I just accidentaly destroyed my Fortron Blue Storm II
  • isabis
    • Sep 2015
    • 6
    • Croatia
    Hello everyone!
    So I recently had problems with my Fortron Blue Storm II (JonnyGuru review: http://www.jonnyguru.com/modules.php...=Story&reid=84).
    The problem was that when I would turn on my PC, my fans would start spinning and then stop after 1 second, PC wouldn't boot up at all. Classic PSU problem I thought, and went ahead to replace my Fortron with a PSU from my brothers PC and voila - my PC works!
    So I went ahead and opened my Fortron to see if I can find out what's wrong with it. What I saw were multiple very dense clusters of dust on few capacitors and transistors. Components looked good, nothing seemed burned up. There was one capacitor that was a bit inflated and another one that seemed to release the chemical, but just a bit. I thought it's not such a big deal and went ahead and cleaned that dust clusters all up, plugged my PSU back and voila – it works!
    Now this is the part where idiot me destroyed the PSU, thank God I didn't get electrocuted in the process:
    PSU fan sounded weird (probably because the PSU was standing upside down and fan was facing down, not the position it was designed to stand in, but idiot me didn't realize it right away) so I went ahead and took the metal case cap of the PSU with the fan attached to it WHILE PSU WAS WORKING to do something with it. Thinking about it now, idk what would I do with a spinning fan, but yeah, idiot me went ahead and did it anyway.
    While I was removing the metal case cap, I accidently touched PSU heatsink with one end of the metal case cap and the rest of the big metal case with the other part of the metal case cap.
    When that happened, I saw and heard a spark, after that my PSU wasn't working anymore.
    Here is a picture to help you understand what happened.
    So basically, I "repaired" the PSU by cleaning it from dust and then I destroyed it right away.
    Here are the pictures of the capacitor that seemed a bit inflated and the one that seemed to release the chemical a bit. Important: my PSU was still working with these two in this condition before I destroyed the PSU.
    More pictures of the PSU here.
    Any ideas on what could have happened here and what needs replacing?
    Thank you in advance!
    p.s. I know, I am an idiot
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: I just accidentaly destroyed my Fortron Blue Storm II
    Those caps are indeed bad. You probably killed whatever semiconductors are mounted on that heatsink that was shorted to gnd through the case cover, and possibly other components in that part of the circuit.
    • isabis
      • Sep 2015
      • 6
      • Croatia
      You gave me some hope in repairing the PSU when you said that I probably killed the semiconductors and then you immediately crushed all the hope I had by saying "and possibly other components in that part of the circuit".
      So, I should just buy a new one I guess.
      With my limited knowledge, I would barely replace the semiconductors, but there is no way I could find and replace those other components that I probably destroyed.
        • 31084
        dont panic, the heatsink is sometimes live - you will have blown a fuse and *maybe* damaged the main rectifier.
        nothing expensive or serious.
        more importantly, about those caps.
        there is no such thing as "just a bit", it's not like cutting yourself!
        both those caps are done - and could blow something.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8212
          I double up stj's comment above. It's a bummer, but fairly inexpensive and easily repairable.
          • isabis
            • Sep 2015
            • 6
            • Croatia
            ok, if it helps in any way, the fuse in my house burned when this happened as well, it was 500V 16A fuse, I had to replace it
              • 31084
              well you need to check the fuse on the psu, and meter the pins on the rectifier to make sure it isnt shorted.
                master hoarder
                • May 2008
                • 12175
                +1
                I have fixed this exact same problem for a classmate's PSU. In his case, he dropped the PSU without its top cover while it was connected to the wall. The metal case (which is grounded) touched the heatsink (which is live at -170V). Result: blown fuse. EASY FIX!
                +1 again.
                This is Why You NEVER Ignore Bad Capacitors!
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Always replace bad caps and caps of the same brand and series ! Always Always Always if you want your device to work and be more reliable !
                  • dragos2009
                    • Mar 2013
                    • 110
                    you have 3 bad caps the other one is hidden under the output wires
                    • ChaosLegionnaire
                      HC Overclocker
                      • Jul 2012
                      • 3264
                      • Singapore
                      well, inexperienced users shouldnt be doing reckless things like running a psu while it is opened up.
                      u could have ended up dead as a burnt smoking corpse from the short u caused. thank god for the earth wire. thats what saved u from being zapped.
                      as a former ambulance medic, i actually dont enjoy doing cpr and having to defibrillate people. (sorry u had to hear that from me)
                      i hope u have learnt your lesson and exercise better electrical safety in future!
                      • isabis
                        • Sep 2015
                        • 6
                        • Croatia
                        @stj & momaka thank you for your help, but I really don't know where the fuse is, I decided I'll take the PSU to the repairshop and explain what happened to the repairmen
                        this repair, no matter how simple it may be, is too hard for me
                        @dragos2009 that is a nice find really! thank you, didn't even notice and you found it on the picture
                        @ChaosLegionnaire Lesson learned, I assure you. I'm never messing around with high voltage components anymore...
                        PSUs are always grounded like this to save idiots like me, right? If not, then fuck, I will get shivers every time I think about how close I was to being possibly dead that day.
                          • 31084
                          the fuse is near where the power wires go on the board - show a foto
                          ok, the fuse is on the corner of the board in a black sleeve.
                          just desolder it and cut the black sleeve away to read the numbers on it.
                          • Behemot
                            • 4845
                            • CZ
                            Start with checking the fuse and input rectifier, the heatsinks are grounded to rectified ground which may still be on different potential than the earth ground. Otherwise the silicon in FSP PSUs is for many years in fully insulated TO-220F packages so no other silicon should be affected.
                            The 100uF cap on the auxiliary rail from stand-by supply is gone too. If you want I have D8 caps just for these units as they are still quite common and known to go bad because of bad custom crapacitors so I can supply you.
                            • ChaosLegionnaire
                              HC Overclocker
                              • Jul 2012
                              • 3264
                              • Singapore
                              its for electrical safety in case sheet happens and the live wire somehow breaks loose and touches the metal casing. this will immediately cause a short to ground thru the earth wire blowing the fuse and cutting off the power thereby preventing anyone touching the metal casing from getting zapped.
                              • Behemot
                                • 4845
                                • CZ
                                Nowadays breaker rather than fuse, fuses are replaced by breakers here at for at least 50 years.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  Yes, they are... but the question is, does your house have proper grounding? Because if not, then the case can become live without tripping anything. Modern electric codes in most countries now require a safety ground on each outlet. However, there are still plenty of old houses in many parts of the world that don't have grounded outlets, including here in the US. As a matter of fact, I lived in one like that while in college. The thing is, I had hardwood floors everywhere and the house was sitting a few feet from the ground, so I could touch live wires all day and not get shocked . Just keep away from sinks, pipes, faucets, coaxial cables, and other (possibly) grounded objects.
                                    • 31084
                                    lol - try that with 240v.
                                    you will be on your back, trust me - i know!
                                    • ChaosLegionnaire
                                      HC Overclocker
                                      • Jul 2012
                                      • 3264
                                      • Singapore
                                      keke lying on your back with 240v...
                                      electrotherapy massage anyone? full payment upfront for the massage. no refunds if it kills you!
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        You can try it even with a 1000 V. It won't hurt one bit if you are well-isolated from ground. On a dry hardwood floor in a wooden house, you just won't get shocked. Now don't try that on a concrete or ceramic tile floor! (or even brick, for that matter.) Also, wearing good (dry!) shoes helps too .
                                        • Alain Renteria
                                          LG OLED77G2PUA Not Powering On After Storm
                                          by Alain Renteria
                                          Got it for free on marketplace because it stopped working after a storm.
                                          When I began troubleshooting the power supply, I fried 2 fuses and a mosfet by shorting 2 pins on accident, but I've replaced those components.
                                          The tv had a soundbar connected, which was also killed by the storm. On the tv side I found a transistor shorted on the hdmi 2 (arc) and a lot of capacitors shorted on the main board.
                                          Disconnecting and reconnecting the psu to main board cable, while still being connected to 120 V AC, would wake things up, such as a red light from the optical...
                                          11-25-2024, 11:11 PM
                                        • bobbintb
                                          TCL Roku 55S403TCAA dead after storm
                                          by bobbintb
                                          I have a TCL Roku 55S403TCAA. It quit working after a storm. Other electronics quit working as well so I am pretty sure the storm had something to do with it. Anyway, I took a look at it, no obvious damage, blown components, scorch marks, etc. I am looking at the power board first, 40-L141H4-PWG1CG. I've repaired bad caps and blown components but nothing more extensive beyond that. I am trying to troubleshoot it, but I can't even find the fuse on this board. There are markings on the PCB saying "replace fuse as marking" however. I attached a photo of the board. I am also testing the...
                                          11-19-2023, 05:02 PM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • televizora
                                          Curious - clock going ahead
                                          by televizora
                                          I've encountered curious and strange issue with HP Probook 8470p - the clock is constantly going ahead without any reason at all.
                                          If I try to synchronize it, everything is fine, but after hour or two I notice that the clock is again 9-12 minutes ahead.
                                          That's extremely weird. Logically, I checked the time zone and DST - everything is fine there.
                                          That's only if the laptop was put in hibernation and then turned on again. If it was turned off and then on - everything is fine.
                                          Any suggestions?
                                          03-15-2023, 01:37 PM
                                        • LaPCon_IT
                                          iMac A2438, destroyed capacitor and coil.
                                          by LaPCon_IT
                                          Hi people.
                                          iMac A2438, board 820-02009-06. Some insect has killed itself destroying capacitor and coil next to it. No chance for buying donor board, so I'm asking you for help about values of destroyed components.
                                          03-16-2024, 09:32 AM
