Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • henex00
    • May 2024
    • Poland
    #81
    Hello, TV Saamsung UE50MU6102K, BN94-12432B, BN41-02568B damaged W25Q40CL insert, please repair.​
    • lotas
      • Jan 2016
      • 4883
      • Russia
      #82
      Ready. Try...
      • henex00
        • May 2024
        • Poland
        #83
        Thank you, I will let you know about the results.​
        • smfvep
          • Jun 2014
          • Greece
          #84
          Hi Lotas, can you fix the file, please?
          I tried some other files, but I managed only to have the stand-by led on.
          Thank you
          • lotas
            • Jan 2016
            • 4883
            • Russia
            #85
            Thank you
            Try.
            • smfvep
              • Jun 2014
              • Greece
              #86
              Hi Lotas,
              I tried with the fix file but the TV set is dead. The standby LED turns on for 1 sec every 15 sec. The standby voltage from 8v goes to 13v. At first, the TV was totally dead. Now it looks like there is some life in it but there must be a hardware problem in the mainboard.
              Anyway, I want to thank you for your effort and time. I wish you the best. Thank you.
              • srdi
                • Jan 2024
                • 5
                • Ukraine
                #87
                The TV does not turn on, there is no standby mode! SAMSUNG UE55mu6192 ver01
                • lotas
                  • Jan 2016
                  • 4883
                  • Russia
                  #88
                  Try.
                  • srdi
                    • Jan 2024
                    • 5
                    • Ukraine
                    #89
                    Originally posted by lotas
                    Try.
                    Thank you very much!! Everything is working!
                    • murtagh
                      • Feb 2014
                      • 9
                      • Ireland
                      #90
                      Hi Lotas UE55MU6172 IC401 can you fix please.
                      Regards,
                      Pat.
                      • lotas
                        • Jan 2016
                        • 4883
                        • Russia
                        #91
                        Regards,
                        Pat.
                        I can, but it (dump) is working for you, your problem is not in it.
                        • murtagh
                          • Feb 2014
                          • 9
                          • Ireland
                          #92
                          Thank you Lotas, much appricated.
                          • juani981
                            • Jul 2024
                            • Argentina
                            #93
                            Hi Lotas, my TV model is UN50MU6100GCZB, Board Code: BN41-02568B from Argentina. I'm having the same issue as another user before. The standby LED turns on for 1 sec every 15 sec. When Flashing an incorrect bin, the board stays completely dead. So I guess it could be bios related. could you help me? Thanks in advance
                            • lotas
                              • Jan 2016
                              • 4883
                              • Russia
                              #94
                              Strange damage to the dump, usually if in this series the MU dump is damaged at the beginning of the dump, then the TV's standby LED does not light up at all. Try this one, I adjusted it a little, and don’t forget about the status register after recording the dump.
                              • Ashry
                                • Aug 2024
                                • 10
                                • Egypt
                                #95
                                Hello
                                Please I need your help with this mb bn41-01587e
                                5vdc exist but standby led not light and no action with power button
                                IC 1401 should be reprogrammed or what?
                                • Ashry
                                  • Aug 2024
                                  • 10
                                  • Egypt
                                  #96
                                  Dear Sir can you help me with dead main board ( BN41-01587) for Samsung ua40d6400un and power board (BN44-0427A)
                                  i uploaded the flash files from 24c02 (IC 1205) & 24c512 (IC 1401) ​
                                  A5 & 3.3 vdc are exist.
                                  thanks in advance.
                                  • lotas
                                    • Jan 2016
                                    • 4883
                                    • Russia
                                    #97
                                    Where did you get the idea that the problem is in these firmwares, if there is no standby mode and the LED is not on, then a common problem in this chassis is IC204 (stabilizer from 5v to 3.3v) and micom Weltrend, check the resistance at 1.2 pin IC203 relative ground and is there 3.3v power on these pins​
                                    • Ashry
                                      • Aug 2024
                                      • 10
                                      • Egypt
                                      #98
                                      Thanks for your your support. i found that sub eeprom (24c02) is connected to this ic1203 so i thought this may be the problem.
                                      I measured the regulator and i/p 5.3 v & o/p 3.3 v so it is good, also the voltage at pin 1&2 3.3v and no short with ground. i tried to press the reset button but nothing happened
                                      how can i check ic1203 (61P805) is healthy ??
                                      does it need programing? if yes can it be done by CH341?
                                      • lotas
                                        • Jan 2016
                                        • 4883
                                        • Russia
                                        #99
                                        What initially happened to the TV? In service mode, at the point you clicked on “Micom Update” and after that the TV stopped turning on?
                                        If yes, then the firmware has been erased in micom, you need to program it.
                                        And also, you have some strange dump 24C512, or it is so badly damaged or poorly read, try this one.
                                        • Me_you_them
                                          • Aug 2024
                                          • 5
                                          • Italy
                                          #100
                                          Hi lotas,
                                          can you help me with this firmware???
                                          Samsung UE55MU6400U
                                          M/B BN41-02568B (BM94-12401R)
                                          • Yanleb
                                            UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                                            by Yanleb
                                            My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                                            Disconnecting the main board from the power supply makes the backlight come ON.
                                            I did disconnect the panel cables and the WIFI modules, the board is still dead.
                                            I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                                            Thanks.
                                            11-18-2024, 12:34 AM
                                          • ogabuga
                                            Asrock B650E PG-ITX BIOS_WHP1 /25Q40/
                                            by ogabuga
                                            Hello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D​
                                            01-28-2025, 04:48 AM
                                          • daniel0799
                                            Full 25Q40 dump for TP-LINK TL-SG1016D V7 (RTL8382L + 2x RTL8218B, PCB KB616010558)
                                            by daniel0799
                                            I’m looking for the **full 512KB (25Q40) SPI dump** for **TP-LINK TL-SG1016D V7 (unmanaged)**, PCB code **KB616010558**, with SoC **RTL8382L + 2×RTL8218B**.
                                            My current dump only initializes 8 ports and the LEDs are misaligned, so I believe I have a firmware from an 8-port model.
                                            I need a complete dump (bootloader + firmware) from a working switch to restore full 16-port operation.
                                            If anyone has this model or a similar V7 revision, please share the BIN file or point me to a resource.
                                            I can provide photos of my board and the flash...
                                            10-22-2025, 11:12 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                          • totof
                                            Samsung UE55MU6102K IC1604 dump needed - TV don't start
                                            by totof
                                            Could you help me...
                                            I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
                                            Then motherboard connected, standby led is on and current consuption is 18W.
                                            Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
                                            Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
                                            The model of my TV is :
                                            Power supply BN44-00807A
                                            Main Board BN41-02568B / BN94-12765W
                                            Panel CY-GM055HGLV3H...
                                            05-01-2023, 04:30 AM
