Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    • Jan 2016
    • 4899
    • Russia
    #101
    Originally posted by Me_you_them
    Hi lotas,
    can you help me with this firmware???
    Samsung UE55MU6400U
    M/B BN41-02568B (BM94-12401R)
    Hi, I can, try it.
    • Me_you_them
      • Aug 2024
      • 5
      • Italy
      #102
      Nothing to do....
      Standby led turns on and immediately off, sometimes led bars turns on and off imediately
      • lotas
        • Jan 2016
        • 4899
        • Russia
        #103
        Nothing to do....
        Was this dump native, original, status register (0x88, 0x42) written after recording the dump?
        • Me_you_them
          • Aug 2024
          • 5
          • Italy
          #104
          Yes the dump was the original native one, status register done, i followed the instruction on the post #4
          • lotas
            • Jan 2016
            • 4899
            • Russia
            #105
            What program did you use?
            NeoProgrammer V2.2.0.10 ?
            Did you program the chip through a clothespin or solder the chip through an adapter?​
            • Me_you_them
              • Aug 2024
              • 5
              • Italy
              #106
              I've used NeoProgrammer V2.2.0.10 and I've desoldered the chip from the mainboard and soldered on the adapter to program it
              • Me_you_them
                • Aug 2024
                • 5
                • Italy
                #107
                Maybe I found the problem...
                I noticed that the component indicated in the photo it's no longer there,​ probably has blown out during the desoldering of the chip.
                Is there any solution?
                • Mr.Pc
                  • Jan 2023
                  • 42
                  • Brasil
                  #108
                  Hey guys! I also have my Samsung TV UN65MU6100G whith main pcb model/code: BN41-02568B and power supply: BN44-00808D which is not turning on and only has the standby LED blinking. I opened the TV and did some tests with the source board and the LEDs light up and the voltage is stable. It has two eproms and I believe the problem is in one of them. Could anyone help me with this, I extracted the file from both. Thank you in advance for everyone's attention!
                  • lotas
                    • Jan 2016
                    • 4899
                    • Russia
                    #109
                    25Q40 is working, have you disconnected the lvds cable from the motherboard? (in this case how TV behaves)
                    • Mr.Pc
                      • Jan 2023
                      • 42
                      • Brasil
                      #110
                      I disconnected the lvds cables and it remains the same. I noticed that when I plug in the power supply, the voltage fluctuates as if there was a short on the main board. I found an inductor L406_UT on the main board that has a very low resistance of 0.04ohms. I don't have the schematics so I don't know if it's right.
                      • lotas
                        • Jan 2016
                        • 4899
                        • Russia
                        #111
                        There is a negative voltage (VGL) on the T-CON, so one inductor should be connected to ground with one terminal, to convert the negative voltage relative to the ground, rather this is this inductor, check how it is connected.
                        • Mr.Pc
                          • Jan 2023
                          • 42
                          • Brasil
                          #112
                          I have already checked your connection and everything is normal considering this negative voltage. I've already checked the USB and HDMI and there is no short. I also checked two mosfets that are in the connector that comes from the power supply and there are no shorts, which is why I was doubting the 25q40.
                          • lotas
                            • Jan 2016
                            • 4899
                            • Russia
                            #113
                            Did you place a jumper on the motherboard between contacts FB_TRDY_1 and FB_TRDY_3 (feedback)?
                            • Mr.Pc
                              • Jan 2023
                              • 42
                              • Brasil
                              #114
                              Not yet because I don't know how to identify these points. What I did was disconnect the lvds cables and turn on the TV without them. 😅
                              • lotas
                                • Jan 2016
                                • 4899
                                • Russia
                                #115
                                Post a high-quality photo in the area of ​​the lvds connectors.
                                • Mr.Pc
                                  • Jan 2023
                                  • 42
                                  • Brasil
                                  #116
                                  I managed to find the points you mentioned, but I don't know how to identify them like that on the PCB. My camera isn't the best, but I believe I can see it. I marked a red dot in each place. I also want to thank you for your time and attention.
                                  • lotas
                                    • Jan 2016
                                    • 4899
                                    • Russia
                                    #117
                                    These ones.
                                    • Mr.Pc
                                      • Jan 2023
                                      • 42
                                      • Brasil
                                      #118
                                      These ones.
                                      So I make a jumper between the two, connect the LVDS cables and turn on the TV?
                                      • lotas
                                        • Jan 2016
                                        • 4899
                                        • Russia
                                        #119
                                        One at a time, and you will see which half of the panel is not working, if the problem is in the panel.
                                        • Mr.Pc
                                          • Jan 2023
                                          • 42
                                          • Brasil
                                          #120
                                          I made the jumper and tested one side at a time, but it still didn't work. In any case, I am grateful for your dedication.
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • ogabuga
                                            Asrock B650E PG-ITX BIOS_WHP1 /25Q40/
                                            by ogabuga
                                            Hello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D​
                                            01-28-2025, 04:48 AM
                                          • daniel0799
                                            Full 25Q40 dump for TP-LINK TL-SG1016D V7 (RTL8382L + 2x RTL8218B, PCB KB616010558)
                                            by daniel0799
                                            I’m looking for the **full 512KB (25Q40) SPI dump** for **TP-LINK TL-SG1016D V7 (unmanaged)**, PCB code **KB616010558**, with SoC **RTL8382L + 2×RTL8218B**.
                                            My current dump only initializes 8 ports and the LEDs are misaligned, so I believe I have a firmware from an 8-port model.
                                            I need a complete dump (bootloader + firmware) from a working switch to restore full 16-port operation.
                                            If anyone has this model or a similar V7 revision, please share the BIN file or point me to a resource.
                                            I can provide photos of my board and the flash...
                                            10-22-2025, 11:12 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
