Sony XBR-65X900E 4 Blink Code
  • Storyteller12
    • Jun 2020
    • 625
    I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
    I don't work on Sony much but assumed it was backlights from what I read.
    Opened up the TV and tested all the backlights with led tester and the all work.
    I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
    So anyway to test these lights similar to the way we test Samsung by unplugging the main board from the power board.
    • 12306
    • U.S.
    Re: Sony XBR-65X900E 4 Blink Code
    a couple things here, there's a bunch more on youtube basically doing the same thing as Nick's ground out there, I'm not sure if the protections on these xbr's are over sensitive or what, hopefully all the people doing this bypass are not in danger of the tv catching on fire: https://www.youtube.com/watch?v=T3VRvQUB_DQ
    https://www.youtube.com/watch?v=XxZHoimSvOU
    • Storyteller12
      • Jun 2020
      • 625
      Thanks for the videos. I did see those, but in the comments nick says this doesn’t work in this model # and to replace leds. and the other video the guy doesn’t say backlights. He mentions no picture, not sure if it’s backlight related, and has a red blinking light on his board where he did the mod. . Mine doesn’t have the red light blinking.
      I can try the second video method just not sure if it will work. I guess it doesn’t cost anything to try. Just wanted to get some opinions from you guys
      • diif
        • Feb 2014
        • 6978
        • England
        More than one LED set in series ? Did they all measure the same voltage ?
        No bench power supply to test the LEDs with sufficient current ?
        • Storyteller12
          • Jun 2020
          • 625
          No bench power supply. Only led tester.
          all voltage measured the same. When i test the lights only 3 leds light up per test point. Buy they all light up
          I have to say this is the craziest designed set I have seen for the backlights. The way they arrange them and the way all the cables run all over the place and under some led strips.
          Sorry no photos. My phone camera broke and I’m waiting for a replacement. I’ll provide pics in a day or 2
          • Diah
            • Feb 2013
            • 6483
            you need to draw out the strips line and led bl socket to understand how they are divided... so you will go to replace only defect led part
            • Storyteller12
              • Jun 2020
              • 625
              How do I determine only affected part of led? They all light up with tester. Can I power tv on without the screen to see if any leds are faulty under load.
              I know I can with Samsung and LG. Every sony I’ve ever got was a bad main board Emmc failure.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4508
                • Italy - Milan
                You have bad leds probably, but instead if the leds groups are controlled singolarily (local dimming) it's less probable, but the photos now are mandatory to see if there is an high voltage booster etc..
                  • 12306
                  • U.S.
                  I hear that, I wouldn't be surprised if it was another bad emmc, maybe test a bunch of those little caps around it for shorts or an off ohm reading.
                  • Storyteller12
                    • Jun 2020
                    • 625
                    Sorry for the delay. Life got in the way.
                    Here are pics of the led array and back of the tv with the boards.
                    Also I made some progress and found to e bad leds as mentioned above.
                    If you unplug the LV board I think it is. Then plug the tv in it does a test pattern with the leds.
                    I found 3 out under load.
                    These leds measure 11.9v, Essentially 12v.
                    Where to buy single 12v led to replace just the bad ones?
                      • 12306
                      • U.S.
                      Nice work, I see you have 9 rows, my XBR-65X900C is edge lit from the bottom, only one edge too, wouldn't think there would be that much difference with only the last letter in the model different.
                      • Storyteller12
                        • Jun 2020
                        • 625
                        Yes, it’s a if difference between the 2. But whatever engineer designed this thing should be fired.
                          • 12306
                          • U.S.
                          lol^^^^I agree 1000%
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4508
                            • Italy - Milan
                            Why do you tell this? It's not a normal back light is a local dimming , it's for a better lighting.. how it works the test pattern? it is tested each led at a time and 3 doesn't light up? since the capacitors for the output are 63v i guess not only a led is fed at a time.. 12v per led means them are chip leds with 4 leds inside.. this is strange.. no idea why..
                            • Storyteller12
                              • Jun 2020
                              • 625
                              The test pattern lights up a few rows vertically and then alternate the other rows. I’m guessing to verify the local dimming feature works, then Lights up all leds. If they all work it stays lit.
                              Update I wired in 4 leds (3v each for total of 12v) to fix the backlight issue as a temp solution and the lights now work and stay lit during test. Sadly It still cuts off and blinks 4 red lights after reconnecting the LD board to the main board.
                              I’m beginning to think it may be main board issue now.
                                • 12306
                                • U.S.
                                maybe also make sure the proper voltage is leaving the dps board like Nick here on this 930D, not same model but same concept: https://www.youtube.com/watch?v=kaCl8J1pPd8
                                • Storyteller12
                                  • Jun 2020
                                  • 625
                                  Update. Tv is fixed. Had to replace all the led strips.
                                  I installed temporary leds where the bad ones were to test and it lit up and passed Sonys test mode but it still didn’t work when powered on. Very strange but Sonys backlights are very sensitive and need exact volt/amps to work properly it appears.
                                    • 12306
                                    • U.S.
                                    yep, that's probably whats causing a lot of the issues with these xbr-xx X models, wonder if theres a way to tone down the sensitivity.
                                    • my2k2zx2
                                      • Jan 2023
                                      • 20
                                      I'm having the same issue with our XBR-55X900F. Powers on, starts the android animation, goes black with 4 red led flashes. Is replacing the led strips the only way to fix this one? I have no idea how to get the panel of if that is the case.
                                        • 12306
                                        • U.S.
                                        ok, this one appears to be solved. @my2k2, can you post some good straight on pictures of each board and one of the whole back, as to see how everything is connected.
                                        • EazyBone
                                          Sony 85x90CK 4 red blink
                                          by EazyBone
                                          So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                          But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                          Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                          Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                          07-18-2025, 12:53 PM
                                        • x_orange90_x
                                          Sony KD-75X750H no backlights
                                          by x_orange90_x
                                          I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                                          Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                                          07-16-2025, 07:49 PM
                                        • cheeky2
                                          Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                          by cheeky2
                                          For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                          See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                          01-08-2024, 05:56 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • EazyBone
                                          Sony XR-77A80J OLED 5 Blink
                                          by EazyBone
                                          Another eazybone post took on this OLED now.
                                          Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                          I'm thinking I have a power board issue though, which is one of the options
                                          Now to check pin voltages from PSU to main and PSU to tcon
                                          Pic 2
                                          1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                          2 bl err -- 0.16
                                          3 evdd on --0
                                          4. Ac off det 3.187
                                          5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                          6 stby...
                                          10-24-2023, 09:09 PM
