Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • henex00
    • May 2024
    • Poland
    #81
    Hello, TV Saamsung UE50MU6102K, BN94-12432B, BN41-02568B damaged W25Q40CL insert, please repair.​
    • lotas
      • Jan 2016
      • 4748
      • Russia
      #82
      Ready. Try...
      • henex00
        • May 2024
        • Poland
        #83
        Thank you, I will let you know about the results.​
        • smfvep
          • Jun 2014
          • Greece
          #84
          Hi Lotas, can you fix the file, please?
          I tried some other files, but I managed only to have the stand-by led on.
          Thank you
          • lotas
            • Jan 2016
            • 4748
            • Russia
            #85
            Thank you
            Try.
            • smfvep
              • Jun 2014
              • Greece
              #86
              Hi Lotas,
              I tried with the fix file but the TV set is dead. The standby LED turns on for 1 sec every 15 sec. The standby voltage from 8v goes to 13v. At first, the TV was totally dead. Now it looks like there is some life in it but there must be a hardware problem in the mainboard.
              Anyway, I want to thank you for your effort and time. I wish you the best. Thank you.
              • srdi
                • Jan 2024
                • 5
                • Ukraine
                #87
                The TV does not turn on, there is no standby mode! SAMSUNG UE55mu6192 ver01
                • lotas
                  • Jan 2016
                  • 4748
                  • Russia
                  #88
                  Try.
                  • srdi
                    • Jan 2024
                    • 5
                    • Ukraine
                    #89
                    Originally posted by lotas
                    Try.
                    Thank you very much!! Everything is working!
                    • murtagh
                      • Feb 2014
                      • 9
                      • Ireland
                      #90
                      Hi Lotas UE55MU6172 IC401 can you fix please.
                      Regards,
                      Pat.
                      • lotas
                        • Jan 2016
                        • 4748
                        • Russia
                        #91
                        Regards,
                        Pat.
                        I can, but it (dump) is working for you, your problem is not in it.
                        • murtagh
                          • Feb 2014
                          • 9
                          • Ireland
                          #92
                          Thank you Lotas, much appricated.
                          • juani981
                            • Jul 2024
                            • Argentina
                            #93
                            Hi Lotas, my TV model is UN50MU6100GCZB, Board Code: BN41-02568B from Argentina. I'm having the same issue as another user before. The standby LED turns on for 1 sec every 15 sec. When Flashing an incorrect bin, the board stays completely dead. So I guess it could be bios related. could you help me? Thanks in advance
                            • lotas
                              • Jan 2016
                              • 4748
                              • Russia
                              #94
                              Strange damage to the dump, usually if in this series the MU dump is damaged at the beginning of the dump, then the TV's standby LED does not light up at all. Try this one, I adjusted it a little, and don’t forget about the status register after recording the dump.
                              • Ashry
                                • Aug 2024
                                • 10
                                • Egypt
                                #95
                                Hello
                                Please I need your help with this mb bn41-01587e
                                5vdc exist but standby led not light and no action with power button
                                IC 1401 should be reprogrammed or what?
                                • Ashry
                                  • Aug 2024
                                  • 10
                                  • Egypt
                                  #96
                                  Dear Sir can you help me with dead main board ( BN41-01587) for Samsung ua40d6400un and power board (BN44-0427A)
                                  i uploaded the flash files from 24c02 (IC 1205) & 24c512 (IC 1401) ​
                                  A5 & 3.3 vdc are exist.
                                  thanks in advance.
                                  • lotas
                                    • Jan 2016
                                    • 4748
                                    • Russia
                                    #97
                                    Where did you get the idea that the problem is in these firmwares, if there is no standby mode and the LED is not on, then a common problem in this chassis is IC204 (stabilizer from 5v to 3.3v) and micom Weltrend, check the resistance at 1.2 pin IC203 relative ground and is there 3.3v power on these pins​
                                    • Ashry
                                      • Aug 2024
                                      • 10
                                      • Egypt
                                      #98
                                      Thanks for your your support. i found that sub eeprom (24c02) is connected to this ic1203 so i thought this may be the problem.
                                      I measured the regulator and i/p 5.3 v & o/p 3.3 v so it is good, also the voltage at pin 1&2 3.3v and no short with ground. i tried to press the reset button but nothing happened
                                      how can i check ic1203 (61P805) is healthy ??
                                      does it need programing? if yes can it be done by CH341?
                                      • lotas
                                        • Jan 2016
                                        • 4748
                                        • Russia
                                        #99
                                        What initially happened to the TV? In service mode, at the point you clicked on “Micom Update” and after that the TV stopped turning on?
                                        If yes, then the firmware has been erased in micom, you need to program it.
                                        And also, you have some strange dump 24C512, or it is so badly damaged or poorly read, try this one.
                                        • Me_you_them
                                          • Aug 2024
                                          • 5
                                          • Italy
                                          #100
                                          Hi lotas,
                                          can you help me with this firmware???
                                          Samsung UE55MU6400U
                                          M/B BN41-02568B (BM94-12401R)
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • jeangonbay
                                            Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                            by jeangonbay
                                            Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                            The model of my TV is UE43MU6105K
                                            Main Board: BN41-02568B
                                            BN94-12007Y
                                            Could you help me to repair the dump please. Thank you.
                                            02-16-2024, 05:46 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
