’t need dumps, but what status register is registered on 25Q40, which is what the programmer log shows when reading these statuses.
                    • Mr.Pc
                      • Jan 2023
                      • 41
                      • Brasil
                      #130
                      hmmm now I understand Lotas! About this error log issue, I don't know how to check. The TV's standby LED blinks continuously and does not report any code. To extract the file I use the TL866 II and I don't know how to see this error log with this equipment. 😅☹
                      • lotas
                        • Jan 2016
                        • 4745
                        • Russia
                        #131
                        Yes, this is not an error log, but a protection (status register), read the 25Q40 chip again and after reading, click on “status register” and a new window will pop up, this window show me where the checkboxes are...
                        • Mr.Pc
                          • Jan 2023
                          • 41
                          • Brasil
                          #132
                          Ok! I will make this now. Wait a minute.
                          • Mr.Pc
                            • Jan 2023
                            • 41
                            • Brasil
                            #133
                            Pronto!
                            • lotas
                              • Jan 2016
                              • 4745
                              • Russia
                              #134
                              Pronto!
                              Everything is correct, as it should be.
                              • lotas
                                • Jan 2016
                                • 4745
                                • Russia
                                #135
                                So with 25Q40 and 25Q80 you have everything in order, all that remains is eeprom 24C512, dc/dc converters on the motherboard (the correct ones output voltages), underestimated or short circuit on the supply lines or the processor itself....
                                • Mr.Pc
                                  • Jan 2023
                                  • 41
                                  • Brasil
                                  #136
                                  Right! Can you verify 24512? I understand very little about programming and I'm even curious to understand it better, but as I said, if you can see it for me, I can read it and put it here. Regarding shorts, I didn't find any and the dc/dc ldo regulators I can't check the outputs because the board goes into protection and also doesn't have their reference so I can inject voltage and do the tests. Anyway, I'm still grateful.
                                  • lotas
                                    • Jan 2016
                                    • 4745
                                    • Russia
                                    #137
                                    24C512 I can't check, since they are all different for each TV (it contains the model, settings, serial numbers, MAC Address, ....), I can upload a working dump for checking, just be sure to save your own one.
                                    Have you checked the wi-fi module or turned it off?
                                    Try.
                                    • Mr.Pc
                                      • Jan 2023
                                      • 41
                                      • Brasil
                                      #138
                                      Try.
                                      Hi Lotas! I've already turned off the Wi-Fi module too, but it stays the same, unless this card only works with the module connected, but I don't think so. I have the board here on the bench, I connected 13v and checked that even the 5v voltage is stable, below it everything fluctuates. I looked for the 25C512 but I didn't find it, I only found a 25512FD but I'm sure it's another component because on the board it has terminals 1 to 4 on the same track, so it can't be 25C512. Finally my head is starting to smoke and I'm already wanting to set everything on fire hahaha I think I'll try to look at another board because I don't have an oscilloscope to be able to see the circuit in another way, I also don't want to take up as much of your time as I already did . Thank you once again for all your support and patience.
                                      • lotas
                                        • Jan 2016
                                        • 4745
                                        • Russia
                                        #139
                                        Maybe it's still 24512FD, if so, then it's 24C512 and on the board 1-4 pins are connected together and sit on the ground.
                                        You write that your 5v is stable, but below is not stable, while 3.3v is doing well, they should also be stable, since this voltage powers the standby and the spi flash 25Q40 (8pin) should be stable at 3.3v.
                                        • Mr.Pc
                                          • Jan 2023
                                          • 41
                                          • Brasil
                                          #140
                                          Hi Lotas! Me here again. Analyzing the 3.3v voltage it is also oscillating and then I realized that when removing the inductor from the 3.3v dc/dc regulator (this regulator receives 13v from the source board), after removing the inductor, the 13v from the source board stabilizes, however, As I said, I didn't find any type of short or apparent leak. I also checked if the 3.3v regulator heats up beyond normal, but it doesn't heat up at all. Don't you have the schematic for that board? Now I tried to read the 24512FD (it has pins 1-4 connected to gnd) but it gave an error and I couldn't read it.
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • jeangonbay
                                            Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                            by jeangonbay
                                            Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                            The model of my TV is UE43MU6105K
                                            Main Board: BN41-02568B
                                            BN94-12007Y
                                            Could you help me to repair the dump please. Thank you.
                                            02-16-2024, 05:46 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
