Circuit diagrams for new models, starting with the “D” series, cannot be found even in service centers, since they do not repair boards, but replace them entirely. Why can’t you read eeprom 24c512, did you unsolder it and read it through an adapter?
Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
Thanks for the explanation regarding the schematic. Regarding reading the eeprom, I unsoldered it and put it in my adapter, which is also soldered to the eeprom, but it didn't recognize it, so I believe it is bad. An interesting detail is that it doesn't have a pin 1 indicator (only on the motherboard it does) and I also didn't understand why pin 1-4 is on gnd on the motherboard, I looked at the datasheet to try to understand better but it didn't work. Anyway, I imagine that if this eeprom is bad, I won't be able to solve it because of the software that I can't read.Comment
I can yes!Attached Filesif you find these attachements useful please consider making a small donation to the site
Why do you choose "Auto 25...", this is not the 25th series (spi flash). and 24 series (eeprom), you need to manually enter 24C512 and press "Select".Attached Filesif you find these attachements useful please consider making a small donation to the site
I had already done this, but another error occurred. (check id error) So as I didn't know what it was, I was afraid to continue.Attached Filesif you find these attachements useful please consider making a small donation to the site
Yes, why do you always have 25, it should be 24, I wrote above that you need to write 24C512, or is the number “4” button on your keyboard not working?Attached Filesif you find these attachements useful please consider making a small donation to the site
Forgiveness! It was my lack of attention
. I managed to read it now.
I made the recording, but it didn't work. Now the LED no longer blinks, the regulator that was previously oscillating between 2.5v and 3.3v is now between 1.12v and 1.11v and getting very hot. I took the 24c off again and put the old software on, but it persisted the same way. To program the 24c, just load the .bin and click on program, right?Comment
Got it! The 24c is soldered correctly. I turned on the board without it and the regulator still gets quite hot, so I removed the inductor and it doesn't heat up anymore, but I believe that something really happened in these tests because when I put the inductor in, both the regulator and the inductor start to heat up again. I'm going to change the inductor tomorrow to see what happens because I don't have equipment to measure inductance. Regarding deleting the 24c, when I open the recorder program, the option to delete it becomes unavailable, so I can only load the .bin file and program.Comment
Hello! I replaced the inductor and it was back to normal. I believe that when I went to remove it I heated it too much and it must have ruined it. On the 24c the LED was blinking the same way. I did both with your dump and mine again.Comment
If you are looking for a new motherboard, look for the number on the white paper tag, it is BN-94-xxxxx, so that there are fewer compatibility problems with your panel.Comment
SAMSUNG UE40MU6402
There is no standby mode. I tried to fix the firmware myself, the standby mode appeared, but when I turn on the image there is no. Maybe I did it wrong.
Can anyone help?Attached Filesif you find these attachements useful please consider making a small donation to the site
by YanlebHi all,
My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
Disconnecting the main board from the power supply makes the backlight come ON.
I did disconnect the panel cables and the WIFI modules, the board is still dead.
I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
Thanks. -
by ogabugaHello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D
01-28-2025, 04:48 AM -
by daniel0799Hi everyone,
I’m looking for the **full 512KB (25Q40) SPI dump** for **TP-LINK TL-SG1016D V7 (unmanaged)**, PCB code **KB616010558**, with SoC **RTL8382L + 2×RTL8218B**.
My current dump only initializes 8 ports and the LEDs are misaligned, so I believe I have a firmware from an 8-port model.
I need a complete dump (bootloader + firmware) from a working switch to restore full 16-port operation.
If anyone has this model or a similar V7 revision, please share the BIN file or point me to a resource.
I can provide photos of my board and the flash...-
Channel: Troubleshooting & Designing Networks
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
by totofCould you help me...
I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
Then motherboard connected, standby led is on and current consuption is 18W.
Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
The model of my TV is :
Power supply BN44-00807A
Main Board BN41-02568B / BN94-12765W
Panel CY-GM055HGLV3H... - Loading...
